Question about Clarion M5675-RET CD Player
Clarion M5675 won't turn on
Clarion M5675 is installed on my boat which has been out of the water and stored under cover for the winter - very dry environment.
While preparing the boat to go in the water this spring I tried all the electrical powered accessories on the boat and the radio was the only one that would not work.
When power button is pressed nothing happens.
Checked power source and fuses to radio - all Ok, 12 volts are present on radio side of fuses going into the unit.
Took off face plate ( detahable control panel) and reinstalled several times.
Also tried pushing in reset button behind detachable control panel.
Nothing worked - could the problem be in the power switch itself?
Should I get a replacement detachable control panel?
  • 3 Answers
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
I just got a new boat this summer and I live in Seattle, where I will use my boat year round. I have been told that I should winterize the motor so it doesn't freeze in the lower temperatures. What should...
I used to live in the Chicago area. We definitely had winter (below zero).I went thru extensive winterization for the inboards and stern drives. I fogged outboards and put Sta-bil in the gas. I also ran the gas out of the carbs or drained them but the boats would sit unused for 6 months. Does the boat stay in the water? If on a trailer, lower the motor so it is in the run (trim down) and the water will run out. If you tilt it up after this for storage, cover the gear case as it can fill with rain water and freeze.
Jul 24, 2014 | Light Outboard Motor Boat Bass Fishing...
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
In my boat is a Clarion CMD6 head unit with two rear CMQ1620R speakers, it distorts at medium to high volume, you cant turn it up load when going.Wishing to put two new speakers in the front, cannot cut...
Best bet is to take your boat to a qualified Marine Audio dealer (generally not a boat repair shop or marina), or to a good quality Car audio store that is insured to work on boats (separete insurance usually).
When it comes to boats, you need lots of power and speakers.
First thing to do is make sure what you have is properly installed. Then determine what is "distorting" .. is it too much base, purely volume or what.
Most boats we do (wakeboard style and river boats) we do: 40-75 watts RMS per speaker 4-6 speakers in boat 1 10" or 12" sub with 200-300 watts RMS Tower speaker if requested with 75-125 Watts RMS per speaker
Feb 06, 2011 | Clarion Car Audio & Video
I have a Clarion M5675RET in my boat and it won't turn on after being stored all winter. I'm pretty sure its getting power. Is there a manual explaining the connectors& pins in the back? Is there a...
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
take the face off and there is a pin hole get a pin and depress the button see how u go
pls rate people arnt rating hope this helps
Jul 13, 2010 | Clarion M5675-RET CD Player
Removing grill covers of Clarion 6.5" marine speakers
Put a piece of cardboard next to the speaker to protect your boats finish. Then use a flat bladed screw driver to gently pry the grill covers off. you may need to work your way around the perimeter, with a little bit of effort it will pop off. There will be 4 screws under the grills holding the speaker to the boat which are easy to remove.
May 04, 2010 | Clarion Coaxial Coaxial Car Speaker
The stereo is Clarion M5675 older.
yes... you may have to push that same number again when it flashes though. its been a while since i played with that radio
Mar 29, 2009 | Clarion M5675-RET CD Player
No power
Do you have the manual. I have the same model installed on my BMW 1100RT motorcycle and it requires two power hookups. One senses the ignition is turned on and the other is the power up from power source. If the ignition power wire isn't connected, the unit will not powerup. You can however, connect both of these power wires to bypass the ignition switch. This ignition switch is used so you don't kill your batter by accident. I'm sure that wouldn't be good on a boat. Good luck!
Mar 03, 2009 | Car Audio & Video
CLARION MARINE SPEAKER
Most covers hold themselves in place. You may have to pry it a little harder. It could have rust around the edges and will not come out easy.
Aug 22, 2008 | Boating
Need Help !
Judging from the symptoms, I'd guess that "ACCS" means "accessory". All CD players have a constant power input and an accessory power input. There has to be voltage on both wires for the CD player to work, although the clock and CD load/eject functions will work with just a constant power connection. My guess is that there's an accessory switch somewhere in the boat that needs to be turned on for the CD player to activate. Failing that, if you can get the the wiring on the back of the CD player, the red wire is the accessory power wire. You can simply cut it and re-connect it to the same source as the yellow constant power wire. This will allow the CD player to work independently of any outside switches.
Jul 10, 2007 | Clarion M5675-RET CD Player
Clarion M5675-RET CD Player Logo
919 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
