Question about IBM Computers & Internet
What is the minimum power supply for mobo:ibm usa p6 2001?will a 250Watts work?
  • jos96301 Apr 19, 2009
    many thanks to aaclevy,I will be addind a 500 watts ,not a 250.thanks ,i forgot about the second hd.
  • 37 Answers
It depends on what peripherals and processor you're using. If you're using an under 100 watt processor, a 250 should work fine if you're only running one HD, one DVD-RW, and a very modest video card.
The fancier your processor is in it's revision line, the more wattage it draws, the more hard disks, cd-rws, pci cards etc you use.
You also may want to consider uptime requirements, and usage percentage. if you're running constant loads, power supplies don't like that, and the capacitors can get burnt up. Servers, video processing, etc will tend to require more than rated supplies just because 100% use of even close to rated wattage (and you will be very close) will tend to cause the maximum design heat to be produces, possibly blowing out capacitors etc in the power supply, causing downtime.
The brand name of the power supply matters too... if you're using a no-name chinese brand, i would be leery about their "rating", as it's probably peak for only a short time rating...
Posted on Apr 19, 2009
  • Aryeh Levy Apr 20, 2009
    a HD runs around 25 nominally but spikes at ~70 during startup...
I have the mobo ibm thinkcentre M50 8219 I have a new case
Hello i depends on the manufacture of the mainboard.
The pinout for the frontpanel is placed down low in the right corner of the mainboard.
Here are the most used pinout:
Good luck
Dec 01, 2012 | Computers & Internet
Hi. Where can I find the model of my IBM mobo, please?
Plug-in a stick of RAM, connect a LCD screen, connect a keyboard, connect a power-supply,
and briefly "short" the 2 'power' pins on the motherboard, and the motherboard will start.
Watch the screen, for the "press <blah> to enter BIOS SETUP" message.
Then, press the 'blah' key, and read the model-number from the screen.
Feb 01, 2011 | IBM Computers & Internet
My t1855 power supply is not working.
explain not working??? not plugged in , no fan , black screen , blue screen.. ?? If it is just the power supply their is a fuse that may or may not be able to replace inside it .. but been my experience if their appears to be no power the power supply/motherboard may be more likely the fault.. i have eperienced mobo burn up processors and powersupply's.. if u have a blue screen then it could b hardware thats out , virus in the bios possible but not likely, remove any cards u have added an disconnect all but bare minimum then systematically re install each an boot each time until u find the culpit.. if all else try the simple an obvious first..
Apr 29, 2010 | E-Machines T1855 PC Desktop
Motherboard will not post
Turn it off. Remove the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-drive).
Remove any add-on PCI cards (modem, network, TV, 2nd video).
Remove ALL the RAM.
Reconnect the power, and turn it on.
Try to POST -- if it is not "dead", it should "beep" a few times, due to having _NO_ RAM installed.
Turn it off.
Add ONE stick of RAM.
Connect the AC power-cord.
Turn it on.
Same "beeps"? Different? No beeps?
Oct 09, 2009 | ASUS P4P800 SE (890552603657) Motherboard
How do the various power connections on the board work? My AT power supply died.
Replace the Power Supply with one that has the same type connectors. When you plug them in the Mobo you will see a lock clip that faces one certain direction.
Jun 27, 2009 | SuperMicro SUPER P6 DGH (P6DGH-USA)...
Dimension 4550 CN 02U819 power supply works but
many dells take proprietary power supplies. if you are using an aftermarket power supply, then you may have burned out your mobo. irregardless, your mobo may be dead, and that mey be the very problem.
Jun 08, 2009 | Dell (E210882) Motherboard
Debian install failed
You might try running one of the live cd distributions to see if the machine hardware is supported that way. You do need a minimum of 128 MB of ram, might be 192 for a live system. It could just be that the system doesn't have enough ram to run Debian, that would explain why it wouldn't finish installation, and why it fails to load now. Check the readme and release notes for minimum system requirements. Maybe you would do better with a leaner distro like DSL?
Dec 17, 2008 | IBM POWER SUPPLY 8565/80 64F3693 Power...
Computers & Internet Logo
481 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
