Question about HP Pavilion dv2210 Notebook
Hp dv2210us power goes on but just black screen, not booting up
I shut down properly, wasn't having any problems.
Next time I went to boot up,
just get a black screen, it does turn on, power is working.
How do I fix it.
I have Vista Home edition
  • sherry822 Apr 20, 2009
    Thank you for posting a possible solution.
    The problem isn't the screen.
    When I turn on the laptop,
    I hear that it starts for a sec or two,
    but it doesn't boot up!!!!!
    It doesn't get to the point where the screen will light up.
    and
    the F11, etc keys don't do anything either.
    Sherry
  • jaydubj Apr 20, 2009
    I may have the same problem. I did all the memory reseat, AC power supply checks no luck.
    When I power up, the lights all come on and I can hear the HD start, then no action and it just stays lit with no POST. No messages. I don't think it even loaded the BIOS.
    I did pull the HD out and was able to recover my data. The HD and OS on it worked fine on the other laptop.
    john
Replace your cmos battery
Posted on Jun 05, 2009
  • HP Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 20, 2009
  • Chris Hingee
    Chris Hingee Apr 20, 2009
    Try reseating the RAM modules and the boot up the laptop. or Try getting the RAM tested at your friendly computer shop.
    Faulty RAM or seating problems with RAM will cause nil response from the laptop.
Acer aspire 6930 6941 won't boot
won't get the check disc option until it boots up and from your description is is a hard drive problem
take it in for a proper diagnosis
Apr 25, 2017 | Computers & Internet
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
JUST BOUGHT LAPTOP ON 2/22/11 AND TODAY THE SCREEN IS BLACK - G62-407DX AN HP WAS WAITING FOR FARMVILLE TO UPLOAD AND THEN NOTHING.STILL SOUNDS LIKE IT IS RUNNING WHEN SHUT.WHAT COULD THIS BE?
Hold down the power button until the laptop turns off. Wait 5 seconds and turn it on again. Do you see the slash screen as it powers up? Hopefully it will boot into the OS. If it's black the whole time, the video card may be dead. But if you do see a splash screen and it goes black after booting into the OS, you may have caught an infection. Try to boot into safe mode w/ networking and downloading scans to remove a possible infection. I use 3 scanners to remove infections. If the 3 do not clear it, the OS is hosed and needs to be wiped and reloaded. 3 scans: Combofix, SuperAntispyware and Malwarebytes. Good luck.
Mar 11, 2011 | HP Computers & Internet
My screen is black or blank. when I reboot the computer the word "DELL" shows on the screen but then it goes black again. I shut down and rebooted several times with no luck.
boot files missing run a OS repair with OS disc recover and backup your data then do a proper clean OS installation to replace all kernel32 and boot sectors on boot drive
Nov 23, 2010 | Dell Vostro 1500 Notebook
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
Ok..So I've had my tx2500 for a little over a year now (go figure, the warranty's out). After I booted up today, I went online and after a few minutes, the screen went pixel'y' and then went blank. The...
there is something wrong with the video driver or the monitor...If the screen shows something like the devices when it boots up...and only goes blak when it logs to windows...I mean if you see all on the screen until you get to the windows logo..this is a operating system error ..a driver seting or crash...so ...just reinstall it ..or repair the operation system ..cause if it is a setting on video driver or a error ..you can not fix it if you do not see anything ..
if the system boots but you never see a thing on the monitor...not even the writen devices when it first starts..or the bios..this means that the screen or the ribbon of the monitor has a damage on..try to change its position...or so ..but in this case you will need a ribbon for sure ...
Jan 31, 2010 | HP Pavilion tx2500z Notebook
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Usb power issues
Some systems will try to boot up on a usb device such as an IPod or a external hard drive.
It should be unplugged to get it to boot properly.
Oct 31, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP Laptop (with Windows XP) that won't boot up properly.
Check you havent accidently knocked the RAM.
You may have put the the fan in the wrong plug.
e-mail me photos of the mother board or wherever the fan was.
completleywacked@gmail.com
Jun 29, 2008 | Computers & Internet
HP Pavilion dv2210 Notebook Logo
725 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
