Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Lens spring/s A couple of weeks ago I got the dreaded lens error. In my case it was probably due to sand. I took the camera apart and when I came to disassembling the lens - the spring popped and fell on the floor - as I picked it up it caught in the carpet and I ruined it. So my question is where do I get a replacement without sending the whole camera back to Canon? Also is there 2 springs, as there seems to be hooks for 2?
I had teh same question, I'm trying to repair mine atteh moment and there is only one spring. still trying to get teh lens back together propoerly, managed to rip a cable track so have to get another anyway... spewing..
Posted on Oct 05, 2007
SOURCE:
Lens error - clicking/gravelly sound when opening and closing and zooming. Comes up with 'lens error' on camera
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Aug 18, 2010 | Canon PowerShot A480 Digital Camera
Dreaded E18 error lens will not retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error, the lens is stuck and the camera would not operate.
Jan 04, 2010 | Canon PowerShot S3 IS Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Casio exilim ex-z60 lens error retry power
the same thing happened to me &nd i took it apart &nd nothing happened .
Jul 12, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Problem with the lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 25, 2009 | Cameras
Hi there .. I have had this camera for a couple of years now and it as been fabulous however a couple of weeks ago, i went to turn it on and it made a churning noise, and then reported on its blank...
Apr 17, 2009 | Canon IXUS 860 IS Digital Camera
Darkened Images
Sounds as if your diaphragm may be sticking due to either the camera or the lens. Look at the back of the lens and work the small tab with the aperture ring set to f32 (or 22). See if the tab moves smoothly but with resistance from a spring, or if it sticks or moves roughly. If it does this with other lenses too, another possibility is the aperture lever on the camera. Mount the lens and set it for f22 or so and use your depth of field preview to see if the lens is stopping down smoothly. In either case it may need professional repair.
Nov 02, 2007 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Dismantled after "Zoom Error" and now it won't power up.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 27, 2007 | Fuji FinePix S304 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
