Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
19.5 model 917270821 won't start - not getting fuel. flows freely from where filter is and past but next section of tube dry- and clear what pulls fuel thru? it's getting past - but nothing in line section that goes to carb area.
  • 246 Answers
Hello mtcrew:
>>According to the Sear Site, this Unit has a Briggs and Straton Model 42E707-2631-E1 Engine Powering it.
>>You can View a Breakdown/IPL of this Engine at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM and Enter the Model (5 or 6 Digits) and Type Numbers (first 4 digits Only). Example: 42E707-2631. Then Double Click on the Model in the Results Area. Select Sectional Index. Now you can Select the Section of the Engine you Wish to View.
>>There is a Fuel Pump that is a Part of the Carburetor.
>>In the Breakdown of the Carburetor at the Site Addy I Provided the Fuel Pump Diaphragm is # 394A.
>>I Suggest you Lightly Presurize the Gas Tank and Force Gas to the Pump.
>>Sometimes the Pump has to be Primed before it will Start Pumping Properly.
>>Replace ALL the Spring Style Hose Clamps with the Screw Style Hose Clamps. The Spring Style Clamps Weaken and will Allow a Vacuum Leak to the Fuel Pump and the Pump will Not Operate Correctly.
Respectfully
John
Posted on Apr 21, 2009
How do I remove the gas tank out of a 2006 Ford 500 no one knows
SECTION 310-01: Fuel Tank and Lines 2006 Freestyle/Five Hundred/Montego Workshop Manual REMOVAL AND INSTALLATION
All vehicles
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
  1. Release the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Drain the fuel tank. For additional information, refer to Section 310-00 .
All wheel drive vehicles
  1. Remove the rear driveshaft. For additional information, refer to Section 205-00 .
All vehicles
  1. Remove the muffler. For additional information, refer to Section 309-00 .
  1. Disconnect the fuel vapor control tube assembly valve-to-fuel vapor tube quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel supply tube-to-fuel filter quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel vapor tube-to-fuel vapor control tube assembly valve quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel tank wiring harness electrical connector at the rear of the fuel tank.
  1. Release the clamp and remove the fuel tank filler hose from the fuel tank.
  1. Place a suitable lifting device under the fuel tank.
  1. Remove the 2 front fuel tank strap bolts.
    • To install, tighten to 35 Nm (26 lb-ft).
  1. NOTE: Do not bend the fuel tank straps.
    Loosen the 2 rear fuel tank strap bolts and position the 2 fuel tank straps aside.
  1. Lower the fuel tank enough to move forward, clear of the fuel straps then complete the lowering procedure.
  1. To install, reverse the removal procedure.
Procedure revision date: 08/19/2009
May 03, 2016 | Ford Cars & Trucks
TC55DA tractor. Why is there water in bowl and little or no fuel pumping from injector?
The system needs bleeding but in most tanks there is jelly from stale fuel which may have blocked the pipe, especially when the tank has run dry. Remove fuel filter, is there fuel freely flowing from the tank pipe? If not blow back through the pipe into the tank, is it flowing freely now? Replace the fuel fitler. All fuel tanks have a build up of water from condensation over time, it's harmless but of course will contaminate the fuel. I would always replace the filter once you've run out of fuel. Bleed the system, fuel filter, glass bowl if fitted, pump bleed screws then up to the injectors one by one. If there is an airlock earlier in the system, fuel will be held back. The fuel pump is the most important part to bleed. If it doesn't fire up right away, use a little easy start to get it running and this will pull the fuel through.
Sep 02, 2015 | Garden
Get my 1980 Suzuki GS8750L to run when I turn throttle..it starts n runs fine otherwise..idles wonderful
Is the fuel flowing freely? Definetly a fuel/air starvation issue. Something really simple such as blocked tank filter ,even a blocked exhaust,next doors cat isn't stuck up the pie nis it??
Oct 05, 2014 | Motorcycles
Honda Lawn mower, won't pull gas
hi
remove your center jet could be same one that holds your bowl tight under the bowl and look for a small plugged up hole clear it open,,,,,, and it should **** fuel up and start and remain running
joe
Oct 01, 2012 | Garden
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
Stihl, FS81 trimmer won't start
Well I would go with fuel supply. But did you pull the hose off the carb inlet and see if fuel flows freely from it? You do have a filter screen inside the fuel tank on most makes and it can get plugged, if it is plugged blow compressed air back into the tank to clean it and then dump and flush the tank..
May 17, 2012 | Garden
I have a 2001 Suzuki Maurader 250 - we bought it used and cannot get it to start - we have had it running but the next day it will not start. |We have changed the oil, plugs, cleaned the carb and now it...
Drain the carb with the gas valve on the tank turned off. Now turn the valve back on and see if gas again begins to flow out of the float bowl. If no gas drains with the valve open then remove the fuel line at the carb and check to see that fuel flows freely through the fuel line. If gas flows freely out of the fuel line then the float needle is stuck closed or trash is plugging up the needle jet assembly. If so, remove the float bowl and free up the needle. Use spray carb cleaner and the little "straw" that comes with the can to direct the spray into the float needle fitting. Fuel should flow when the float is down and stop flowing when the float is lifted. Pull a spark plug and ground the metal against the cylinder. Check for spark. If there is no spark then check the operation of the kill switch on the side stand and the handlebar. Use a multimeter to check the switches. Get fresh gas and install an in-line fuel filter to keep any trash out of the carb. Clean the air filter. Please rate my answer. Thanks.
Apr 03, 2011 | 2001 Suzuki GZ 250 Marauder
Ran out of gas, put gas in it, changed fuel filter and I can hear the fuel pump kick on, but it still won,t start.
Possible that there is an AIR LOCK and so you will need to bleed off the air within for the fuel to flow into the pump. So remove the fuel line and allow fuel to flow or blow into the fuel tank.( must **** out the fuel )
once the fuel comes over the pump will hold on.
Next time make sure that the tank does not run dry.
Dec 31, 2010 | 2001 Pontiac Sunfire
42 inch Craftsman carburator not getting any gas. You can spray quick start and will will fire. Does gas from tank gravity feed to filter?
gas tank gravity feeds fuel to the carb. if you pull the fuel line from the carb, fuel should flow out of the tube. if it does not, then either the vent hole on the gas cap is plugged or there are contaminents at the bottom of the gas tank preventing fuel from flowing into the fuel line.
Dec 14, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
830 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
