Washer drains properly after rinse cycle. The
Washer drains properly after rinse cycle. The problem is that the drum does not spin, but the center washboard does spin. What could be wrong?
Please reply. Thank You.
  • 1 more comment
  • jt1969 Apr 19, 2009
    Thanks for your quick response. It is a top loader, Kenmore 80 series washing machine. Is the motor coupler easy to replace? and can I run by any Sears appliance store to pick one up?
    Thanks again.
    James
  • jt1969 Apr 20, 2009
    Thanks a bunch. Your advice was very helpful. I am really impresssed with your quick replies...Excellent!
  • myattal May 21, 2009
    Kenmore Model 80 Washer (top loading) drains properly after rinse cycle. The problem is that the drum does not spin the water out of the clothes. The center agitator assembly does spin, but the drum does not spin. What could be wrong?
    There is also some oil leakage on the bottom of the motor and gear case.
    The unit is 5 years old.
    Thanks
    Sniper:
  • 88 Answers
It would help to know what washing machine we're dealing with.....but I'll just assume it's a standard Kenmore(whirlpool) direct drive top loader. If so, you most likely have a broken motor coupler, which is located between the motor and transmission, that's most likely, although you could have a very bad clutch or tranny too. Check the coupler first. Hope that helps.
Posted on Apr 19, 2009
  • Dan Sharpe
    Dan Sharpe Apr 20, 2009
    Hi James. Yes the motor coupler is not fairly easy to replace, and most any parts supplier should carry it. The part # is 285753A runs around $15-20. I'll give a quick step by step.
    1. Open top console by removing two screws on the lower left and lower right, (may be under a piece of trim plastic, if so these should pop off with a little help from a flat blade screwdriver) Flip console up and back on hinges.
    2. Unhook wire harness for the lid switch (on the top of the cabinet)
    3. Using a flat blade driver, pop out the two gold clips that connect the cabinet to the rear panel. (insert driver down into clip, and lever the screwdriver towards the machine to pop out clips)
    4. The cabinet should now be free. Open lid, grasp the cabinet and tilt forward slightly, then pull off the machine base.
    5. Pop off the two metal clips on the face of the water pump, (no tricks, just flex them off)
    6. Slide pump forward off the motor shaft, and push out of the way. The hoses will make it keep popping back in front of the motor, so I usually just hold it back with my knee.
    7. Remove 2, 1/4" hex head screws from the motor retaining clips (they look just like the pump clips..)
    8. Remove wire harness connections from motor.
    9. With the flat blade again, pop the motor clips off the motor, when releasing the second clip, MAKE SURE you are supporting the weight of the motor, as it will now be free.
    10 Pull out motor. The motor coupler (which is comprised of three separate parts) should be on the motor shaft, tranny shaft, and have a black rubber coupling in-between. If the two plastic drive parts are firmly in place, (try spinning them to make sure they're not stripped on the shaft) and the rubber is not torn at all, you may have a bad transmission. If it is broken, continue by...
    11. Remove old coupler, (may need to pry off of the tranny if that side isn't broken)
    12. Install new coupler by driving (a hammer and a wide socket works, otherwise they do have a tool specifically for couplers) the new plastic and metal centered drive components until flush with drive shafts, (make sure they are FLUSH!! driving a new coupler on too far, or too little can cause them to break quickly).
    13. Make sure all 4 rubber motor grommets are in place. (I didn't mention these, but they are on each corner, back of motor, easy to figure out.
    14. Before re-installing motor, have the bottom clip hooked in the back, or it will be a pain in the **** trying to line it up while you're holding the motor in place. Re-installing the motor is the most irritating part of the job...the coupler parts must all line up just right for the motor to seat properly....you'll see what I mean.
    15. Clip motor back in place, put screws and wire harnesses back.....and basically reverse the process....if you run into issues, re-post and I'll try to help. Good luck!
  • Dan Sharpe
    Ha ha...should read "is" fairly easy to replace. : )
Need to run spin cycle only
No, the instructions comes from a programmed chip in the logic board. You can only do spin only if there is a spin only program. You can drop the hose into a large pail after it has done the main pump out. You could also set up an above ground 'sump' and a sump pump with level switch that cuts the power to the washer in the event that the sump pump fails.
Jan 11, 2018 | GE WCVH6260FWW
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
