Question about Compaq Evo D500 PC Desktop
New ram not speedy
I've recently updated the 2-256mb rams to 1-1gb ram chip in the left dimm slot. it just feels slower than when I had 512 in it. is it possible I installed in the wrong slot?
The old chips say 256mb ddr 266 cl2.5
The new one from PNY says 1gb ddr pc3200 400/333/266mhz
Thanks!
  • 272 Answers
Well, the lowest speed of those rams will be effective for all rams. If you install same sized ram on 1st and the 3rd port, it should be run on dual channel mode and will be fastest possible. please try this if you have 4 ports.
Posted on Apr 19, 2009
Can you put 2 igb memery into the blue connectors and 2 512 gb into the black connectors
Yes, provided;
A) The Maximum Total Amount for the Ram Memory is at least 3GB.
B) The Maximum Amount for each Ram Memory slot is at least 1GB.
C) The first blue connector is ram memory Slot 1. (DIMM 1)
The Processor 'sees' the Ram Memory in Slot 1 first.
If there is a large amount of ram memory, (1GB), and a small amount (512MB), the large amount goes in Slot 1.
ALL ram memory must be the same 'speed', (Frequency Rate), or the slower ram memory 'speed' will be used.
If there is too much of a difference it may not work at all.
Ram memory needs to be 400MHz, or 533MHz, for your computer.
{DDR2 Sdram at 400MHz = PC2-3200
DDR2 Sdram at 533MHz = PC2-4200 (Also known as PC2-4300)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 18, 2011 | Computers & Internet
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
Installed a second 256 mb memory card and it won't recognize it. System is still operating on only 256mb of ram instead of 512.
Are the DIMMS identical?
If they are not or one is faulty, it will not recognise the both of them.
Does it work with each RAM either way round?
The must be of the same manufacture and speed.
Hope that helps.
Dec 09, 2010 | Sony VAIO Digital Studio PCV-RX560 PC...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
DG965RY board can not reboot with 'restart' button on windows Xp
Run with only two RAMS each in one of the DIMM slots. Three RAMS may not work unless supported by mobo or being exactly identical in their specs..
Nov 17, 2008 | Intel DG965RY Motherboard
Acer travelmate 2003lc will not boot with new ram
512MB (FT64MSD64V3F)
200 Pin Dimm - SDRAM - 2.5V - DDR - PC2700 (PC-333) - Non-ECC
is the correct type of RAM for your laptop.
Have you tried booting with all combinations.
512 in slot 1 --- Boots
move same dimm to slot 2 (on it's own) and try booting.
boot with 256mb in slot 1 and known to be good 512 in number 2
This laptop should allow up to 2GB RAM. So I don't belive it is an issue with the mother board not seeing the amout of RAM. I think it could either be flaky dimm or your slot 2 is damaged
Aug 23, 2008 | Acer TravelMate 2300 Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Compaq Evo D500 PC Desktop Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
