Question about Electrical Supplies
Honda em2500 starts, runs 1 minute, quits and will not restart
Em2500 honda ... my generator usually starts by the second pull. we had big snow yesterday. it misbehaved when I pulled it out onto the porch. It started on the second pull, then it sputtered and ran for about 2 minutes then quit and would not restart. I gave up and let it sit for 3 hours. when I returned, I fired it up on the second pull, left it partially choked until it warmed up, then put it into full run mode. it worked beautifully for 12 hours. shut it off overnight. next morning, same thing. I closed the choke and it fired up on the second pull, it ran for about 30 seconds to warm up, then it quit and have not been able to restart since. fuel is new and it was serviced last fall. what do you suggest? thanks. LH Colorado
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
Posted on Apr 29, 2009
  • 744 Answers
Does your unit have a low oil pressure cutoff?
These smaller gen sets will burn some oil in extended use, especially under a moderate to heavy load. Check the oil level.
Also, check the high and low speed speed carb jet setting (some units may not have a low speed jet), make sure the fuel is ok, and take a look at the sediment screen in the fuel tank. Lastly, if it keeps acting up, disassemble the carb and float bowl and look for problems in the float, needle valve, and needle valve seat. These small engines vibrate and things can go out of whack.
Posted on Apr 21, 2009
How can I diagnose the problem with the indicator light flashing after supplying power for only a minute?
a problem has arisen in the converter panel /board
take it in for a proper diagnosis and repair
Apr 20, 2016 | Honda EB3000C CYCLOCONVERTER Generator -...
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
I have an em3500 honda generator which starts stalling out after 1/2 hour to an hour like it is running out of gas and then shuts off. I can restart it and it will run for 1/2 hour to hour and do the same...
Recheck for spark when it stalls. If you have lost spark I would say a heat damaged coil.
You should also drain and inspect the carb bowl. You may have low fuel flow which limits full throttle operation to 30 minutes or less. When it dies you are just refilling the bowl for the next run.
Good luck and be careful!
Aug 10, 2010 | Honda 3000 Watt Portable Generator
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
I have a honda generator em2500x voltage problem
My E2500 did this. Turned out to be dirt in the brush holders causing the
brushes to have less pressure in the slip rings. Stopping and restarting
joggled the brushes to make better contact until they wore down again.
Pull your brushes and make sure they slide easily in your holders. Also
you may need to replace them if they are worn too much or clean the
slip rings. Good luck. Doing your own repairs is fun.... especially when
they work.
Jul 27, 2009 | Electrical Supplies
My 7.75 Hp snowblower starts, runs 15 minutes, then stops.
check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Jan 29, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Electrical Supplies Logo
785 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
