Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
Digital cable service in house.
I have cable digital service, with cable box on family room tv, I have an older (non-digital) tv in bedroom. Can I buy a turner to connect to this tv to get additional channels, without renting a cable box from service provider.
  • 33 Answers
There are many providers who are providing a best cable service in good pricing. They are also providing several in house cable services and promotion code, discount offers. You can take service from these providers, they are also provide cable conversion box with promotion codes. Verizon FIOS Promotion Code Save up to 50
Posted on Feb 23, 2015
  • 1,305 Answers
Many of the public channels were offering a coupon for a free cable conversion box... here is a LINK
Posted on May 10, 2009
How do I diagnose this lighting electrical problem?
Lighting cables have a tendency to run through the roof space linked on from one room to another. You need to access the roof space try and see where the supply from the fuse box comes in and trace the cables around the system. If you are not happy with household electrics then have someone who is take a look. I'm sure it can be traced to a junction box and probably a loose screw or damage from vermin or general deterioration. If the cabling is 1920's vintage then a lot were rubber coated long before PVC came along and the rubber rots away and problems occur. If the whole house has been rewired to modern standards then an insecure wire in a connector block is the most likely. Go careful and work safely.
May 22, 2015 | Dryers
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
Oct 23, 2013 | Neet Cooler Trunk Organizer
Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the...
If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
Here is a suggestion for Wireless Access Point.
You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
Dec 30, 2010 | Computers & Internet
Virgin cable installed, how can I get it to other rooms?
Buy a spliter and install it on your line out (to tv) on your cable box. Now u have two lines out, but both tv sets must watch the same chanel
Apr 28, 2010 | Televison & Video
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Second zone not working
This amp allows you to pick a secondary source for those other rooms. Did you by chance accidentally change it from the "SOURCE" designation that makes room 2 listen to same thing as room 1? Just a thought.
Dec 04, 2007 | Denon AVR-3801 Receiver
Thomson dsi 4200 satellite receiver
The only way this would work ( and this applies to any form of cable/satellite box) so the only way this works is if the TV that has the satellite connected to it has a video output normally indicated with the color yellow, but you still need sound that normally is the red and white (RCA cables). So the first tv needs to have video and sound outputs and the TV you want it connected to needs to have the video and sound inputs. depending on the distance between the 2 TV's this might prove to be rather difficult. it would be easier to run the coax cable from the main satellite box to the room where you have the 2nd TV however to do this you would need to move the satellite box back and forth. Hope this helps
Aug 22, 2017 | Televison & Video
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
126 people viewed this question
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
paul
paul
Back2life...
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
