Question about Acer Aspire 5100 Notebook
Internet my internet has is not working. If i go to my network connections, then click on my connection it has like a hand under the two computers. then is says(not connected,fire walled)PLEASE HELP ME
    President:
  • 2,961 Answers
Right click on it and select connect as it may be looking for a network. If you have the icon in your task bar right click on it and select view network connections and then a list of connections in your vacinity will show, click on yours and see if it connects. Although the hand underneath the icon doesnt make sense as that refers to a shared item normally shown under my computer or a folder, not the network connection.
Posted on Sep 20, 2007
SOURCE:
I had a computer problem and now my netgear won't work. When I got my desktop up and running again and now we can't connect to the internet on our laptop, wirelessly. For some reason the Netgear wireless...
Please follow the below steps to configure settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
If your laptop has Windows XP then perform the below task:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
If your laptop has Windows Vista then perform the below task:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
If your laptop has Windows 7 then perform the below task:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
Hope the above steps allow you to resolve the issue. If you need any further help then revert back so that we can assist you further.
Regards
Anand
Apr 12, 2010 | NetGear WGR614 Wireless Router
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Internet connection
Dear Sir,
plz folow this step
For XP-> go to your control panel -> click under network connection -> right click on Local Area Connection and disable it -> right click again to enable it back.
For Vista-> go to your network and sharing center-> click under manage network connection located on the left hand side -> right click on Local Area Connection and disable it -> right click again to enable it back
if the probelm not solved then give IP address manualy for internet above same processdure
Apr 08, 2010 | Acer Aspire One PC Notebook
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
We are on Starband Satellite internet. Have windows programs , both vista and xp. We have the linksys G wireless internet system. How do we install it ?? So far, when we put it in, nothing works. No...
Yes you can but it is not as easy as using a router with a cable or dsl connection.
The 360 modem requires the Mission Control software in order to run properly so you can't just hook it straight to a router.
What you need to do is use an old computer to sit in the corner and act as a router(kind of) and then connect it to a real router.
When your finished you won't even need a monitor for it. You will need either two network cards in it or 1 network card and a usb port to hook it up to the 360 modem. Make sure network cards are also working correctly. Install the starband mission control software and make sure it is working correctly.
In Winxp go to network connections and right click on the one hooked to the starband modem and click properties. Now click on the advanced tab and check "Allow other network users to connect through this computers Internet connection.
You can plug the other network cable straight into a switch and this computer will hand out ip addresses through ICS(Internet connection sharing) built into winxp.
You can also get a wireless router and change the ip address of it to match the range that ics is handing out and disable the dhcp server so that you don't have two things handing out ip addresses.
If you use the web accelerator you will have to put it in the browser of each computer that you will be using (in the browser under proxy). It will be something like 192.168.0.1:9877.
Also make sure your running a firewall on your little router-computer. If the computer is running winxp professional you can take the monitor off and use remote desktop connection to check on things or to control it. Or search the Internet for VNC.
from____cajun101...yahoo
hope this helps you get more confused :)
Oct 24, 2009 | Linksys Wireless-G Broadband Router
Cannot connect to internet after full restore of my laptop using netgear WNR834M router. tried going to netgear login. don't know what to do there other computers on wireless working .
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
If on the laptop u have windows XP then perform the steps below:
8. Go to the 'Wireless Networks' tab .
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For VISTA on the laptop perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Aug 04, 2009 | NetGear RANGEMAX WNR834M Router...
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Acer Aspire 5100 Notebook Logo
110 people viewed this question
Ekse
Alun Cox
