Question about Battery Technology Computers & Internet
Dell laptop doesnt charge only runs on ac power
My dell laptop wont charge to use it i have to plug it in to the charger, sometimes it does charge and the battery is functional idk if its a setting on the power set up that makes it not charge the battery but run straight of ac power. what can i do?
  • mgqsc101794 Apr 20, 2009
    only a few months
    i know its not the batteries because sometimes it does charge
    the chargers new to cuase my old one broke so idk why
    the symbol in the task bar is supposed to show(if its charging) a plug with bolt going through up but when i plug in the charger it shows that momentarily and after a few seconds it just shows te plug meaning it running on ac power and the battery life stays the same
  • 50 Answers
How long have you had the laptop as all batteries even rechargeable have a limited life span. Dell laptop batteries normally have a life span of 1 to 2 years, so you may need to buy a new one
Posted on Apr 20, 2009
  • megax01
    megax01 Apr 20, 2009
    Even when the battery is gone it takes a small charge, however it'll only work for about a minute or 2 before it fails instead of the hour or more its supposed to work.
    When it charges does it last for the full hour or only a few minutes?
    And yes once its plugged in you won't see the battery symbol just the plug. You only see the battery symbol when your running on battery power. Once you plug it in and windows realizes this the battery changes to a plug that's just the way windows works.
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
My dell inspiron plugged in not charging
buy a replacement charger
if this does not work
i suspect the socket is perhaps damaged
sometimes its the laptops power management
so take the battery off
open the screen
press the power on
wait a few seconds
plug the battery back and the power
and see if the light flashes for charge again
i do suspect the charger or the laptops power socket...
Apr 19, 2015 | Dell Computers & Internet
Dell laptop wont charge battery.
The Laptop charger or the charging point itself is bad or damaged. You'll need to try different charger to take your laptop to any nearest computer repair shop to have charging point repaired or replaced.
Oct 28, 2014 | Computers & Internet
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
I have an Acer laptop and my battery is now only charges to 70% now, idk why and idk how to fix it, is there a way to fix it?
Could be you need a new battery. var fctb_tool=null; function FCTB_Init_443a2b995a89477b96a7f17c8ca41c58(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_26cbbf90a9594b92bb191c14e1f651ec(t) { fctb_tool=t; start(fctb_tool); }
Dec 10, 2010 | Dell Latitude C640 Notebook
My Inspiron B130 laptop wont charge. i have to wiggle the charger around, and sometimes that doesnt work.
Either the plug on the laptop is bad, or the charger cord is faulty. If you have a friend that has the same charger you can use it to find out which.
Laptop chargers do go bad...
Aug 04, 2010 | Dell Inspiron B130 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
187 people viewed this question
Top Battery Technology Computers & Internet Experts
Computer Links
Terry Schallert
Are you a Battery Technology Computer and Internet Expert? Answer questions, earn points and help others
