Question about eMachines W4620 Notebook
Wireless locks up my keyboard
When I use the factory wireless on my Emachines W4620 the keyboard locks up and I have to reboot.
  • bimdub Apr 20, 2009
    this started several months ago, no new hardware or software added, I did re install the driver for the wireless and have even re installed all operating system software, I have no problem using an external card and I thought the keyboard itself was the problem and have replaced it. basically anytime I try to connect with the internal wireless card I have to completely reboot as the computer just hangs....
  • Jerry May 11, 2010
    When did this problem start happening? Did you install new software or upgrade any device drivers?
Unlock keyboard
Well you may have a bigger problem than a locked keyboard. If you tried to shut down all your programs and reboot, and if you could reboot as someone else to see if it it a locked keyboard. By rebooting the keyboard should auto unlock however if your using a wireless keyboard (check your batteries), and finally on this machine there is a problem with using USB keyboards, try to unplug the USB keyboard then waiting 10 seconds, then plug it into a different USB port, this will reset the keyboard in some cases, but it may be necessary for you to reload the keyboard driver. Okay you say how do you do that without the keyboard? Well if your mouse is working go to START>PROGRAMS>ACCESSORIES>ACCESSIBILITY>ON-SCREEN KEYBOARD and use your mouse to reload the USB keyboard driver and see if that fixes your problem.
Aug 27, 2013 | E-Machines eMachines Desktop PC
Locked/frozen keyboard
Try to find a unlock tab in your wireless keyboard..
Feb 21, 2012 | Logitech Computers & Internet
How to turn w4620 wifi on
You should ensure that you installed all drivers needed. Make sure that in Device Manager ( Right click on My Computer, choose Properties, Hardware Tab and then click Device Manager) there are no exclamation marks in yellow triangle. If there are you need to download and install appropriate LAN drivers for your model. Click on this link to go to download page.
If everything is in order you must press Fn key + F2 to turn on/off wireless adapter. Go to Settings->Network Connections-> select your wireless adapter, right click on it and select View Available wireless Networks, like on the picture below.
I assume that you use Windows XP and sceenshots are from this Operating System.
Dec 17, 2011 | eMachines Computers & Internet
Wireless connection 10 not connected how do i connect
Go to network connections and check if the wireless connection is enable.To enable right click and select enable.
Oct 24, 2010 | eMachines W4620 Notebook
My laptop mouse is not working as if it is locked and using what I know and iti s not much i cannot unlock if that is the problem, help!
Try an external USB mouse. Also refresh your plug and play settings in Device manager through control panel... Try usingthe keyboard shortcuts to do that...
Sep 20, 2010 | eMachines W4620 Notebook
My Emachine laptop model W4620 puts itself into standby before it even loads the sign on screen; it won't even let me strike F2 to enter the BIOS or F10 for setup. I pulled the battery out for a minute...
into the bios and set you all, clock, hdd, DVD and other set when i can then save and exit, if after use and close the unit and is again able to use some time lapsed and this is the same still only one message means that your damaged battery and need to replace its battery, good luck and hopefully I helped you
Jul 26, 2009 | eMachines W4620 Notebook
Keyboard and now monitor work when they want to
Its not problem with key board.
your RAM has become weak to start normal windows
get your RAM replaced
pls rate me
thank you
Feb 14, 2009 | eMachines W4620 Keyboard
Keyboard stopped working due to not having a start up disk
GO INTO CONTROL PANAL AND LOOKING IN THE FOLLOWING FOLDERS
DEVICE MANAGE
NETWORKING AND SHARING
PROBLEMS & REPORTS
YOU WANT ALL GREEN MARK OR NO MARKS AT ALL AND THAT MEANS EVERYTHING IN OKAY.
ROD
Feb 12, 2009 | eMachines W4620 Keyboard
eMachines W4620 Notebook Logo
93 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
