Question about Dell OptiPlex SX270 PC Desktop
Computer does not start. Replaced motherboard and RAM. Hear the fan when I start the computer
I have a Dell Optiplex SX270 which stopped working. I replaced the motherboard with a new one and have also replaced the memory (RAM). But there seems to be no change. When I press the start button, I see yellow/orange light on the motherboard and the green light under the start button. I also hear the fan running. But I don't see anything on the monitor and if I click on a button on the monitor, I get the message "check signal cable". Please help.
  • prajai15 Apr 20, 2009
    I have used three different monitors (Dell Monitor that I got, a new LCD that I had bought recently and an older CRT that I have a server running with). I have also replaced the DVI to VGA adapter that connects monitor to PC. I still have no luck. All monitors go to power save mode. One thing that I did notice was that with Dell LCD monitor, if I connect the monitor goes to power save mode, but if I disconnected the monitor cable from the DVI to VGA adapter, the monitor wakes up with a self test screen. Any help is appreciated.
    how do I check if power supply is working? I don't have another optiplex SX270 to test it against. Neither do I have another power supply. This is an external power supply and the orange/yellow light on the motherboard is actually solid when I connect power supply to computer.
  • 272 Answers
The monitor has the problem. the message only means, the connector is not properly connected on motherboared . please try another monitor.
I am sure about this...monitor or the connector ( as u have changed the motherboard) of the monitor has the problem.
Posted on Apr 19, 2009
  • Fixer Apr 20, 2009
    You have changed almost everything. Usually the problem of Ram and gfx card prevents showning up on monitor.on other cases, your pc should not start running. Can you please make sure, power supply is ok?
    this is an unusual condition, i think
Dell optiplex sx270: loud, steady noise like an alarm a few seconds after I turn on the PC
You can check the meanings of the error beep codes HERE. Every beep code means something different. The bad thing is that the code I think you are speaking of is a fatal error.
Good luck
Aug 26, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Optiplex SX270 LED light code
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
May 01, 2010 | Dell OptiPlex SX270 PC Desktop
PC won't start up
Hi There,
I would suggest you test it with another Power Supply, or check you Ram, Let me know if successfull or not?
Cheers
Techmor
May 27, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
I have a dell sx270 desktop when I plug it in only the fan works
First of all, keep the front button pressed until the system shuts off. It might be one of several causes:
1) Memory module damaged (or dirty)
2) The processor is damaged, or
3) The motherboard parted off.
Remove the memory modules and test them one by one. Or if you can test them in another PC (assuming both PCs use the same kind of modules).
May 01, 2009 | Dell OptiPlex SX270 PC Desktop
Hou do i reset bios on a dell optiplex sx270
  1. Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Apr 02, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
Orange led on mother board
You have a hardware failure, most likely memory or video card. The first thing I would try is open the case and blow the dust out of it, especially dust on the memory modules and anywhere on the motherboard. Then try to boot the computer again. If that does not work I would start removing components one at a time and testing them.
Mar 16, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
My computer will not power on
brand and model of the computer would be good.... as well there is a switch on the back of the computer on the power supply. toggle it to the other position and try again
Robert
Sep 08, 2008 | Dell OptiPlex SX270 PC Desktop
Motherboard
manual for mainboard GA-71XE4
Jun 20, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
Dell OptiPlex SX270 PC Desktop Logo
472 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
