Change language to English
Get your car fix right now
MITSUBISHI OUTLANDER SERVICE REPAIR MANUAL 2003 2007 DOWNLOAD
SOURCE: 2004 mitsubishi outlander cooling fans not operating
TAKE A PEEK UNDER THE HOOD IN THE FUSE PANEL FOR THE FUSE AND RELAY FOR THE COOLING FAN. IF THE FUSE IS BLOWN THEN REPLACE IT. IF YOU SUSPECT THE RELAY TO BE BAD THEN TEST IT BY SWAPPING THE FAN RELAY WITH ANOTHER ONE WITH THE SAME PINS ON THE BOTTOM. MAKE SURE IT IS THE SAME SIZE AS WELL. HOPE THIS HELPS.. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
SOURCE: mitsubishi outlander cooling fans not operating
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
SOURCE: Change spark plugs
Remove the intake baffle if equipped (5 10mm screws), then remove the coilpacks/wires (10mm bolts), then remove sparkplugs (use 5/8" socket)
SOURCE: how do you reset change oil light on mitsubishi outlander
Turn the key off.
Press the "Info" button on the left of the dash cluster until your maintenance miles/months screen is displayed.
Press and hold the "info" button until the maintenance screen begins flashing.
Release the "info" button and then push and hold it it for one second.
Your Maintenance intervals should reset to +6 months and +7500 miles since the last interval amount.
Note that if you have not reset it for more than one interval, you may need to do it more than once. If you have not done it for many intervals, you may need to have it reset with the scantool at a dealer, as I have run into a handful of vehicles that the oil change reminder locked up after 3-4 "intervals" were skipped/not reset.
SOURCE: how do i change out my thermostat?
Mitsubishi Outlander 2003-06
Removal & Installation
CAUTION
Wait at least 90 seconds after the negative battery cable is
disconnected to prevent possible deployment of the air bag.
Fig. Exploded view of the air cleaner assembly
Fig. Exploded view of the thermostat mounting
To install:
Install the thermostat so the jiggle valve is facing straight up.
Be careful not to fold or otherwise damage the rubber ring.
Fig. The thermostat-s jiggle valve must be facing up, at the 12
o-clock position during installation
Refer to the fastener tightening specifications shown on the
accompanying illustration.
During installation of the lower radiator hose connection, insert
the hose as far as the projection of the water inlet fitting. Align the
matchmarks on the hose and hose clamp, then connect the hose.
Fig. Insert each hose as far as the projection of the water inlet
fitting. Make sure to align the matchmarks before connecting the hoses
Fill the engine with the proper type and amount of engine coolant.
Hopw helps with this (remember rated this).
