Does it need the battery to run while plugged to the a/c ( wall)
Even though plugged in it seems to run out of power and turns off
  • rcunningh928 Apr 19, 2009
    Just bought a new powercord . It will not run without the battery in the laptop.
    Hey what do you think ??? Ive taken out the battery and it wont turn on ??
  • 37 Answers
I'm assuming you have a laptop. check connections to the power cord.
laptops do NOT need a battery in to run.
if it won't start without the battery in it, your power supply has issues. possibly a kink in the cable, possibly just burnt out.
Posted on Apr 19, 2009
  • Aryeh Levy Apr 20, 2009
    Dunno why I got a 2... anyway
    by power cord do you mean the cord to the power supply or the entire plug to laptop piece....
    if not you could have a broken connection on your power connection - solder can chip and crack.
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
My printer wont turn on even though it's connected to direct power supply. Why wont it turn on?
Generally the troubleshooting steps are:
  1. disconnect the printer from the data cable to the computer and plug directly into a wall outlet bypassing any power strips/battery backup and then see if it will power on. If it does, run a self test and see if it prints.
  2. If still in a no power state, unplug the power adapter from the wall and the printer, wait 5 minutes, then plug into wall, then in to printer and try to power on again.
  3. If still no power and under warranty, contact manufacturer for repairs/replacement.
  4. If not under warranty and an Inkjet, almost assured it will be less expensive to replace than to repair:
My current favorite: http://www.walmart.com/ip/HP-Deskjet-3050-All-In-One-Printer/15075186
Jul 10, 2011 | Lexmark Office Equipment & Supplies
My Dell laptop will not switch on even though fully charged
If you can't turn it on with just the battery connected, try plugging it in also. If it still doesn't turn on, disconnect it and remove the battery. Wait several minutes and put the battery back in and plug the power supply back in.
Now try it. If it works, unplug the power supply and see if it stays on. If not, the battery is dead.
Oh--another thing to try--take the battery out and try running it just plugged into the wall.
If none of these work, you have a motherboard issue.
var fctb_tool=null; function FCTB_Init_8a85a27cc718468fa4a27288d7aa61cc(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_89c0ad1aa1454e269e37bbc1669c67eb(t) { fctb_tool=t; start(fctb_tool); }
Dec 29, 2010 | Dell (002TR) Motherboard
TOSHIBA U400 running VISTA; When I am on battery and get low i plug in so i can continue working but even though the lighted icons on the laptop show it is plugged in and charging and the toolbar icons...
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Apr 24, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
It will not turn on even though it's plugged in
Well, if your computer does not even turn on, or run through the POST test, then you may have a power fault somewhere inside you computer. There really isn't a reset for it. If its the V6500 (laptop), then try removing the battery, if the computer allows, and starting the computer with AC. If it works, then you know its your battery. If not, then you have bigger problems (as stated earlier). Here is a site with some steps to follow to help determine your specific problem, if it is a battery/AC adapter issue.
Mar 02, 2010 | Computers & Internet
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
Computer won't turn on though plugged into wall
Make sure you have power at the outlet. Take power cord off and remove battery. Hold power button down for 10 seconds, plug just power cord. Try to turn on. If dose not work , you have a hardware issue.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Battery Depleted
Are you able to run the laptop with no battery installed but the power cable plugged in? If not, there's a good chance your power jack on your laptop has broken (or almost broken) and will need to be replaced or the power adapter isn't working.
If it does run, your battery is probably bad and can't take any charge. It will need to be replaced.
Apr 10, 2008 | HP Pavilion dv1000 Notebook
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Dec 16, 2007 | Canon ZR400 Mini DV Digital Camcorder
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
