Question about HP Compaq nx9030 Notebook
HP Compaq nx9030 working fine then all of a sudden switched it's self off and now wont re-start, 'start windows normally page' is coming up but it seems to stick on that page. any one help?
  • 1 more comment
  • kirsty_ellis Apr 20, 2009
    wont start up in safe mode, wont start up at all. how do you run a error check on the hard drive? also now it is saying 'disk read error'
  • ERIC BAKER May 11, 2010
    To start up in safe mode usually F8 at the beginning of the boot up will give the option of safe mode.
    Have you tried starting up in safe mode to troubleshoot the problem and run a error check on the hard drive?
Compaq nx9030 not work whit 2gb memory!
check your processor speed cause it might also cause this type of problem
Dec 04, 2012 | HP Compaq nx9030 Notebook
I cant get ubuntu 11.10 to load onto my compaq nx9030 the disk runs fine but when i go to install it doesnt work
Use the Windows installer for dual boot. Easy! Or test as Live CD (no-install)
A full install may require partition and Linux disk / file format. Along with setup files destinations options. This a full commit install.
Nov 08, 2012 | HP Compaq nx9030 Notebook
My wifi wont light up or work please help its a hp nx9030
On front of the note book, right hand side almost directly under the wireless light, if a switch. That switch turns the wifi on and off, make sure it is in the on position (to the right). If that fails look at device manager (control pannel, system), and make sure your wireless card is loaded. It will be listed under network adapters. If it is not, then it is likely that something has gone wrong with the wireless adapter its self.
I hope this helps
Sep 01, 2011 | HP Compaq nx9030 Notebook
371796-001 HP nx9030 heat fan works when tested
go to bios settings by pressing F10 for hp .. there select the optimal factory defaults.and engage and also save settings with F10 ...and exit ..This will get rid of any wrong settings made in bios ..related with he fan ..and should start proper..The only thing that can malfunction is caused by a higher temperature to start ,, and never get to it ..
If it still makes the same ..you should consider changing it ..or see the wires to be proper inserted..cause it has 2 for power and one for starting..and can be damaged..but still functional when you check it ..just the wire for the start to be damaged or not making contact .. ..
May 24, 2011 | HP Compaq nx9030 Notebook
Unexpectedly shut down, wont restart, bought a new charger, still no luck.Heeeelp
plug charger up keep pushingf2 repeatedley tell you the first page start up then change boot formate to f12 then when asked push f12 3rd time restart push f12 then staRT UP WINDOWDS SECOUND OPTCION.
Feb 15, 2011 | HP Compaq nx9030 Notebook
How to remove my hard disk from HP Compaq nx9030
you have it explained in this manual from page 93 to page 97. It's very easy, but be careful when you remove the hard drive conector, if fits very hard to the HD...excuse my english.
Aug 26, 2010 | HP Compaq nx9030 Notebook
HP Compaq nx9030 power problems
all i do is hit Fn butten when booting
Dec 17, 2008 | HP Compaq nx9030 Notebook
HP Compaq nx9030 Notebook Logo
171 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
