Where is the fuse box in the inside air handler?
We have a trane xe1000. We were updating the thermostat and believe we have blown a fuse in the air handler. We checked the power with a tester going into and in the air handler, which is positive. We tested the thermostat and nothing. Where is the fuse in the air handler that we need to replace? The 50 watt in the outside unit was blown and we have replaced. We also replaced the power cord and box.
  • 24 Answers
There should be a small 3 or 5 amp fuse on the circuit board inside the air handler.
Posted on Apr 20, 2009
Why did the air handler on my 1999 Trane heat pump stop working? Could it be a fuse in outside unit
The fan is controlled by a relay that is operated by the thermostat. There is usually a wiring diagram inside the unit that will show the location of the relay.
Feb 08, 2015 | Heating & Cooling
NO POWER TO MY LOW VOLTAGE THEMOSTAT
rarely is the blower motor fused that might be a 2.5 amp fuse read across the fuse if you have 24 volts it is bad.
May 31, 2010 | Goodman CKL60AR60 Air Conditioner
Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Feb 06, 2010 | Heating & Cooling
Secondary fuse
Usually there's a fuse in the electronic board in the air handler (it's like the car fuses and 3amp or 5 amp). Also some transformers have a reset switch.
Sep 27, 2009 | Ruud UBHC Air Conditioner
Trane Air Handler and Trane Thermostat with no power. Please help
First of all put back the jumper wire you remved Rc to Rh and also put the red wire to either one then the white to W, the green to G and the yellow to Y .That is for the thermostat wiring for a not heat pump outdoor unit.Remember this electronic thermostat has a time delay so the unit will take a few minutes to start.All this if the problem is the thermostat.But also when nothing works it could be that the drain line is clogh and some air handlers have a flood switch who shut the unit off if drain is clogh(it could be located in the drain line out of the air handler or inside it on the drain pan.) newer TRANE units have it inside.
Aug 13, 2009 | Heating & Cooling
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
Heating & Cooling Logo
1,672 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
