Question about Whirlpool ES5FHAXS Side by Side Refrigerator
ICEMAKER NOT WORKING LOWER PART OF THE FREEZER IS WORKING: MEATS ARE FROZEN. REFRIGERATOR SIDE IS NOT COOLING
    Top Expert:
  • Whirlpool Master
  • 76,846 Answers
  • The defrost timer is stuck in defrost mode. Turn the little thumb screw CW and see if compressor starts. If compressor starts and temperature starts to pull down, replace the timer before your evaporator ices up…again.
  • If your refrigerator has an adaptive defrost control board instead of a mechanical defrost timer, the board might be fried.
  • The evaporator fan motor is fried. Open your freezer and see if you hear the fan motor running (on some models you need to hold down the door switch to run the fan). If not, you’ll need to replace either the fan motor or the fan switch (if your fridge has one). How do you tell which one is bad? Kidneys.
  • The defrost heaters in the freezer are fried. How do you check? You got it: continuity. Another way is to put the fridge in defrost mode and measure the current draw with a clamp-on ammeter. Did I lose ya on that one, Hoss? You can also tell you got a defrost problem if you see a bunch of frost built up on the inside back wall of the freezer compartment. Read more about diagnosing defrost system failures.
  • The defrost thermostat is open. You know what to do.
  • Like 97% of appliance owners, you have the refrigerator cold controls set wrong.
Posted on Apr 19, 2009
  • yadayada
    yadayada Apr 19, 2009
    Click highlighted links above for more info about the problem and diagnostics.
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
My problem is that the items in the meat and vegetable bins in the lower part of the refrigerator are freezing and there is frozen water in the lower part of the freezer.
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 14, 2011 | KitchenAid Superba® Architect® KSRP22FSMS...
Freezer worked well for a few days then ice in icemaker started melting. Refirgerator side was frozen.????? Then it repeated again. Any idea
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Oct 08, 2010 | GE Refrigerators
Fridge coil is frozen but the fridge is not cold. Freezer coil is not frozen but freezer is cold. Icemaker doesn't produce ice and the water in the ice maker is not cold. What do you think?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
234tghj
Jun 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Frig not cooling-water line frozen
Check to see if the fan in the freezer is working. It moves cold air from the freezer side to the refrigerator side. If it is not working or if there is an obstruction in the duct work the issue could be there. Fans and motors are cheap and easy to replace.
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Icecream not staying froze meat stays frozen though
Meat is always more dense than frozen dairy product. This soft ice cream issue usually occurs when the circulating fan becomes blocked due to overloading.
Unlike a chest type freezer, top mounted freezers use a fan to circulate to the refrigerator. If the return vents to the freezer become blocked by too many small items, or loose plastic bags the compressor may run too long in an attempt to lower the refrigerator temp,
This may cause the compressor to heat up and kick in the overload safety, further dropping the total temperature.
Mar 05, 2010 | General Electric GTR16BBSR Top Freezer...
My side by side is not cooling well on either the freezer side on the refrigerator side...have both sides jacked up to nine ...it is still cooling but not cold enough!! The ice cream is soft, but the meats...
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 07, 2009 | Refrigerators
Maytag LRTC15A AH01A - not keeping insides cool - condensor fan working and clean - freezer fan working - cannot feel air flow to crisper (meat bin).
The flow ducts from the freezer to the lower part were frozen solid. Once fridge thawed and drained, all worked fine again. Flow duct very hard to get at.
May 13, 2008 | Maytag Refrigerators
Freezer is not working to optimum capability. Meats and frozen foods harden, but ice cream and breads do not. I have the temperature control to almost maximum. Any ideas?
remove bottom kickplate and clean condensor coils, pull away from wall and vaccuum behind and underneath. if the machine cant breath, it cant cool properly
Mar 05, 2008 | Amana ASD 2624 Side by Side Refrigerator
Whirlpool ES5FHAXS Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
