Question about HP OfficeJet 6110 All-In-One InkJet Printer
Changed black cartridge. Machine works fine, but
Changed black cartridge. Machine works fine, but shows "press enter to align cartridge" message. Is there a way to reset machine so this message does not show?
  • mlgrubb Apr 21, 2009
    The machine is used solely as a fax and is not connected to a computer, so this fix does not work.
  • HP Expert
  • 228 Answers
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Posted on Apr 19, 2009
2 Suggested Answers
Astinsan
  • 87 Answers
SOURCE: won't fax or receive
You need to check the cable that goes to the wall.. Make sure it is plugged into the plug on the printer that says "line" or "wall" if it is plugged into the one marked phone... it will most likely not work.
After that (if it doesn't work) go through the setup procedures the manufactures manual has for that model
If you lost it your in luck HP has everything you need here:
http://h10025.www1.hp.com/ewfrf/wc/product?product=60259&lc=en&cc=us&dlc=en&submit.y=9&submit.x=7&lang=en&cc=us
Posted on Apr 25, 2009
Have changed the black ink in the printer as it was displaying error code 4. It is now displaying error code 5! What does this mean. What should I do?
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I changed the cartridge on my machine. I got the
You can bypass the alignment on the machine making it use the previous alignment. To do this, press and hold down enter when it says press enter to align cartridges and then press setup.
Oct 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Jul 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Won't fax or receive
Apr 17, 2009 | HP PSC 950 All-In-One InkJet Printer
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp2170 all in one
error message on saying remove and check cartridges , was working fine yesterday and nothing has been changed
Apr 17, 2008 | Office Equipment & Supplies
Shows press enter to align cartridges
Drop ithe 2210 from the 10th floor of a 22 story building. Problem solved. No more repetetive error !!!
Apr 08, 2008 | HP Office Equipment & Supplies
I topped off the ink and pressed enter and set up at the same time...I didn't have to do the page alignment again and my copies seemed pretty good. Thank you to the site for the tips!!! Happy Day connien2003
Mar 08, 2008 | HP PSC 950 All-In-One InkJet Printer
Printer not working...
Press Enter and Menu simultaneously when align message is prompted on the All-in-One.
Dec 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
233 people viewed this question
Seeker5211
Seeker5211
