Cleaning I need to clean the front of the air conditioner and I can not take that little face olate off how do i do that.
    Novelist:
  • 75 Answers
Hi, There are so many different types of units that it is really hard to answer this question. If you have the manual it may help. The filter can probably be removed without taking the face plate off. The filter may be all that needs cleaned. It usually slides up out of the face plate. Clean it with soap and water and replace it. The face plate its self may have some screws holding it on. Many of them just come off after removing the screws. Others pop off from the bottom first, some from the top. If this is a unit still being sold, You could go to the store and have someone there show you how to take it off. Home Depot usually have some helpful people that may just show you how a few of them come off. That may help you to understand more about what you need to do to get it off. You could ask a friend, relative or neighbor to give you a hand. Usually two minds work better than one on such maters. I hope I have helped you. kstfas
Posted on Sep 20, 2007
SOURCE:
How to remove face cover for cleaning
The front covers are usually snapped into place. Grab at top and bottom and pull. It should pop right off. GOOD LUCK FRIEND.
Sep 15, 2014 | Whirlpool ACC184PS Thru-Wall/Window Air...
Why is my ac window unit not cooling as well as it use to? .
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# FAC105P1A, is not cooling as well as it used to. Please try cleaning the air filter as well as the cabinet.
Air Filter Cleaning:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
• Push the vent handle to the Vent Closed position (where applicable).
• Open the front panel.
• Grasp the filter by the center and pull up and out.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
Cabinet Cleaning:
• Be sure to unplug the air conditioner to prevent shock or fire hazard. The cabinet and front may be dusted with an oil-free cloth or washed with a cloth dampened in a solution of warm water and mild liquid dishwashing detergent. Rinse thoroughly and wipe dry.
• Never use harsh cleaners, wax or polish on the cabinet front.
• Be sure to wring excess water from the cloth before wiping around the controls. Excess water in or around the controls may cause damage to the air conditioner.
• Plug in air conditioner.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FAC105P1A Window Air...
The air that comes out of the vent stinks. How do i fix this? Do i need replacement parts? Please help...
No you probably don't need any parts just a thourough cleaning of the water tray and evaperator coils and the air filters. they make a product you can get at hardware stores for cleaning the coils and a mild detergent and water with a little baking soda should clean the rest. you will need to dissasemble the unit for the cleaning so as not to miss anything. Over time water builds up deposits and they can grow algea's and molds that cause these smells. You might however need to replace the filters if yours are not washable or are damaged beyond cleaning. Refer to your manual on the cleaning process.
Sep 09, 2011 | Danby Portable Air Conditioner
How do you get the filter alert light to go out?
Usually taking the filter out and cleaning it will reset the filter light if this has been done try unplugging the unit for a few minutes and than plugging it back in
Jul 23, 2011 | Friedrich QuietMaster Heavy Duty SL33J30...
I turn off the a/c but the compressor don`t stop it continuing running the only way to stop the compressor is when I unplugged the unit, so can you help me to know what part need to be replace. thank you
The Master ON/OFF Switch either needs cleaning or replacing. I'd try cleaning it first with electrical contact cleaner. Be sure the ON/Off Switch is in the OFF position, before you unplug the unit, to take the face off to clean the switch & it's contacts.
Hope this helped you. Please let me know. Thanks.
Jun 11, 2011 | Frigidaire FAC126P1 wall/window Air...
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
Cold air not blowing out evenly across the vent, mediumn cool on
Please check that the directional louvers are not set on one side. Also clean the filter screen in the front. It should be free from dust and pollen. Remove the front cover and switch on the air conditioner. Check the flow of air. If it is one sided then there is problem with your blower. For that you may have to call a technician.
Jun 01, 2010 | Heating & Cooling
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
Remove Front panel for cleaning. Frigidaire FAC127P1A4 Air conditioner
Need a part number for a "drain pipe" that would fit in the bottom of the drain pan so I can redirect condensate for Frigidaire Air Conditioner, model FAS257Q2A
May 11, 2009 | Heating & Cooling
Heating & Cooling Logo
254 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
