Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
MadCatz8860 Won't Charge
My son bought the MadCatz8860 bluetooth headset for his PS3. We followed the charging instructions in the user manual, but the red LED charging indicator has never lit. The unit "appeared" to have charged on the initial, and functioned fine for about 5hrs. Now it turns itself off after five mins of use and still won't charge. Any thought beyond, "you shouldn't have bought that piece of ****"?
  • Christ_101 Apr 30, 2009
    Same problem here. I read some other post mentionning to charge using both mini-USB cables plugged in... same result.
    Also tried charging using PC instead... nothing to do... The red indicator flashes about 12 times at most and stops. This must be a battery problem.
    I haven't found a hard reset procedure that would reset the internal state of the headset. Any thoughts on how to do it? Maybe this would at least let the unit completely charge.
    Thanks
  • bigmant May 07, 2009
    Thanks Vulture, but that ship has sailed...we already did the initial charge and now we're dealing with a unit that won't charge at all.
    Still looking for a viable solution...next step for me may be to try and return the headset and get a refund or replacement.
When you buy it for the 1st time, charge it up for double the reckemended 1st charge
Posted on Apr 28, 2009
I found my son's plantronics 220. Been in storage a year! I have it charging now. the light is red and ever so often it flashes a blue color for a instant. Is it still good?
Normally the flashing red / blue light indicates the headset is in pairing mode. The red light indicates it's charging but the occasional instant blue is a mystery. The user guide below has the instructions for turning the headset on and off, and pairing to a phone. I would suggest you charge it up, follow the pairing instructions and see what comes up.
http://www.plantronics.com/us/media/media-resources/literature/user_guides/Explorer220_userguide_en_us.pdf?WT.dl=20
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I am unable to sync my Mad Catz bluetooth to my PS3 and I can't find my bluetooth manual. How do I sync up?
Please see the sync details below:
Trouble Shooting
Jan 28, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do i charge my "Mad Catz PS3 Headset"?
You can download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
To magnify the text of the manual, click the [+] button on the Adobe Reader window (see attached image)
Hope this solves your problem. Thanks for using FixYa.
Jul 14, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Mar 04, 2009 | Plantronics Stereo Earbud Headset for Use...
Motorola bluetooth headsat h385 for phone lg(kp170)
Click on the link below to open the user manual, and follow instruction on PDF document:
BEFORE YOU BEGIN CHARGE START BLUETOOTH FEATURE
Mar 02, 2009 | Motorola Mobility Universal Bluetooth...
Instruction manual for the datel bluetooth headset for Sony ps3
Here is a link for Sony with detailed instructions for pairing the bluetooth device to the PS3.
http://tinyurl.com/53tg8k
When it propts you for a code, use 0000.
Good luck to you and your son!! Happy gaming!!
Aug 21, 2008 | Microsoft 20GB Hard Drive for Xbox 360
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
907 people viewed this question
Top Mad Catz Radio Communications Experts
Gene
Tom Chichester
Bill Boyd
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
