Question about Kitchen Ranges
Oven won't heat after E5F5 error messages
I had my oven on the clean cycle, and the error message E5 F5 come on about 2 hours into the cycle. The oven will not heat now.
  • braduta Apr 20, 2009
    Thanks, the Model number is KEBC147KBL04.  It's a built in single oven.
  • Scott Wiuff
    Scott Wiuff May 11, 2010
    Very common problem with this error. What happens is that the oven gets soooo hot durning a clean cycle that it will slightly melt the plastic keypad making it "think" there is a key being pressed all the time. It's fairly easy to fix. What's the model number? It's usually seen by opening the drawer for pots and pans.
    Scholar:
  • 87 Answers
Unfortunatley on that model the keypad is a bit spendy. It's around $100.00 Here is the link to what part it is. You maybe can search around and get it a little cheaper. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KEBC147KBL04&productCategoryId=0125300&brandId=0593&modelName=BUILT-IN-OVEN---ELECTRIC&diagramPageId=00002&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0410072&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 21, 2009
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Oven won't heat
You might have to unplug it let it set for a hour then plug it back in and it might set it self.
Dec 31, 2012 | KitchenAid Kitchen Ranges
I was using the Self Clean on the oven after a couple of hours I got an error message E1 and F5 - and the oven door is locked. I have no idea what that means or how to get the door open again. I tried...
Hello there and thank you for choosing fixya
Ok before i get into the error codes just a few words here about the self cleaning feature
This the feature that is the most harsh on these ovens due to the extremly high temperatures that is produced then this can and will cause serious problems if not done correctly
I know that people like this feature but i highly suggest that if you are going to use it please try to get the oven as clean as possiable before using this feature this helps the cleaning cycle tremendously ok?
Now for the error code
the e1 error dode is due to the door being locked so to repair this you need to unplug the oven and leave it sit for at least 1 hour this allows for the internal reset feature to reset the oven controle
after the hour is over plug it back in and in 1 to 5 min you may hear a audiable beep or click if so simply press the cancel button and attempt to open the door if so great you should be ok
Now for the bad one
The F5 code is due to the oven control sensing the extreem heat during self cleaning
and sensing that the controls are not controlling the temperature during cleaning which is a bad thing this can and will cause the control board to fail and once again due to the excessive heat
So hopefully once the oven has been unplugged for the hour and reset you should be allright but if not than you do have a bigger problem meaning that your controle board is shot ok?
Please keep me posted on how this is going so i can send you more information on this
Best regards Mike
Feb 18, 2011 | Whirlpool Ovens
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
After I cleaned my oven, I can't get the oven
the heat sensor the controls the oven temp is bad or shorted closed and needs to be changed also the control panel that operates the oven temp could have a bad I C Chip thats went bad and you may need to new control panel
Jan 22, 2010 | Ovens
I was cleaning my GE profile convection oven and after the 3 hour cycle, an error message F 1 started flashing, and the oven started beeping.
We frequently see this symptom due to a failure in the electronic range control (ERC). We repair a lot of these.
- www.fixyourboard.com
Jul 24, 2009 | GE 30" Built-In Single Electric Convection...
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
My oven flased an F9 error....
The solution to this issue is to finish running the self cleaning feature to this oven, Shutting off the oven or opening the door before the self cleaning feature has completely run will send a F9 error from the safety co0ntrol unit feature built in to the system bios of the control circuit, You will need to close the oven and set the option self cleaning to run now. if your error message prevents you from taking these steps you will need to unplug the oven from the wall socket and let it sit for an hour to reset the screen and then run the self cleaning feature all the way trough, it will shut down on its own when the self cleaning cycle has completed
Oct 24, 2008 | Frigidaire FEF366 Electric Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Oven section not working
beaver, the F5-E5 is the code for self clean temp not achieved after 30 minutes. This makes sense since you are having trouble pre-heating your oven on regular bake. I believe your ignitor is not drawing enough amps to open the gas valve all the way. Sometimes these can be erratic, work sometimes, sometimes won't. Your part number for the oven ignitor is 9782065. Catriver..post back.
Apr 06, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
162 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
