Question about Zenith B25A10Z 25" TV
TV Problem I repair alot of TV sets every week in my own shop . I have in a Zenith 25" Color TV , Model B25A10Z . The problem is that everything works on this set but the picture is milky white. By adjusting the contrast nothing happens. Got into service mode and all is fine. I'm getting up there in age. I need some part numbers to replace the bad components . Thanks Art Questell quest128@cox.net
  • Anonymous Dec 26, 2007
    What channel should the TV be set on why using a DVD player; we have a Zenith B25A10Z 25" tv. can hear the DVD playing using the surround sound system, but cannot get a picture.
  • PHILLYAPRIL Apr 11, 2009
    HOW TO HOOK UP ZENITH B25A10Z TV TO DVD PLAYER?
    TV HAS ONLY ONE CABLE CONNECTION IN BACK.
    DO I HOOK UP DVD TO DISH RECEIVER?
    WHAT IS A MODULATOR?
    THANKS,
    PHILLYAPRIL
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Picture is milky white is due to crt.if it is old set. or check video section
Posted on Sep 21, 2007
Are either of these TVs digital? I'm asking about model numbers b25a10z and b27a10z. Thanks.
Neither one is digital..you will need an external digital box to receive digital tv signals
Jan 08, 2011 | Zenith B25A10Z 25" TV
NO POWER WHEN POWER SWITCH IS PUSHED
hi
usaly this problem is cause by the deflection
HV section witch cause the power suply to stop running . I would suggest to contact your local tv repair service but I don't know if it worth it
Sep 28, 2010 | Zenith B25A10Z 25" TV
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
My television lost its sound
its a tuner that is failing on your set it can be replaced
but it might be to costly for a set of its age
and im sure the picture tube is starting to show the tales of age also
not a repair id suggest
Oct 30, 2009 | Zenith B25A10Z 25" TV
Problems with B25A10Z Zenith 25" tv
that model has had a few different problems that cause this. bad micro,bad regulator,bad caps and tuner shorts. suggest you take to the shop for an estimate
Sep 07, 2009 | Zenith B25A10Z 25" TV
My zenith b25a10z tv has no color...can it be fixed?
main ic is bad, as I remember it starts with TA
Jul 08, 2009 | Televison & Video
Zenith television no color except when in the menue screens
The onscreen menu does not rely on the color circuit to produce a color menu.
The most common issues with that symptom are bad color crystal on the main board or a shorted transistor on the main board next to the video jungle IC
Mar 13, 2009 | Zenith B25A10Z 25" TV
Horizontal lines across TV screen Panasonic CT-31SF13U
The problem sounds like a vertical deflection issue form what you describe.
On average they are usually in the simple repair categories. On average they would run in the $50 range if you take it to a reputable repair shop.
There are several possibilities
Bad capacitor (s)
Bad vertical IC
resistor in the power supply to the vertical circuit changing value
Jan 24, 2009 | Zenith B25A10Z 25" TV
Zenith B25A10Z connected to a DVD player via modulator. We use verzon STB. Dvd will not display on TV when turned on. Remote a/v does nothing. Any help?
If you are using a modulator, usually that sends a signal to channel 3 or 4. Select either 3 or 4 and you should get the signal. The modulator should have a switch to enable you to select one of those channels. Selecting the Video input is when the DVD is connected using the audio and video cables (Red/White/Yellow)
Dan
Jul 29, 2008 | Zenith B25A10Z 25" TV
Zenith 25" Color TV - Model A25A23W
Your problem is a bad connection on the CRT socket on the CRT driver board, a bad connection in the RGB driver supply from the video jungle IC or maybe even an intermittant Picture tube. the only way to tell would be to tap on the crt board while the sets playing with a non conductive insterment, and see if it changes. Now there is alot of HIGH VOLTAGE at this spot, so if you have no TV repoair experience Please stay safe and call in a pro to assist you. Good Luck Please dont forget to rate this thread.
Nov 11, 2006 | Zenith A25A23W 25" TV
Zenith B25A10Z 25" TV Logo
167 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
