Printer only prints out bottom half of characters in text or misses out lines
My printer only prints out the bottom half of characters in text and misses out lines of print. I have tried all the suggestions on the trouble shoot menu, but with no success.
5 Suggested Answers
BinaryCode
  • 54 Answers
SOURCE: The bottom half of some
First of all what is your printer model and manufacturer? What is your computer's operating system? What program/application are you using when printing?
If you are using windows xp or any Microsoft windows operating system, try to print from notepad to check if this happens as well from a generic windows application.
Click Start > Run > type in the box notepad then press ok
from there type a couple of lines about 10 - 15
example:
test
test
test
test
test
test
test
test
test
test
test
test
test
and check if the issue occurs. If it occurred as well in notepad then it is just a format setting in your application.
Posted on Jun 12, 2008
  • 72 Answers
SOURCE: missing lines and some lines have only half the characters
Solution one: Make sure the paper is appropriate for the print job Using the wrong paper for the print job might cause the colors to be faded or dull.
  1. Many papers have printing and non-printing sides. Make sure to load the paper with the print side facing down.
  2. Make sure the paper type is appropriate for the project. Use HP Premium or HP Advanced Photo paper for the best results.
Solution two: Check estimated ink level Use the following steps to check the ink level.
  1. From HP Solution Center, click Settings , and then click Printer Toolbox . The toolbox appears. NOTE: The toolbox can also be opened from the Print Properties dialog box. In the Print Properties dialog box, select Printing Preferences , click the Features tab, and then click Printer Services .
  2. Click the Estimated Ink Level tab.
Solution three: Check the print settings Use the following steps to check and adjust the print settings for the product.
  1. In the software program from which you are printing, click File , and then click Print .
  2. Make sure the product is selected from the drop-down list, and then click Properties or Preferences .
  3. Click the Features tab, and then select the print quality and paper type settings that match the print job.
  4. Click OK to accept the new settings.
  5. Click Print to send the print job.
Solution four: Check for defects using an extended self-test report Extended self-test reports identify specific print quality issues. Use an extended self-test report to determine what is causing the issue. Step one: Print an extended self-test report Use the following steps to print an extended self-test report.
  1. Press and hold the power button (c01346625.gif ), and then press Cancel .
  2. Release both buttons. The extended self-test report print
Posted on Jun 18, 2009
SOURCE: Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
Posted on Sep 20, 2010
electrotech1
  • 1126 Answers
SOURCE: Printing text, about 20% of
You need to run the the setup software that came with the printer to line it up correctly, or the in cartage needs change.
Posted on Mar 08, 2011
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Printronix T5000r Label Syntax to print " character
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Jul 14, 2008 | Printronix T5000r Label Printer
Missing lines 105SE
If you print too close to the top or bottom of the label, the printer might remove the whole line reather than print part of each character.
If the missing line is somewhere else, the printer might be using a "cached" image. If your software has a feature like "Clear Cache" or "Reimage Label", you could give that a try.
If this doesn't work, let me know the type of software you're using and I'll try again. :-)
May 19, 2008 | Zebra 105Se Thermal Printer
May 08, 2008 | HP PSC 1610v All-in-One Printer
Canon printer double printing and nor lining up top and bottom of letters
I had a similar problem with my 8500. I downloaded the latest driver from Canon, and the problem seems to be fixed.
Feb 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
678 people viewed this question
k24674
