Question about Jandy Aqualink Rs4 One Touch Control System Control System
AquaLink RS 4 top lights flashing red bottom lights flash yellow
The top lights are flashing red, the bottom lights are flashing yellow. The pump program still activates and runs as programed but nothing works when I manually press any of the buttons (i.e. pump, spa, spa heat, blower)
    Problem Solver:
  • 5 Answers
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Posted on May 03, 2009
  • 22 Answers
SOURCE: Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Posted on Dec 30, 2008
PartsCenter
  • 125 Answers
SOURCE: Operating instructions for Aqualink RS8 pool/spa combo panel?
AQUALINK GUIDE
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
  • 128 Answers
SOURCE: Jandy Aqualink RS
Disconnect the spa side remote.
Posted on Aug 23, 2009
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
How do I sinc my new jandy pda to existing antenna
make sure the new PDA is the same mhtz as the existing antenna old ones are 800 mhtz new ones are 900 mhtz if same open front of antenna you should see red and green lights flashing make sure red 4 pin plug is connected to both then turn PDA on then turn learn switch on antenna PDA will tell you when to turn switch off on antenna
Jan 30, 2014 | Jandy AQUALINK RS TELELINK KIT
I have aqualink rs 6 model 8227 we had a power outage for about 5 hours when the power came back on it says firmware rev b 13 and establishing communications but it never does. I can turn everything on...
turn system off then try again make sure wire connecting to controller is plugged in and tight if wireless see if antenna is flashing green and red lights inside of case
Nov 03, 2013 | Jandy AquaLink RS2/6 All Button Dual...
I have an Aqualink RS that will not turn the pool's filter pump on either by remote or in service mode
check your jandy valves make sure they are fully open or closed they can lock your system if they are not in full closed or open mode second option is to try to turn jandy valves manually to if they are in spa mode manaully change then to pool mode or if they are in pool mode change them to spa manually on the jandy valve there is a 3 way switch this is where you can turn them manually wt we want is to send the signal back to the main control outside that the valves are in ready mode look in the main control open the door and see if there is a red light that indicates another problem if you can send me where the red light is what the red light label says it will help if you send me the aqualink model #
Oct 06, 2013 | Standard Power Center for Aqualink Rs
SISTEM LOCKED UP ?
go to aqualink take off front top panel turn off see if red 4 pin connector is connected and tight if so turn everything off then back on the controller should see it if not check the cable see if cut if ok then check to see if powersupply is working should have 24 volts to back of board
Sep 23, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
How can I tell if I have a P4, P6 or P8? My PDA is stuck on "waiting." Can I get a replacement antenna?
turn aqualink and PDA off then turn aqualink back on then PDA if same thing happens open the case on the antenna to see if red and green lightsare flashing also check to see if the red 4 pin plug is connected inside the top panel then make sure cable to antenna isnt broken
Jul 08, 2011 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
I have a a rs16 and the screen says 6700 rev c what does that mean
check to see if wiring from aqualink to house isnt cut or damaged also check the red 4 pin connectors 1 inside controller make sure no wire ends touching each other or off then check the one inside the aqualink top panel
Aug 04, 2010 | Jandy AquaLink RS OneTouch RS16 Pool or...
We had an intense thunder storm and lightening the other night. My indoor Aqualink RS8 has a blank screen and is unresponsive. It apparently is not getting any power. The Spalink controller is blinking...
The circuit internally have gone short.There are many other facing this same problem.Some have got this indoor panel dead due to moisture collected on the indoor panels circuit board.The panel is not very strong to handle the humidity effect.It gets short. It has to be replaced. To get any other part and also the indoor panel board please click on the link below http://poolparts2u.com/products.asp?catid=0&scatid=27 ------ Thanks.
Jul 19, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
358 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
