My Brother HL 4070 cdw has a red lcd screen that reads Unusable device. Remove device and then turn power off and back on again. I'm not sure what they mean by remove device. I've tried turning on and off again several times. Any ideas would be greatly appreciated!
  • 1 more comment
  • llvogels Apr 19, 2009
    the toner cartridges are all new as of last week. The printer worked fine last night and the the power went out last night because of a storm and when the power came back, I got the red light.
    Any other ideas?
    Thanks!!!
    my Brother HL 4070 cdw has a red lcd screen that reads Unusable device. Remove device and then turn power off and back on again. I'm not sure what they mean by remove device. I've tried turning on and off again several times.
    The printer worked fine last night and then our power went out overnight and when it came back on, the red light was on.
    yes, I am
    Top Expert:
  • Office Equip... Master
  • 78,919 Answers
Are you trying to print from a wireless port?
Posted on Apr 19, 2009
  • yadayada
    yadayada Apr 19, 2009
    THE PROBLEM IS NOT WITH THE PRINTER BUT THE SOURCE YOU ARE TRYING TO PRINT FROM, CHECK TO MAKE SURE SOFTWARE IS NOT CORRUPTED.
  • 854 Answers
I think you have to check your toner cartridges. Check if there are jammed tiny papers on it. Also check if still filled with toner powder.
Hope this helps
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
Everything appears fine on our 14 month old HL-4070 CDW. However we're still unable to use it. The LCD continues to display "print unable 3B, even after 5 power on-off cycles. Suggestions?...
it could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
May 19, 2011 | Office Equipment & Supplies
"Service Call Error E54"
This error code indicates a fault with the Main Motor. Either it's jammed or unusable. Unplug the printer from the power source, leave it for around 30 minutes, . While it's turned off, remove the cartridges, check for any damage, then put them back in. After tha, then reconnect it to the power and turn it on again. If this still doesn't clear the code from the display then you'll need to see a Brother service agent to have the main motor replaced.
May 02, 2011 | Brother HL 1650 Laser Printer
My brother HL 4070 CDW printer says to change the belt. What do I do?
Ther is a picture in the manual that will show you. It won't insert on here. Send me and email joediaz911@gmail.com, I will send yout the PDF.
Feb 21, 2011 | Office Equipment & Supplies
We have a Brother HL 4070 CDW printer and it's leaving black smudges down every printed page. We have tried vacuming it out, but that did not help the smudges. Any ideas?
Hi there !
this is a commun problem for all the printers, you should clean you printer's inside !
for that printer you habe to check all the way where the paper moves.
Aug 20, 2010 | Brother Office Equipment & Supplies
Brother HL-4070 printing out black whole page. Is this drum problem?
Try swapping the black and the magenta (red) cartridge.
This will not damage the printer and you can see if the toner or the drum is defective.
If you get a red page, drum
Black page, toner cartridge
Mar 26, 2010 | Brother HL-4070CDW Printer
What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Oct 10, 2009 | Brother HL-4070CDW Printer
Will not make connection to wireless brother hl 4070 cdw printer
You might not be on the wireless network or the printer might not be on the wireless netowrk. try connecting to it via a usb cable and see if that works. if so try reconfiguring the settings on it for your wireless network than try again. Also if you have the disk the printer came with you can uninstall the printer put back in the disk, reinstall the printer and it might do all that I am saying automatically.
Sep 12, 2009 | Brother HL-4070CDW Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Reset page counter
Try to unplug your printer and leave it for 1 to 2 hours.
Feb 27, 2008 | Dell 1710n Laser Printer
87 people viewed this question
k24674
jasbo
jasbo
