Question about Sony VPL-HS51A / VPL-HS60 Multimedia Projector
Not producing any image
I have VPL-HS51A, when I turn on the projector it comes up normal, but when I connect to any of my video inputs, it does not show any pictures. I can't seem to tell if the its bulb problem or something else. HDMI use to work fine but now not picture at all, If I disconnect the signal I can see the projecor menu fine.
  • skapoor Apr 20, 2009
    I have the second problem, tried all the video inputs and same results, signal seem to be detected but the screen goes dark. I can put my hand in front of the projecter and see a light coming out but its not bright enough, Could it be that bulb need to go into a brighter mode when video singal is added? Before I spend $300 on a bulb I really want to make sure its the bulb and not the projector problem.
  • 10,594 Answers
There are 2 problems in this post, let me know what problem is yours?
In case of first problem, please check fans are running?
and for second problem, as you said you see Menu of projector then its not bulb (lamp) problem and no picture reason could be bad HDMI cable or HDMI port of projector. Please provide analog video signal either DVD player or computer to make sure that projector has picture from other inputs.
Hit "add a comment" button for further query / info.
Thanks.
Posted on Apr 19, 2009
  • Shahid Electronics
    Shahid Electronics Apr 20, 2009
    Thanks for update,
    Lamp in projector has only one mode to provide back light and there is no option of less bright or more bright lamp drive.
    If you see Menu options without any signal input as normal as it was before then it is not lamp issue. It can be problem of video input circuit defect and qualified Sony tech is required as it can not be solved at user level.
    Please contact nearest Sony Service Center for fix.
    Thanks.
I connect new LG Blu -Ray On my Sony Cineza Projector.but only blue colour on the screen ,what is the problem here?
You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
Jul 10, 2012 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I have a big yellow circle in the middle of my projected video. Can this be reset?
no you cannot remove, you have to change the screen inside the monitor. the spot cause burn on the screen picture.
Aug 29, 2011 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I have changed the bulb on my Sony VPL-HS50 video projector and the image is now in black and white. I folloewd the instructions in the manual word for word. The bulb is a Sony genuine part
Is the buld u changed right and in working condition.please clean the optic lens and image CRT board which ( Scanner image board) to see if the issue remaisn or nott
Sep 28, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
The fleshtones of people on the screen is blue
This is not really a solution but when mine does this I switch the input to the projector to another video source and then back again. this usually makes it go away. If you find a better solution I would appreciate hearing it. Thanks.
Jul 06, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Service Manual HS51A
Here is the manual...
https://docs.sony.com/release/VPL-HS51A_HS60.pdf
Mar 23, 2017 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony hs 51 projector problem
open the lamp cover if the power indication comes and check the connectors of cover sensors. also check and service the complete unit by disassembling all the cards & connectors. Lamp life also has to check.
Mar 21, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
check the Lamp unit. If Lamp is ok then check the ballast unit
Mar 10, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Vpl-hs60 projector diagonal is off
I also have this same problem with my HS51A... With nothing on the screen you can see that the panel is physically shifted.
Aug 21, 2007 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
123 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
