Question about AMD AXMJ2800FHQ4C - Athlon 2800+ XP-M 266MHz Processor
Athlon 2800+ XP-M runs at 606 MHz
I just bought a 2800+ mobile cpu. When inserted into system it will only run at 606MHz not the rated 2.13GHz. Motherboard is a Gigabyte 7VT600P-RZ(-C). will run anything faster than 1.4GHz, up to 400 FSB.Cannot find any way of increasing the multiplier. Ran Cpuz and it came back with: Core speed: 606MHz Multiplier: x6.0 FSB: 101.0MHz Bus Speed: 202.0MHz I tried the overclock program that came with my motherboard but it wouldn't let me change the multiplier settings. Do I need to reinstall windows? I assumed it would run default at 2.13GHz when inserted into motherboard, was I wrong in thinking this? Any help would be much appreciated as I don't want to go and spend more money on getting this thing working. Thanks. Mike.E
I'm running mine @ 16 multiplier, fsb 137mhz on an ASRock mb K7S41GX. Gives 2187.7Mhz
Posted on Jan 05, 2008
    Sergeant:
    Champion:
  • 293 Answers
1. Check your battery, 2. Press CTRL+F1 or ALT+F1 while you are in the BIOS. 3. Update your BIOS Microcode and CPU Code.
Posted on Sep 20, 2007
SOURCE:
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
I AM TRYING TO INSALL AMD ATHLON XP 2.5GHZ ON THIS MOBO BUT CAN NOT GET IT TO RUN AT CORRECT SPEED
There is no AMD Athlon that runs natively at 2.5 GHz. They were badged on comparative rating: a 2500+ will run at 1833 MHz or 1867 MHz, depending on the version.
May 11, 2010 | Chaintech AMD (7VIF4) Motherboard
Whats the biggest and or best cpu i can put into this motherboard. i curently have an amd athlon xp 2800. i just bought some more ram and wold like to know if i can speed up the cpu.
Here is a list of supported CPUs.
http://www.ruby-electronics.com/store_item/MSI_Athlon_XP_Duron_nForce2_Motherboard_K7N2_Delta_MS-6570-020
If you're going to upgrade to the XP3000+ (the fastest supported CPU), then be sure to get the one with the 200 MHz FSB.
Also, go with the lowest supported latency DDR PC3200 you can get IN PAIRS. Remember that Windows XP 32 bit only allows a total memory allocation of 4 GB which must include your video car memory and any memory allocation for add-on cards.
So 6 512MB sticks of DDR PC3200 are better than 2 2GB sticks of DDR PC3200. As the 6 sticks will allow for dual channel transfers (above and beyond the Double Data Rate) and will keep you well within your 4GB limit (once you add the video memory and any add-on cards).
You'll also benefit from doing a fresh install of XP with nlite or similar and stripping XP of all of the components you don't use. Good LUCK!
Oct 13, 2009 | MSI K7N2 Delta-L Socket A/nForce2/FSB...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
May 15, 2009 | Computers & Internet
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
http://support.asus.com/download/download.aspx?SLanguage=en-us
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Apr 16, 2009 | ASUS A7N8X Motherboard
How fast of an amd athlon processor can i use in a biostar m7mkb?
According to these specs 500 Mhz and up
http://www.motherboard.cz/mb/biostar/M7MKB.htm
Your motherboard supports a slot A Athlon.
The fastest looks like up to 1Ghz as according to CPU World:
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20(Slot%20A).html
Hope this info answers your questions. Feel free to comment if you need further info from me.
Rate me please when you get the chance.
Mar 04, 2009 | Biostar Slot A M7MKB Motherboard
I have AMD Athlon XP 2200+ m7vit bravo m-b
All current 333 MHz capable Socket A chipsets (VIA KT333, KT400, nVIDIA nForce2, SiS 746FX) should be compatible with Barton based processors although you may need to flash the BIOS for the processor to recognized properly
your board has a 333mhz front side bus so should be capable of running them
You must ensure that the cpu is for 333 mhz and not more and that it fits socket A which your board is
Please post rating thanks
Aug 01, 2008 | Biostar M7VIT Pro KT400 ATX Motherboard
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Open Questions:
See all AMD AXMJ2800FHQ4C - Athlon 2800+ XP-M 266MHz Questions
Computers & Internet Logo
177 people viewed this question
Top AMD Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
