Question about Zanussi 24 in. ZSF6160 Free-standing Dishwasher
Water not heating
My Zanussi ZSF6160 dishwasher (2 years old)stopped heating during both the wash and drying cycles. A repair man imediately suspected the control relay rather than the heating element. He subsequently dismantled the control module and found a black burn mark on the back of the control module PCB. This call out cost me £30 and he then quoted me a further £216 to fit a new control module!!!!! Once I had regained my composure I armed myself with soldering iron and multimeter, took the heating element control relay off and found it to be working perfectly, thus it was the PCB trace that had failed with carrying the 10A current thus with some extra beefy wires soldered to back of PCB to avoid any further PCB burn out I have cured my dishwashers ills and it now works perfectly again! The way the repair man knew exactly what the problem was I suspect that this is a common problem (design flaw) so I want to let others know that all that is required is a bit of resoldering rather than a hefty repair bill or a new dishwasher Is this weak PCB trace, carrying 10A, built in obsolescence?
  • 1 more comment
  • Tony Smith Sep 20, 2007
    One of the high current carrying solder joints on the relay had melted/been blown away and also the PCB trace near this joint had evaporated, so which bit whent first I can't tell. The trace varied in width and was perhaps a bit wider near the failed joint so perhaps it was actually a weak solder joint that failed blowing up some of the trace with it? The trace was on average 1/4 inch however some thinner sections had extra surface mount solder along its length to try to beef it up.
    The moral of this story is don't leave on high powered appliances (washing machine, dishwasher) when you are out of the house because there is a genuine chance they could fail and cause a house fire!
  • Anonymous Feb 19, 2008
    zanussi de6854 is not heating any ideas
  • AlanJC Feb 25, 2008
    I have the same 'no heating' problem Tony... and have emailed Zanussi telling them of the problem and asking them for the part number for the heater element so I can replace it. Their reply should be interesting... if they know the fault lies elsewhere! Do you have a diagram that shows what soldering is needed??
  • 883 Answers
Probably not, believe it or not. If they actually designed a trace to fail under load, then they could not predict when it may happen. Yes, things get more load-some over long use and demand more current, but the pcb trace was probably not intentionally too small. Let's say it was designed too small. So at first startup it carries 9.5 Amps. The next factory unit draws 9.8 amps. the next unit, wait a minute, draws 10 amps and blew the trace before it got shipped. I think this under-design was a simple oversight, but one that should have demanded a product recall from Zanussi that would send a tech to every unit to install a pcb with a beefier trace. Email Zanussi and complain! Just curious...can you measure how wide is this pcb trace? It should be about 1/4 inch wide.
Posted on Sep 20, 2007
SOURCE:
I have Zanussi DX6453 dishwasher. Suddenly it is not drying our dishes. All programs working. Do you think is problem with Element or Thermostat. It is heating water.
sugget the water temperature, it relies on the temperature of the water to heat to items up so that when the wash cycle has finished the heat will dry them. Hope this is useful. Regards Mike
Jul 07, 2011 | Zanussi Dishwashers
Zanussi 6015 dishwasher washes in cold water
the dishwasher might accept cold water but must heat the water up during the cycle. If it does not then check the heater circuit......element...thermos NTC, with a meter for electrical continuity....some dishwashers stop mid cycle if the re is no heat but some go right through on cold depending on the make.. good luck
Mar 01, 2011 | Dishwashers
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Dishwasher running on cold water
that will be the callrod heater at the bottom look at it in the bottom to see if you see any cracks
not an easy job
Apr 17, 2009 | Zanussi 24 in. ZSF6160 Free-standing...
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Zanussi 24 in. ZSF6160 Free-standing Dishwasher Logo
531 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
