Question about Fuji FinePix S700 Digital Camera
Fujufilm S700 won't power on. New batteries and are in correctly. Battery door closed properly, however, the door covering the SD is broken in half. Will this cause the camera not to power on?
  • lshunter Apr 24, 2009
    thank you for the information.
  • 244 Answers
Yes it will. The door activates a micro switch that cuts power to the camera when open to prevent accidental removal of the card and loss of pictures stored on the card. You can bypass this switch with either a solder "bridge" or remove the switch and use a piece of wire to bridge the pads on the board.
Posted on Apr 21, 2009
The battery door does not close properly. Can it be fixed?
Probably, but the cost may be more than the camera is worth.
Sep 27, 2016 | Sony Cybershot DSC-W7, DSC-W5,...
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
My camera won't power up with fresh batteries. It died while I was taking photos. I thought the batteries were flat so put in new batteries (two different sets), but the camera wont turn on when the start...
Try plugging your camera in via-usb into your computer. That's usually the most direct way to get power to your camera. If that doesn't work, check the battery door where you insert your batteries. It could be loose or closed incorrectly. If your camera doesn't turn on even after plugging it into your USB, there may be a hardware problem or something that has shorted out (possibly your LCD screen.)
Mar 06, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
My sony cybershot dcs-s700, it has new batteries, but the power button flashes green and camera will not stay on, and you are unable to magnify. Whats wrong
Hi!
Remove the Battery from the Camera and clean the battery compartment using a soft cloth. Then, press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery is fully charged. If the issue persists then the issue may be related to mechanical failure and service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Camera wont turn on
Check the internal contacts for bent, broken or improper connections.
Try inserting and pressing the battery in the camera while keeping the battery door open to see if the camera powers (This may help you determine if the battery is being held in correctly by the battery holder or the battery door.)
Cameras using AA type batteries
Check that the battery door closes properly and is snapped into place properly. Make sure there are no cracks or any defections on the battery door.
Mar 31, 2009 | Olympus FE-310 Digital Camera
Fujifilm finepix s700 is not turning on
OK
First check the battery door to make sure that it is closed properly. If you have a media door (the door which covers where the media cards are inserted) make sure that is closed properly. If this is the case then check that there is no plastic broken off. The doors contact with microswitches which allow the camera to turn on.
On the camera there is also a playback button. (green triangle) If you hold this and the camera turns on then your power switch is faulty.
Failing all of this then put some power into the camera via an adapter. If the camera turns on then it is likelly to be a battery fuse.
In all instances you will need to send the camera to be repaired at the fujifilm service centre. Web address below.
http://www.fujifilm.co.uk/technical/camera_repair/
Dec 17, 2008 | Fuji FinePix S700 Digital Camera
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
NO Power
Possible causes Solutions
/ Corrective Actions
The power does not
turn on.
The ViviCam 6300
suddenly powers down.
The image is not
captured when the
shutter button is
pressed.
The flash does not fire.
Continuous shooting
is not possible.
Cannot transfer files
over a USB connection.
* Load new or fully charged battery.
* Load the battery in the correct direction.
* Close the battery cover correctly.
* Properly connect the AC power
adapter.
* Set the option of Auto Shut Down to Off.
* Turn the power back on or charge the
battery.
* Rotate the mode dial to A , P , SCENE
, Tv , Av or M.
Transfer the desired files to your
computer and then delete unnecessary
files, or use a different memory card.
* Select a different flash mode.
* Select [Single] in the capture mode .
* Insert a new SD memory card.
* Check all connections.
* Install the USB driver on your computer.
* Turn on the ViviCam 6300.
* The battery has run out.
* The battery is not oriented correctly.
* The battery cover is not closed properly.
* The AC power adapter (optional)
is disconnected.
* The function of Auto Shut Down in
Jan 25, 2008 | Vivitar ViviCam 5386 Digital Camera
Not turning on
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
May 31, 2006 | Kodak EasyShare C340 Digital Camera
Fuji FinePix S700 Digital Camera Logo
393 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
