Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
2003 Whirlpool Duet Washer clear water pooling in drum after use.
I have a 2003 Whirlpool Duet. Recently clear water is slowing accumulating in the front loader drum after the washing is done for the week. So after being idle for a week, there's a pool of clear water in the drum. Where is the water coming from?
    Sniper:
  • 88 Answers
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Posted on Apr 19, 2009
  • DaniG826 Nov 04, 2010
    This happens to us to and we have the same exact washer! I have to say that I really cannot stand this washing machine. We've had soooo many problems with it. This is just the latest.
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a wet\moldy odor coming from our Whirlpool Duet Front Load Washer, Model WFW9400S. I opened the washer cabinet up and don't see anything like pooling water or a dead animal. I did notice the hose...
with all the environmental changes made to laundry detergents, consumers should use only 1/2 the amount of detergent they previously used. The detergent build up causes a moldy odor in the washer.
Sep 16, 2010 | Whirlpool Washing Machines
Water leaking when machine is off
you need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Feb 08, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load and suds
if you use washer without cloth you will some water and it is normal..use different detergent and use less you will be ok..hope that help you.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
1,194 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
