Laptop Overheating My gateway mx3701 keeps overheating and shutting down. I predominantly use the laptop for browsing and video. The fan exhaust port sometimes smells like something is burning. I installed speedfan - it says that the core is running at 75*C and rising. how do I remedy this problem?? Any help would be appreciated.
  • 741 Answers
Check all the vents and the CPU fan, something is not ventilating as it should..
Posted on Apr 19, 2009
Gateway laptop keeps shutting down
If there are no apparent software failure symptoms that are causing this, my best guess would be an overheating shutdown. Many laptops will get clogged with dirt because their intake fans are on the bottom and many users place them on laps, floors, and surfaces that allow dust and dirt to be sucked in easily. These clog up the heatsink that cools the processor. The unit has safeguards that shut down the unit if the processor gets too hot. Many units can be easily cleaned, but many others require a complicated tear-down to do this.
Sep 16, 2014 | Gateway Computers & Internet
Shuts down unexpectingly when running game programs
Is the Laptop Overheating? During intense game play your Laptop will Overheat if it's not getting sufficient air flow. Try cleaning the Fan, vents, heatsing with Compressed Air, Improve air flow through the Laptop, a Laptop Cooler is a option. Try shutting down unnecessary processes, I use freeware RAZER GAME BOOSTER, you configure what you want to shut down: http://www.razerzone.com/gamebooster Remember, Your machine usually shuts down for a good reason, it's trying to protect vital components. Overheating will fry the CPU, Graphics Adapter, etc.
May 11, 2013 | Gateway NV73A17u Laptop
Computer shuts off at random
It sounds like it's overheating, check your fans make sure all are working, if your fans are all working then your power supply is overheating and should be replaced. If your system is a laptop the battery can overheat also and shut the system down. So you can have different issues dependent on laptop to desktop.
Feb 03, 2012 | Gateway Computers & Internet
HP Pavilion dv2610us overheating causing laptop to slow down?Is this because my laptop battery died
Overheating is not caused by dead battery. The most common cause of it is a faulty system fan. If the fan has mechanical defect or has degraded performance due to accumulated dusts and particles around it, it will cause overheating. Overheating can cause system to slow down at first, then if you keep using it without minding the overheating problem, your laptop can freeze and shut down on its own.
Here are some tips for overheating issue:
- Use canned air to blow out dust and particles from the system fan.
- Do not operate the laptop in areas where the temperature is high, it will worsen the problem.
- Replace the fan if you notice that it is not working properly as before cause it will further damage the laptop.
Hope this helps.
Jul 09, 2011 | HP Pavilion dv2610us Notebook
My medion laptop keeps overheating
change your laptop heat sink fan
Nov 11, 2009 | Computers & Internet
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Aug 08, 2009 | ASUS m6n Notebook
Video Quality Problems
Hey,
the laptop is overheating and shuts down to prevent hardware failure. Use canned air to blow dust out from the fans that may improve it a little.
Feb 18, 2009 | Toshiba Computers & Internet
Gateway laptop fan problems
IF you trust yourself, take apart the laptop and apply a thin coat of thermal paste to the processor, and put it abck together. This should help.
Dec 18, 2008 | Gateway (8008625) Cooling Fan, Heatsink...
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
