Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
Direct receiver is not responding to remote
My direct tv receiver is not responding to the remote .
but the remote works the tv
  • 56 Answers
If you go to: http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.450
it has different remote codes. you would have to select "satellite setop box" also you need the model # of the receiver which can be found (normally) behind a door on the front panel of the receiver on a sticker (where the access card and reset button are) if its not a directv receiver, (hughes, etc) then it would probably be on the back of the receiver you would see a sticker with the model # of this receiver.
the first code should be 00001 follow the instructions on how to program on that website.
Posted on Apr 20, 2009
  • Kenneth Blackstock Apr 17, 2014
    what makes a dvr not responding to remote directv
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I have a Motorola DCT6416 PVR. Dog layed on remote and de-programmed. I can't find the program code to fix my remote control.
are you sure its not something simple like the remote is in the wrong mode. what lights up on the remote when you push buttons?
what isn't working? the cable box not responding? the tv not responding? nothing?
RCN's motorola code is 002 (actually i think the new remotes may be different), TV code could be anything.
FYI: battery cover on remote sometimes has directions for code search
hope something here helped
Apr 19, 2011 | Motorola Televison & Video
Strange problem with a Dish 2800 receiver: during the daytime, it works fine. Starting about 5:00 or 6:00 PM, it starts responding poorly to the remote. That remote works fine on other receivers in the...
Hey there! This is Becki Barned, with Dish Network customer service! The problem that you may be having is with interference with the remote. Depending on how much light is shining directly on the receiver, such from a lamp in the evening, or the sunset, this can interfere with the remote responding to the receiver. If you have glass in front of your receiver, that can cause it too. Try to remove all objects or lights from the front of the receiver, and it should work fine!
Aug 26, 2010 | DISH Network DISH-2800 DTV Receiver
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
I have a yamaha receiver that turns on and off with any button for my remote for the direct tv. any advice.
Best bet would be to call the company that installed the direct tv system and ask them if there is any way to run the system with another code from the remote than it had now. You probably won't be the first with this problem so they will probably already have a solution ready. Only problem with that being that if both the receiver and direct tv system work on RF frequencies instead of IR lights like normal TV remotes, then it will require to use a different frequency to operate and will require a technician to come to your home and they might charge for that. If all else fails you can always try to isolate the optical eye of the receiver if it does work with IR lights to blind it from the remote. But doing so will also blind it from its own remote and you might have to resolve to operating the receiver by hand. If it woks in RF, then if your lucky enough taking the antenna for the remote off of the receiver will shorten its range and might just be enough for it not to respond to the direct tv remote. It will still work with it's own remote though, but having no antenna you will need to get closer to the receiver.
Jul 08, 2009 | Yamaha Audio Players & Recorders
Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
Can't find the remote control codes
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series. ALSO try code 10835.
Sep 06, 2008 | Televison & Video
Volume not responding on Direct TV remote
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD221RD.pdf
See Page 15.
Worked like a charm! Good luck!
Jan 31, 2008 | RCA DIRECTV Satellite Remote Control
Emerson Jumbo Universal Remote won't program Direct TV receiver.
panasonic t.v. codes are
003, 054, 055, 062, 070, 148, 170, 171
Direct t.v. codes are
200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217
Jan 08, 2008 | Televison & Video
My TV won't respond to the remote control
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
Sep 03, 2007 | Philips PR0930X 9 in. Portable Television
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
5,663 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
