Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars lite 2 LG or LD Pool Heater- Heater won't stay on
The heater willl turn on for about 2 minutes, then cycles off, theyn trys to turn on again and does, but turns off within 10 seconds. Pressure on the pump is low, pressure switch has been replaced and the temp on the pool is below thermostat setting.
  • Anonymous Jun 01, 2008
    pool heater goes on for a short time then shuts off
  • lizbb Jul 10, 2008
    My heater would not turn on tech came & changed the water pressure switch. then it turned on but would not stay on. according to him the control panel needs to changed & that might solve the problem is that so
  • 22 Answers
The control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Posted on Feb 19, 2009
Clean your filter first, the water flow may not be strong enough to allow the furnace to stay lit.
Posted on Jul 13, 2008
Try jumping out the pressure switch on the heater. The pressure switch is normally closed, the water pushes it open. You can check continuity between the contacts on the pressure switch. Even a new switch will still cut the conenction
Posted on Oct 02, 2007
SOURCE:
Keyless for a ford freestar 2004 i replace the batery in the remote control and now the remote not work
You need to reprogram it here are the steps
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Mar 13, 2013 | Televison & Video
I own a 2005 Ford Five Hundred and I am trying to get my keyless entry to work.
I assume you are trying to program the remote. Here are the instructions. Your question is very vague.
Oct 20, 2012 | Cars & Trucks
1999 Mercury Sable Keyless entry wont work
I only have the instructions. If it won't program you may have a problem in the module. In that case see the dealer for testing and diagnosis
. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN.
Door locks will cycle to confirm programming mode. 2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle
Jul 03, 2012 | 1999 Mercury Sable
Reset code for 2005 Ford Focus keyless entry remote
So this answer is on the same topic of a 2005 Ford Focus keyless entry remote. There is no way to "reset" the code from the vehicle, however you can reprogram an existing or program a new keyless entry remote to your Ford Focus by using these simple instructions:
*** THERE ARE 2 POSSIBLE PROGRAMMING PROCEDURES. ***Procedure #1
Note: Obtain all remote transmitters for this vehicle.
Note: Do not depress the brake pedal during procedure.
  1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
  2. Within 20 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 4.
  3. Within 20 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 3. For all other remotes.
    Procedure #2
  5. Note: Obtain all remote transmitters for this vehicle.1Fasten seat belts and close all doors.
  6. Turn ignition from OFF to RUN 4 times within 6 seconds, with the 4th time ending in RUN. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
  7. Turn ignition to OFF. Acoustic signal will sound and system warning lamp will illuminate to confirm programming mode.
  8. Within 10 seconds, press and hold any button on the first keyless remote. Wait for acoustic sound and warning lamp to flash (confirming programming) then release button on remote. Wait 2 seconds but within 10 seconds repeat step 4. For all other remotes. If you only have one remote then continue to step 5.
  9. Turn ignition to Crank or wait 10 seconds to end programming mode.
Jan 30, 2012 | 2005 Ford Focus
Have mecruy montneer 2001 lost keys how to program it
Programming Instructions: 2001 Mercury Mountaineer.
Apr 26, 2011 | 2001 Mercury Mountaineer
How to program keyless entry? bought vehicle used from dealership
Feb 04, 2010 | 2003 Ford Expedition
Trying to program a remote, but it doesn't work.  i followed the instructions turned the key from off to on 8 times and left it at on, but the locks did nothing. can you help?
WHAT FOLLOWS IS THE CORRECT PROCEDURE, REMEMBER YOU MUST COMPLETE THE 8 KEY CYCLES IN LESS THAN 10 SECONDS, IF YOU DO IT RIGHT THE POWER LOCKS WILL GO UP AND DOWN TO INDICATE IT IS READY FOR PROGRAMMING.
Jul 08, 2009 | 2002 Ford Taurus
How do you program the key flob? Can you do this yourself our is this a dealer job. If yes to the dealer any other way to have this done cheaper? This is a 2000 ford windstar with 4 buttons on the remote.
From the owners manual.
Apr 09, 2009 | 2000 Ford Windstar
Car key remote
Mar 24, 2009 | 2001 Ford Expedition
96 sable wagon keyless entry
Try re-programing the system.
These are the instructions from the service manual.
. Turn ignition from OFF to RUN 5 times within 10 seconds, with the 5th time ending
Mar 02, 2009 | 1996 Mercury Sable
Heating & Cooling Logo
1,836 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Keith Bowers
Sheldon Dedek
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
