Question about Kitchen Ranges
Oven not heating
The oven is not heating. Light comes on in oven. Stove top burners all light as they should. The display says it's on and preheating but you do not hear anything come on and no heat when it says preheating is done. Underneath at the broiler I see nothing hear nothing and smell nothing.
  • 6 more comments
  • rgtorres1 Apr 19, 2009
    Model Number:  SF32SPEED        0
    Broiler does not come on either
    The burners are electronic
    How bout SF32PEE
    I'm sorry SF325PEE
    Thank you very much I will check that out
  • Scott Wiuff
    Scott Wiuff May 11, 2010
    is this older? That model number doesn't look farmiliar?
  • Scott Wiuff
    What is the model number? It should be either in that back or most likley in the front seen by pulling out the pan drawer. Is this electric? Does the broil element work?
    Scholar:
  • 87 Answers
On the bottom is a link of what your oven is. I'm pretty sure it's the ingnightor #16. You should see a glow red hot when you turn on the oven or broil. Very common problem and pretty reasonable price to repair. Unless that glows and get's red hot, it will not turn on the gas. I think that should do it. Let me know if you need anything else. Scott
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=SF325PEEQ0&productCategoryId=0124002&brandId=1198&modelName=Free-Standing,-Gas
Posted on Apr 19, 2009
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
Gas ovens are fitted with at least one safety device and it could be it has failed.
The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire oven will not light
The control panel behind the knobs is the most likely problem.
The heating element rarely fails.
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
Mar 11, 2009 | Electrolux 30" Self-Cleaning Freestanding...
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
OVEN WILL NOT HEAT UP
you probably have a bad bake ignitor
Jan 04, 2009 | Frigidaire Kitchen Ranges
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Kitchen Ranges Logo
351 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
