Don't have video neither audio not even raster. On a TV Toshiba 29as41 model. Year 2002
I experience some sort of video but is interference with my capacitance with my hands lets assume all voltages are ok. you know since i have high voltage on crt. it could probably be the jungle chip What do you think. IN addition there is nothing on a/v input. Same thing What can I do?
    An expert who has answered 500 questions.
  • 556 Answers
As you are saying that some sort of video &interference your problem in tuner section. also check print break or loose contact near tuner& tuner it self. ther is no possibility of jungle chip
Posted on Sep 21, 2007
Posted on Sep 20, 2007
Need to know the size of screws that goes into TV stand for a Toshiba TV model number 40S51u
58 cents each mail order. Not only do they have to be right diameter and thread, also the correct length.
40S51U Toshiba Tv, 40" 1080P Led Lcd Replacement Parts,_40
  1. Cached
Toshiba from Encompass parts & accessories. ... 40S51U Toshiba Tv, 40" 1080P Led Lcd. 40S51U Tv, 40 ... 75024004, Toshiba Screw, Stand, Mac000, 0.77.
Toshiba 40S51U Parts List -
  1. Cached
  2. Similar
List of Spare Parts for Toshiba 40S51U Parts List. 40S51U UNKNOWN ... Toshiba TV Mounting & Installation. 75024004. SCREW, STAND, MAC000. $0.58.
Toshiba TV Stand for 40S51U Complete with Neck and Screws ' eBay > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
TOSHIBA TV STAND FOR 40S51U COMPLETE WITH NECK AND SCREWS in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Parts ' eBay.
Toshiba TV model number 40S51u Google Search
Nov 27, 2016 | Toshiba Televison & Video
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Cant figure out which cables to plug into which holes. only have red,yellow & white cables. have a plug-in for coaxial (orange)-do i need a coaxial cable. have an Orion tv w/a dvd player in it-but it...
rca video out on DVD player toshiba SD3960 av in on tv
yellow is video part of rca
red and white is audio cable part of rca
change input source to AV 1 on tv when wacthing dvd player
for a more detailed explanation a photo of back of dvd player and model number of TV would be helpful
Mar 05, 2018 | Toshiba DVD Player
Lg 37le2r will only show black and white picture. Checked antenna ok.
I've encountered that experience before it needs some technical knowledge because the raster for rgb on your lcd is going bad and the video signal out put cable is mis aligned get someone to re align the raster and your video signal output cable
Jan 09, 2010 | LG 37LE2R 37 in. LCD TV
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Toshiba no video sound is fine
If you can see the menus this means the CRT, high voltage, scan amplifiiers, the output video processor, and CRT drive circuits are working. The fault is most likely in the video section of the input select circuits.
Maybe the Toshiba parts department can supply a service manual for your set. With a signal source, a scope, and a DVM, an experienced technician can troubleshoot your set to locate where the failure is occuring.
I have not serviced this model, but in other models I have found the main input select IC to be defective. In some cases I also found a bad voltage regulator IC that supplies the input section has failed.
Jerry G.
Dec 16, 2008 | Toshiba 36A42 36" TV
Connecting a wii to a toshiba tv model no. 28n33b
I was having exactly the same problem with my toshiba 28N33B until 2 minutes ago! I searched the internet for the solution but only came accross your unanswered question, i hope you've sorted it by now anyway as its been 6 months, but for all those with a similar problem:
You cannot connect your wii to AV OUTLETS only INLETS! At first glance it appears that the 28N33B only has outlets....BUT actually, the AV inlets are (stupidly) hidden behind the speaker to the right of the TV screen (as if you were looking at the screen) - they are separate from all the other ports at the back of the tv.
For anyone looking for Toshiba inlets on other models - my advice would be to take a deep breath, push the telly out from the wall and take a GOOD long look all over the tv for three circular ports coloured red, white and yellow that have the words 'in' or 'inlet' etc printed near to them. You're wasting your time trying to connect the wii via the audio output, it just wont work, no matter how much you re-tune the tv (I know from experience! grr!)
Right, i'm off to play mariokart, hope this helps somebody!
Aug 10, 2008 | Televison & Video
Mitsubishi proyection tv
what model mitsubishi do you have. It has to be video related not deflection or you wouldnt have the menu screen. Do you have snow, retrace lines or black screen? Let me know your model.
Jan 19, 2008 | Televison & Video
Sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
May 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
Top Televison & Video Experts
