Home | Remote Controls | Innovage Jumbo Uni...
Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Innovage Jumbo Universal Remote Control
By bigzak on Sep 19, 2007
I bought this remote control at Bed Bath and Beyond. There are no directions on how to set it so it will work on my TV. Help Please!
We have a SAMSUNG Flat screen.
We put the batteries in, pushed the search button and nothing happened. We know the batteries work,as a little red light was on on the remote.
Sponsored Links
Same Problem
Apr 14, 2009
-   dont know how to program remote
-   Guest
Mar 07, 2009
-   my jumbo remote wont work because the directions are not clear -   Guest
Mar 02, 2009
-   I got a smart jumbo emerson universal remote control. I cant set it up there is no instructions.only said ease one touch learn allows you to transfer codes from your old remotes. I try but didn't work -   Guest
Feb 22, 2009
-   i have the jumbo universal remote but the input button doesnt work???help!!!!!1 -   Guest
Feb 21, 2009
-   The instructions say to press the set button. There is no set button on the remote.-   Guest
Best Solution
posted on Dec 22, 2007
Very Helpful)
amandarose1
Rank: Apprentice
Rating: 99%, 57 votes
I just bought this remote, i have a sony tv. i have tried all the codes and the code searches and yet i have had no luck. i have read thru the directions and follow them step by step. i dont understand why its so hard to program, and why there is so many codes for a so called universal remote control. any help would be greatly appreciated.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 05, 2008
Very Helpful)
BayAreaGuy
Rank: Apprentice
Rating: 98%, 7 votes
If you are looking for a code for your Comcast Motorola cable box so that you can use your Innovage Jumbo Universal Remote Control and you notice that there is no code for that box in the manufacturer's instructions, you should try all of the General Instrument codes. Some time back, Motorola purchased GI and the boxes are made by that group. To save you time, those codes are either 003, 049, 051, 053, 054, 058, 068, 069, 070, or 071. I hope that helps.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Aug 04, 2008
Very Helpful)
raskel
Rank: Apprentice
Rating: 97%, 83 votes
If you don't have the code do this! I worked for me.... Hold code search until light stays on... then select item to program <tv, vcr, dvd,exct..>... then press power button once... It will blink every couple of seconds and run thru the codes it self..... wait for the item choosen to turn off.... Then quickly press enter... TADA PROGRAMED!!!!! continue for each item to be programed. Be patient there are up to 500 codes! Can take Up to 10 min, But better than wasting $10.00$ good luck
Was this helpful?
Yes
No
32 people thought this was helpful
Solution #4
posted on Dec 26, 2007
Very Helpful)
ka8apf
Rank: Apprentice
Rating: 96%, 12 votes
Patience is the best fix... yea, I was getting frustrated, got the dvd player and vcr right away, but my emerson tv was killing me, had it switch off a couple of times, but the channel/volume wouldn't work. finally went thru the push button 300 times directions, and when I hit the button sslloowwllyy (once every 2 or 3 seconds or so) I finally landed on the right code. (I guess I was going past the code when I was mashing the button 3 or 4 times a sec!) couldn't get it to work on my surround sound (pioneer) but it never claimed to do that!
It was a gag gift from my wife, (my fingers are large and lots of remotes have tiny buttons), but it is worth the $10 that I saw it for at the local stores... considering remotes can sell for upwards of $500, you get what you pay for!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Dec 28, 2007
Very Helpful)
joy6
Rank: Apprentice
Rating: 96%, 43 votes
I need help to program my t.v. I program my sharper image jumbo universal remote to my satilit direct t.v. but i can't get it to work on my philips/magnavox T.V. I hit code search light was steady on ,hit t.v. it blinked hit on/off for one hour nothing happened tried again one hour later T.V. went off hit enter then tried to turn on t.v. nothing what am I doing wrong?
Was this helpful?
Yes
No
Solution #6
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I found the solution after pulling my hair out for 3 days. It really does work. As the instructions state as an alternate solution...press the code button until the red light stays on, release the code buttion (the red light stays on), push the TV button, then slowly press the on/off button ( up to 300 times) do it slowly, you will hit the right code and the TV will turn off then press the enter button. You are done! If you pust the on off button too fast it does not work. That was my problem for the first 3 days. do it slowly.
Solution #7
posted on Sep 08, 2008
Helpful)
streetsmart1
Rank: Apprentice
Rating: 95%, 19 votes
There is some good information on this page. Here is a link with a pdf / picture of the manual / instructions / directions.
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
Here is the short version
Turn on the device you want to deal with
Hold the Code Search button (for 3 seconds till it goes solid)
Then push the device button you want to program
Then keep the remote aimed at the device and occasionally and slowly push the power button. (It could take 50 pushes or 60 seconds for the remote to find the right code)
Once the device turns itself off, you need to quickly push the enter button. This will store the code in the remote.
Then push power again to double check that the remote will turn the device back on. Try all the other buttons. If it all works, then great. In my case the volume down button changed the channell, and I had to keep searching for new codes. Also my TV Input button hasn't worked on any code I tried.
Any suggestions for my TV Input button?????
Was this helpful?
Yes
No
10 people thought this was helpful
Solution #8
posted on Jan 05, 2008
Helpful)
gadget73
Rank: Apprentice
Rating: 95%, 8 votes
#12 - I read on another site that the code for a Comcast Motorola DVR Cable Receiver is 051. I can't confirm it yet since I'm not where the box is.
Was this helpful?
Yes
No
Solution #9
posted on Jan 06, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The 51 code did work for the Motorola Cable box
Solution #10
posted on Sep 20, 2007
Helpful)
simplemitch
Rank: Guru
Rating: 86%, 624 votes
here's a link to photos of the manual:
http://www.rockabilly.net/files/manuals/...
Comments:
Sep 22, 2007
- So you followed the instructions in the manual EXACTLY?
Sep 22, 2007
- Heres the EXACT sequence to follow. OK?
1)press and HOLD "code search" for at least 3 seconds (until the light lights up).
2)Press TV
3)press the 3-digit code and the light should turn off.
4)Test by pressing the Power button.
5)If it didn't work try the next 3-digit code until you find the code that works.
And here's the codes for Samsung:
004, 005, 009, 015, 104, 105, 106, 109, 172.
If it works please remember to change the rating from "unhelpful" to "solved"....
Sep 22, 2007
- Did you follow my directions word for word? If so, did the light go on and off as listed in the steps above( step 1 and step 3)? Did you try ALL OF THE CODES?
Was this helpful?
Yes
No
Solution #11
Somewhat Helpful)
10101
Rank: Apprentice
Rating: 74%, 3 votes
anyone know a motorola cable box code?
Was this helpful?
Yes
No
Solution #12
posted on Jul 31, 2009
Very Helpful)
sarahbearuhh
Rank: Apprentice
Rating: 100%, 2 votes
website to online manual. hope this helps everyone!!!
Was this helpful?
Yes
No
Solution #13
posted on Nov 27, 2008
Very Helpful)
ankhlenda
Rank: Apprentice
Rating: 94%, 11 votes
google--Emerson Jumbo Universal Remote Instructions
This site has a printable instruction guide with all the codes and updated codes for new product names.
Hope this helps all of us!
Was this helpful?
Yes
No
Solution #14
posted on Sep 05, 2008
Very Helpful)
navoy
Rank: Apprentice
Rating: 100%, 1 votes
THE PERSON WHO POSTED THIS SOLUTION IS ABSOLUTLY CORRECT FOR THE INNOVAGE JUMBO UNIVERSAL REMOTE!!!!!!
Was this helpful?
Yes
No
Solution #15
posted on Dec 01, 2008
Helpful)
olderelder75
Rank: Apprentice
Rating: 92%, 3 votes
I have the Emerson Jumbo remote that this lady talks about, also no manual. I somehow figured out how to program the TV so it works, however, I don't seem to be able to enable the DVD. Do you know the right way to do it?
Richard
Was this helpful?
Yes
No
Solution #16
posted on Jan 16, 2009
Helpful)
dkef0915
Rank: Apprentice
Rating: 88%, 2 votes
how do you find the code
Was this helpful?
Yes
No
Solution #17
posted on Nov 30, 2008
Helpful)
carchamber
Rank: Apprentice
I have a Emerson 32 LCD HDTV and a jumbo universal remote emerson, can not get it to code the tv so it can turn tv on and off.
Was this helpful?
Yes
No
Solution #18
posted on Jun 27, 2008
Helpful)
barbiehoc
Rank: Apprentice
http://www.blurtit.com/q567041.html
Someone posted the whole manual at above website--go to end of written paragraph and clik 'here'--you have to open and print 6 pictures--but they are clear and then you will have the whole manual and all the codes! (Innovage Jumbo Remote Manual)
My works fine now! Good Luck!
Was this helpful?
Yes
No
Solution #19
posted on Jun 28, 2009
Somewhat Helpful)
stevefoss
Rank: Apprentice
Rating: 75%, 1 votes
I have programmed the report for my cable & TV - However I am not able to bring up the guide - Any ideas?
Was this helpful?
Yes
No
Solution #20
posted on Mar 07, 2009
Somewhat Helpful)
ocv1328
Rank: Apprentice
Press and Hold "Code Search" until light is solid red.
Aim remote at device and press appropriate device button to program.
Press "Power" button until device turns off.
Press "Enter" after device turns off.
Was this helpful?
Yes
No
Solution #21
posted on Jan 19, 2009
Somewhat Helpful)
rougev
Rank: Apprentice
i can't get my dvd to turn back on after it goes off
Was this helpful?
Yes
No
Solution #22
posted on May 18, 2009
Not Rated)
rtc5027
Rank: Apprentice
Rating: 0%, 0 votes
If you are correctly using the code search button/the correct codes and your tv goes off and you hit enter it is programmed. To complete the programming you must hit the correct device button after hitting enter i.e TV, VCR, etc.Then hit power again. If you hit power before hitting the device button it will cancel the programming.
Was this helpful?
Yes
No
Solution #23
posted on May 08, 2009
Not Rated)
IAMSISSY
Rank: Guide
Rating: 74%, 8 votes
SOME OF THESE REMOTES -YOU MUST HIT THE MUTE BUTTON-NOT THE ENTER BUTTON
DO THIS
CODE SEARCH-(BLINKING RED LIGHT)-
DEVICE KEY- (BLINKING RED LIGHT)
CODE ( 3 DIGIT)
MUTE KEY
TRY TO TURN DEVICE OFF WITH POWER BUTTON
Was this helpful?
Yes
No
Solution #24
posted on Jan 13, 2009
Not Rated)
dej57
Rank: Apprentice
Rating: 0%, 0 votes
Can't give you the "code", but I can suggest a method that I found to control my 42" Oleavia. Use the code search method, but instead of stopping and hitting enter on the code that turns the TV off, continue trying codes until you find the one that then turns the TV on, and then hit enter. Standard features of the remote then all work, except for mute, in my case.
Was this helpful?
Yes
No
Solution #25
posted on Dec 25, 2008
Not Rated)
WeeFix
Rank: Apprentice
Rating: 0%, 0 votes
Hello all remotes purchased work in a similar fashion. You must select the appliance you want to work with hold down the Code Search function key until it stays lit they key punch a 3 digit code. After this verify that the unit works with this code, if it does not use another code provided ( usually 2 to 3 per brand).
If you do not have the code for the particular apppliance look at http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf or
http://en.kioskea.net/faq/sujet-281-universal-remote-codes
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my... (More)
Answer
words appear on screen as tv plays and i can get it off
Answer
how can i get the codes for my remonte control : Philips Magnavox PM435S 4-Device Universal Remote... (More)
Answer
We bought a universal remote, but the mount cover for a vaulted ceiling won't cover the box?
Answer
i dont know a code for my regent dvd player that will work for a g.e universal remote
115 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 23, 2009
dont know codes for tv
Comment by Guest, posted on Jan 16, 2009
cannot find code
Comment by Guest, posted on Jan 15, 2009
my remote dosent even work. innovage i a piece a ****
Comment by TOMBESCHKE, posted on Jan 03, 2009
I HAVE THE SAME PROBLAM WITH MY REMOTE AND MY SAMSUNG FLATSCREEN. I CAN FOLLOW THE DIRECTIONS CORECTLY AND GET THE TV TO TURN OFF BUT IT WILL NOT TURN BACK ON WHEEN ALL DIRECTIOND ARE FOLLOWED CORECTLY........TOM
Comment by awoolman, posted on Dec 29, 2008
Can't find information anywhere!
Comment by Guest, posted on Dec 26, 2008
Remote works perfectly except that it won't allow me to access the guide on my Direct TV, that allows me to scroll thru all the channels- very strange.
Any help?
Comment by graham_coupe, posted on Dec 25, 2008
I have the same problem in that I cant find a code for a clarity television
Comment by wolpertinger, posted on Dec 25, 2008
Add me to the list, any ideas?
Comment by danielprock, posted on Dec 20, 2008
buught the Emerson Jumbo remote on ebay...no manuals...anybody help?
danielprock@yahoo.com
Comment by Guest, posted on Dec 16, 2008
Westinghouse TV/VCR can't get it to program
Hate when I buy something and it doesn't work as it should and there are phone numbers or any other help !!
Comment by Guest, posted on Dec 08, 2008
I just purchased this remote and have had no luck programming, I do not have a cable box, have tried TV and cable and still no luck, can anyone help, I looked for a phone number on the pkg. but nothing was listed.
Thanks Peggy
Comment by olderelder75, posted on Dec 01, 2008
Somewhat the same. I have an Emerson Jumbo Universal Remote, didn't get, or can't find, the instructions for programming the components. Somehow I got it to work for the TV, but can't seem to get the DVD to work. Someone got the know-how?
Richard
Comment by Guest, posted on Nov 28, 2008
lost directions to jombo remote
pleasse help
Comment by beckrau03, posted on Nov 26, 2008
need to know how to program
Comment by Guest, posted on Nov 26, 2008
we have a phillips tv. tried to set the remote with the code search button and was able to get the tv to turn off but nothing else. HELP!!
Comment by wpooh65251, posted on Nov 17, 2008
i have the same emerson jumbo universal remote but no directions on how to code it .
Comment by liliafelix, posted on Nov 17, 2008
I have the same problem and also a samsung TV
Comment by markmorrison, posted on Nov 12, 2008
I HAVE A CITIZEN C557 VCR DVD COMB ANY ONE HAVE THE CODES FOR THIS IF SO EMAIL ME AT markmorrison1961@gmail.com thanks
Comment by Dessy2005, posted on Nov 03, 2008
There are no instructions on how to use the Innovage jumbo universal remote control. How do you expect people to buy and enjoy your product if they can't use it?
Comment by mackeeta, posted on Oct 26, 2008
chasing code book please
Comment by pkoulikis, posted on Oct 16, 2008
We put the batteries in, pushed the search button and nothing happened. We know the batteries work,as a little red light was on on the remote.innovage jumbo remote
Comment by xoxemilyfxox, posted on Oct 05, 2008
i have the remote and i have a pioneer flat screen plz help me find the code quickly
i bought the jumbo remote and i dont know how to switch the code and get it to work i have a pioneer flat screen
Comment by Guest, posted on Oct 05, 2008
need to find code i have a pioneer flat screen help!!!!!
Comment by Guest, posted on Oct 04, 2008
how do i reset my remote?
Comment by daddydmj, posted on Sep 28, 2008
I have Motorola cable boxes.
Comment by mkp95, posted on Sep 09, 2008
I have managed to program the remote control (thanks to the help on here) to operate the TV and the digital box, but my problem is that the tv is a (Ferguson) TV/DVD combo and it's not operating the DVD. Anyone have any ideas please????
Comment by namanan, posted on Sep 09, 2008
there is no code for a GFM television. ive tried to program the remote on auto, but it wont go past 93 entries on the on/off button what do i do now?
Comment by jakers1122, posted on Sep 04, 2008
Need codes to program TV for Emerson Jumbo Universal Remote.
Comment by Guest, posted on Sep 03, 2008
the red light stays on nd nothin hapens help!
Comment by Guest, posted on Aug 29, 2008
need instructions on the sharper image oversized remote, need to know how to program the remote
Comment by camcg44, posted on Aug 21, 2008
please help do not have any directions to my jumbo universal remote the red light on the remote comes on but nothing im doing will make it work driving my bonkers any advice please reply. thankyou (remoteless}
Comment by Guest, posted on Aug 19, 2008
i need to program a jensen jr 300 remote to my apex tv/dvd combo but i don't have the codes
Comment by craftytoni, posted on Aug 10, 2008
need codes for my zn-735w for toshiba tv
Comment by nsfcceo, posted on Aug 09, 2008
When you are FOLLOWING THE DIRECTIONS and no results are produced after 25-minutes ... there is no more remote because it
disintegrated from being thrown against the wall.
There are no directions except what is found online. SET button? WHAT??? There isn't one. CODE SEARCH? Doesn't work.
Comment by rayzway1, posted on Aug 07, 2008
i need to know how to program it to my devices? panasonic t.v.
Comment by Guest, posted on Aug 07, 2008
i lost the code book an i need the codes for an emeson tv
Comment by Guest, posted on Aug 06, 2008
need code for remote
Comment by pellicano_p, posted on Aug 05, 2008
cannot program my jumbo universal remote battery are fine
Comment by Guest, posted on Jul 30, 2008
It will not work with Direct TV , no matter how i try to install code.
Comment by dchubb67, posted on Jul 19, 2008
set to work on my tv
Comment by ocmofohs, posted on Jul 10, 2008
Hey all! If you would just search for a PDF of the Innova Jumbo Universal Remote Control Users Manual, you could get all the info you need!
I just bought mine at a garage sale... with no manual..
Anyway, to make it easier for you all, here is the link... http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
Comment by jamiedd, posted on Jul 09, 2008
I Tried ALL of the codes for a sylvania television and NONE of them worked.
I did everything exactly as the manual said. I even tried the code search.....after minutes of pushing the on and off button I gave up!
I tried ALL of the sylvania codes. This is rediculous. Never had problems with universal remotes before.
Comment by dyoussefi, posted on Jul 06, 2008
Need the codes for a Sharp TV for Innovage Jumbo Universal Remote. Thanks.
Comment by Guest, posted on Jun 15, 2008
need code for sanyo tv, can anyone help?
Comment by Guest, posted on Jun 10, 2008
i don't have the directions to my zenith zn-735w universal remote control
Comment by Guest, posted on Jun 09, 2008
my tv is an acer....anyone know the code???????
Comment by Guest, posted on Jun 06, 2008
Comment by lee007, posted on Jun 02, 2008
I have had many Direct TV recievers over 7 years. I have found that I can not program any remote to my Direct TV Brand HD Satellite rec. nor can I program any remote to my newest Direct TV Brand Digital Receiver. My guess is proprietary Technology. I also have an RCA Direct TV Digital Reciever over 7 yrs old and it programs easily to Emerson Jumbo and any other.
Comment by Guest, posted on May 31, 2008
have a rca remote need to program to a sharp 32 in flat screen t.v. i need the code
Comment by Guest, posted on May 26, 2008
bought this remote no instruction came and can't get it to work
Comment by raymeo, posted on May 25, 2008
I have a Orion TV i need the code to program it.
Comment by Guest, posted on May 25, 2008
need code for samsung vhs
Comment by WarrenGio, posted on May 22, 2008
I have a SamSung LNT3242HS HDTV and the remote control does not work. The lights on the channel and volume buttons stay constantly lit up. I put in new batteries, tried reseting the remote, and I've pressed every button, but nothing works. Has anyone else has this problem?
Comment by dip55, posted on May 07, 2008
You can go to this web page and download the manual if it helps.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage
Comment by Sweet April, posted on May 07, 2008
I am going through the same situation, My remote only lights up but wont turn my tv on or off. I want to know step by step what to do because it is very frustrating, and it does'nt come with any directions! Please Help Me!!!
Candy Rodriguez
Comment by Terr53, posted on May 06, 2008
I have a samsung 40 " flat screen as well and it is doing the exact same thing. I can't find codes for this TV... plus I push codes search and nothing happens. Very frustrating
Comment by gah1, posted on May 04, 2008
I have purchased the Innovage jumbo remote, but have lost the instructions on how to program it to my tv/dvd/sat.
Comment by kaybbay, posted on Apr 30, 2008
i put in the batteries ,sellect the cable ,and press the seach button the red light flickered and nothing happen,i repeat the same process for the dvd and tv nothing happen
Comment by Guest, posted on Apr 28, 2008
my remote will work on dish but not on cable box
Comment by Guest, posted on Apr 27, 2008
I need to figure out how to programe the Jumbo Universal for an Emerson TV? Do you have the instruction manual..mine was lost!
Thanks
Comment by sihota, posted on Apr 27, 2008
i have sonicview sv-4000 sat but real remote is damage but now i have universal remote jumbo and there no code for sonicview what should i do now?
Comment by rainbow12, posted on Apr 23, 2008
I am trying to program my jumbo remote to DishNetwork. I can not find the owner;s manual for assistance.I have been unsuccessful. Suggestions please.
Comment by dog bite, posted on Apr 20, 2008
I have a flat screen tv that I can not get and also Comcast cable the jumbo remote does not work help
Comment by ddugard, posted on Apr 13, 2008
This was given to me as a present. I love the large buttons but I really need to know how to program the thing.
Dale D
Comment by Guest, posted on Apr 08, 2008
we need directions to program this unit to our tv which is a panasonic
Comment by Guest, posted on Apr 05, 2008
i bought a remote and the red light is always on.
Comment by Guest, posted on Mar 25, 2008
I can not get my cable box to work with it
Comment by Guest, posted on Mar 24, 2008
need program codes for remote.
Comment by chkswyfe, posted on Mar 16, 2008
i just need to know how to set the remote. i got the codes on the internet, now i jus need to what buttons to push.
Comment by Guest, posted on Mar 13, 2008
I recently received the jumbo universal remote control and it has no programming instructions for coding it for our Sony tv. It has no programming instructions at all in the package.
Comment by dauke, posted on Mar 12, 2008
I have a Samsung VCR model VR5806. I was able to set up this remote to turn it on, off, play, record, etc. However I cannot get the menu to come up. I tried following the instructions but when I press the menu button the LED does not come on. Any suggestions? Thanks.
Comment by Guest, posted on Mar 12, 2008
lost jumbo remote instrctions. please help
I purchased a jumbo universal remote and lost the intructions. I have an Apex. Please help
Comment by Guest, posted on Mar 09, 2008
how do I program my remote
Comment by Guest, posted on Mar 07, 2008
remote
Comment by ian268, posted on Feb 16, 2008
Comment by Guest, posted on Feb 12, 2008
I have followed all the instructions in the manual for over three hours and with close instructions putting the codes.
Comment by Guest, posted on Feb 11, 2008
how do u program the code to TV....what button sequence?
Comment by Guest, posted on Feb 10, 2008
I have lost the instruction booklet I have a Samsung TX
Comment by mtorr305, posted on Jan 18, 2008
need code 4 samsung tv
Comment by Guest, posted on Jan 15, 2008
I PROGRAMMED IT FOR MY T.V ITS A PHILLIPS , IT TURNED OFF AND I NOW IT WONT TURN ON AGAIN !!! HELP
Comment by Guest, posted on Jan 13, 2008
i put the batteries in to program the remote to my universal remote and don;t buy it it doesn't work
Comment by joy6, posted on Jan 07, 2008
the batteries work I PROGRAMED THE SATILLITE NO PROBLEM, BUT I CANT PROGRAM THE T.V. PHILIPS/MAGNAVOX. CALLED THE HELP LINE TOLD TO TURN OFF EVERYTHING BUT THE TV, NOYHING, UNPLUGGED EVERYTHING BUT THE TV NOTHING . HIT CODE SEARCH TILL LIGHT WAS ON STEADY, HIT TV IT BLINKED ONCE HIT ON OFF BUTTON TILL TV WENT OFF HIT ENTER IMMEDIATELY WAITED A FEW SECONDS HIT TV THEN POWER/ ON/OFF BUTTON NOTHING. YOUR PRODUCTS MUST ALL SUCK BECAUSE EACH TIME I TRIED TO CALL SUPPORT IT TOOK ME TWO TO THREE HOURS TO GET THROUGH WITH HITTING MY REDIAL BUTTON I GET PUT ON HOLD HEAR THE RECORDING EVERY FIFTEEN MINUTES THREE TIMES THEN THE PHONE DISCONNECTS AND I HAVE TO HIT REDIAL ALL THEY SAY IS IT SHOULD WORK THIS HAS BEEN GOING ON SINCE CHRISTMAS THE SORE JC PENNEY'S WON'T TAKE BACK THE JUMBO SHARPER IMAGE REMOTE THE PACKAGE WAS OPEN WHAT THE HELL DO I DO NOW ? DO YOU STAND BT YOUR PRODUCTS ? I WANT MY MONEY BACK OR INSTRUCTIONS ON HOW TO PROGRAM THIS THING INSTRUCTIONS FOR THIS REMOTE NOT ONE LIKE IT. VERY VERY VERY DISSATISFIED
JOYCE DIDOMENICO
@ CASCLOSED@AOL.COM
Comment by Guest, posted on Jan 07, 2008
we pushed the code search button and it blinked 3 times. what do we next?
Comment by Guest, posted on Jan 06, 2008
have a samsung tv and the menu continues to stay on screen and cannot remove with remote `control
Comment by beckyb26, posted on Jan 03, 2008
Did anyone evr find a solution to programming this remote for Direct TV?
Comment by Guest, posted on Jan 02, 2008
All of the listed codes for Direct TV do not work. I have tried almost all codes listed for all types of Satellite Dishes. Does this thing really work?
Comment by Guest, posted on Dec 28, 2007
Used the remote for a day until the red code light came on and stayed on.
Nothing works at this point.
Comment by jack52, posted on Dec 28, 2007
cannot program direct tv (d11) on the innovage jumbo remote
Comment by joy6, posted on Dec 27, 2007
philips/magnavox tv. red light is on hit code search till light is stead hit t.v. only the t.v. is on the light blinked once hit on\off each time it blinked till it turned off the t.v. it took 45 mins. hit enter when the t.v. went off. it still does not turn on the t.v. how do i program this remote to operate my t.v.
Comment by Guest, posted on Dec 27, 2007
the little red light is on only the tv is on. pressed code searchtill red light is on steady hit t.v. button which blinked once the hit on\off for one hour . tv went off hit enter now the t.v. still does not operate with the remote it is a phillips/magnavox brand. how do i program it?
Comment by Alanwrock, posted on Dec 27, 2007
Same problem with Viewsonic TV and Motorola Digital Cable box.....I am thinking of tossing it???? Very bad product.
Comment by GOATHEAD, posted on Dec 27, 2007
I CAN'T GET THE INNOVAGE JUMBO REMOTE TO CONTROL MY DIRECT TV RECEIVER. IT WILL CONTROL MY SONY TV. DIRECT TV PEOPLE WERE OF NO HELP. ANY IDEAS? I TRIED EVERYTHING THE MANUAL SUGGESTED; NONE OF THE CODES WORKED.
Comment by Hrmpro, posted on Dec 27, 2007
I have followed the instructions to program my jumbo universal remote but it just does not work. I tried the code listed for my sony tv, the code search option including the option to press on off 300 times to search all codes. Nothing works. Any ideas?
I have a directv hd receiver and a sony home theater dvd and I can't find a code to make them work. What can I do?
Comment by Guest, posted on Dec 26, 2007
I have a TV that isn't listed in the instructions. It's an Insignia. The Code search didn't work.
Comment by Mary Cooper, posted on Dec 26, 2007
We have done all the steps in the manual the llights come on cannot get the channel to change or turn the tv off or work the volume HELP HELP HELP HELP US!!!!!!!!!!!!!!!!!!!!!!!!
Comment by doratech, posted on Dec 25, 2007
the code for samsung dvd/vcr combo does not work . I also tried to use code search button to no avail.
Comment by Guest, posted on Dec 25, 2007
Comment by Guest, posted on Dec 24, 2007
I also clicked the code search button on the control while having the tv on it did nothing and the batteries are brand new so I know thats not the problem.
Comment by JAWimmer, posted on Dec 21, 2007
Does this innovage jumbo remote work with TIVO? How do you program your sound receiver on it? We have JVC....I was able to put in the tv (to turn off and on) and the dvd player and that's it...
Thanks
Julie
Comment by ponky05, posted on Dec 21, 2007
Just had a replacement Jumbo Universal Remote Control (Innovage) but can seem to get the code for Sky Digital. Can someone please help with the code as the remote does not autoselect the code from Mute/Search button. Thanks.
Comment by lkjh, posted on Dec 20, 2007
i have a prima tv and theres no code for them
Comment by polariod, posted on Dec 11, 2007
I have a polariod tv can't find a code
Comment by Kmeisterus, posted on Dec 08, 2007
It's with the Samsung remote that came with the TV - a remote that widens at the top and has the number 00302D under the DVD/VCR control buttons and above the Channel Up button. Volume functions work but nothing else.
Comment by Guest, posted on Dec 05, 2007
what are the codes for a Sharp TV? Zenith Universal remote ZN 735W?
Comment by isuckatlife, posted on Nov 22, 2007
this remote is KILLING ME!!!
i cannot program this jumbo remote even with the manual
i have tried all three codes for Directv on the satellite thing
and it doesn't respond
doesn't change the channel or turn off
NOTHING!
please help I'm desperate :(
Comment by stimetb, posted on Nov 18, 2007
looking for manual and codes for smasung for jumbo universal remote
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Remote Controls:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
