Question about Traxxas Rc Revo Nitro Monster Truck
Troble with clutch
Just revs when u give it throdle. lift off the ground and give it gas tires kinda spine. put it down and it does nt move just revs.
  • Anonymous May 15, 2009
    revo 3.3 motor runs, teeth on cogs are fine wheels accelerate off the ground but stops or barely putts around when placed back on ground???
    Problem Solver:
  • 10 Answers
Its probably the spur gear. I had that happen a lot of times :)
Posted on Jun 02, 2009
Tapping Noise that does not slow with engine RPM ?
If there is an ABS, check for sensor damage. Check for tire tread damage.
Jul 16, 2016 | Cars & Trucks
I have a 2002 suzuki ozark. When I start it up and put it in gear and lift up the back end and give it gas the tires will move. But once I get on it and set down it won't go. Some people say it's the axle...
I recommend a repair manual from filepeep.com if they have it, or MFG website, or manualslib.com
You will learn a lot about your vehicle, and have it the next time you need it.
Mar 28, 2015 | ATVs
Johndeer la140 runs good on full choke but throdle lever does nothing it is not broke the butterfly is moveing in the carb but no gas response runs good on full chock but when i put the choke down ...
WHEN YOU GIVE A CARB CHOKE, IT RESTRICTS AIR FLOW AND GIVING THE ENGINE MORE GAS INSTEAD OF A REQUIRED MIXTURE... USUALLY THIS IS FOR STARTING IN COLD TEMPS. UNTIL THE ENGINE WARMS UP AND YOU RETURN THE CHOKE BACK TO NORMAL. THAT IS ALL THE CHOKE DOES.... IT DOES NOT MAKE THE ENGINE RUN BETTER BECAUSE YOU THINK IT WILL.
Jan 06, 2015 | Garden
My kx 80 (1992) starts and revs up nice but wen put into gear it hardly moves, the heavyer the person trying to ride it the less it goes, when I lift the back wheel off the floor (no pressure on engine)...
Front wheel drag (locked brake).Bad tire air pressure.If not,is carburetor cloged,need to drain (bolt under) or remove to clean.If the motor revs in the gear ,the clutch slip.Could be bad clutch cable tension or need replace clutch/cable.
Oct 22, 2013 | Cars & Trucks
I pull start my 49 cc pocket bike and it starts. I lift the back tire off the ground and give some gas its fine. but when i sit on it and give it gas it dies out?
You most likely have oil spilled on the clutch. OR, the carb needs to be opened by 1/4 of a turn on the set screw on the carb.
Aug 21, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 1989 ford f-150 rwd will go in reverse but will not go forward. I took it to someone and they said it was my clutch. but others are telling me its the synchronizer or transmission. when i put it in...
What do you mean it "kinda budge" when you hold the gas down all let off the clutch? To get better answers ask better questions ...When you put it in drive, you mean put it in first gear? Does the clutch slip when you take off or give it gas while you are driving? Will the transmission shift through all the forward gears?
Jul 17, 2011 | Ford F-150 Cars & Trucks
When i put in gear then let out on clutch the car
sounds like u have a worn out clutch or a faulty pressure plate
Jul 08, 2009 | 1995 Ford Probe
Is it the clutch?
Check the linkage and make sure you havent diconected anything. If the engine revs and kinda crawls real slow it might be the clutch. If it revs and desnt move and all your linkage is good it could be your tranny.
Jan 28, 2009 | 1990 Toyota 4Runner
I have a 2001 dodge 2500 with a cummins,and a 6 speed the truck will move on flat ground,but if you step on gas motor will rev. The truck was parked for about 2 weeks. It has 135,000 miles on it. Is my...
its the clutch,the more you try to make it move and it revs the more damage you can do as your making intence heat by it slipping,a usal tell tale is that it smells like burnt eggs,hope this helps if it does vote me a fix ya
Jul 15, 2008 | 1996 Dodge Ram 2500 Club Cab
Traxxas Rc Revo Nitro Monster Truck Logo
310 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
