Question about E-Machines eMachines Desktop PC
Tried new power supply but didn't help. (Who knows - maybe I didn't install correctly.) I first thought it was the power switch on front of machine. Was wondering if some easy test for power switch?
  • JDTec
    JDTec May 11, 2010
    You need an multimeter to check the switch and the Power supply.
  • E-Machines Master
  • 5,660 Answers
Tips from me:
1.If your power supply isn't coming on, I advise you to check the 20/24-pin motherboard power cable,
connector, and be sure it's down in tight. Make sure that lock tab of the power cable connector, snaps over the motherboard connector lug. Make sure that connector is in all the way.
2.Be sure the wires that come from the Power On switch, and go to the motherboard, are connected, and down all the way. The connector, or individual connectors, need to be down on those motherboard pins all the way. (The area on the motherboard where they connect, is called the Front Panel header. A connector on a motherboard is called a Header)
Also make sure both wires from the Power On switch, (Button), are connected to the motherboard, if the wires have individual connectors.
Now, how to test to see if the Power On switch is bad.
The 20/24-pin ATX motherboard power cable connector comes in three styles.
A.20-pin connector. Has two rows of 10 socket holes
B.24-pin connector. Has two rows of 12 socket holes
C.20-pin and a 4-pin connector.
NO matter what style it is, it has a Green wire going to that connector. The Green wire is the
Soft Power On wire.
With the motherboard power connector plugged into the motherboard, and the computer plugged into the surge protector, you need to jump that Soft Power On wire, to a Ground wire.
View these photos of a 20-pin ATX Main power cable. (Motherboard power cable, Main power cable.
Same/same)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Look at the photo all the way to the right. (You can save this page, and bring it up in a new window)
This shows that Green wire. Fourth one from the left.
Next to it is a Black wire. Fifth one from the left.
ANY Black wire is a Ground wire.
You need to make a jumper wire. This wire should have insulation on it. It should be as thick as those power cable wires. It should be about 3 inches long. You need to strip off 3/4ths of a inch of insulation, off of EACH end. Twist the exposed wires. Make a tight wrap. Bend this wire into a U-shape.
At this point you may want to don a protective rubber glove. Tightly fitting dishwashing glove, or perhaps a surgical style one. Reasoning is, that there will be a spark. You may feel more safe this way. I don't use one, but I'm an old tech, and maybe not too Tightly Wrapped! lol! (I also was a journeyman lineman, so this spark doesn't bother me!)
With the ATX motherboard power cable plugged into the motherboard, you are looking at the back of the connector. The wires go down into a socket. At the end of every wire is a metal terminal end.
It's pretty far down in there. One end of your jumper wire, goes down deep into the Green wire socket. It needs to touch that metal terminal end.
The other end of your jumper wire, needs to touch a Ground wire terminal end. ANY Black wire is a Ground wire. Just stick the end down into a socket with a Ground wire. Hold it there for about 1 to 2 seconds, bring the wire back out. You just want to make a Momentary Contact.
Your power supply should start.
If so, you have a bad Power On switch. If not, your problem is the power supply, or the motherboard.
Posted on Apr 20, 2009
  • 40 Answers
I'm assuming you press the power button and absolutely nothing happens?
you can purchase a pretty cheap power supply tester, but usually switching it with another one is the easiest way unless you do this type of thing often.  to be safe, just hook up the main connector to the motherboard and the additional 4 pin / 6 pin if it exists.  don't worry about hooking up your cd/dvd drive or hard drive yet.  if you have a video card and it has an additional power connection, it'll need to be plugged in, too, if you want to test for video.  now give it a shot.
if you are getting not fans moving, no leds on the front of your pc, your switch could be bad...probably not the psu if you changed it out unless it lacks the necessary hookups for your system.
often when i can't get video, the motherboard has gone bad...but sometimes a pci or agp card just needs to be reseated or even the memory.  good luck!
    Scholar:
  • 172 Answers
It is the classic motherboard problem, see my support pages at http://www.motherboardsrus.net and go to the emachine support page. Chris
Posted on Jun 05, 2009
Have a brand new juczzi tub water supply lines have water but nothing comes outa tub
If the machine had plugs fitted ....were they removed? Are the taps for the hoses, maybe you call them valves, switched to the power on position? Read your instrections/documentation and ensure you have installed the machine correctly. Something may have been overlooked
Jul 02, 2015 | Washing Machines
My e machine computer will just shut off after 5 or 10 min.,
I had an Emachines W3609 that did the same thing, I changed the 350-watt power supply with a 550-watt and it still shut off, even using the newer one. I thought just the first one was bad but I guess not. It had more than enough power to power it up but nothing. And it used to randomly restart at times and then just shut off. Try and get a new hard drive maybe that will help. Good luck!
Jan 03, 2013 | E-Machines Computers & Internet
D945ghz
Intel D945GZ motherboard? Got it. Now what the world are you talking about? A Chassis Intrusion Switch? What desktop computer is it in? Computer manufacturer name, and Model Number. Post back in a Comment.
Wait a minute. Won't boot, or the Power Supply doesn't start up?
Power Supply doesn't start up;
1) You have a bad ATX power on switch
2) You didn't connect the ATX power on switch to the correct pins, on the Front Panel header.
3) You have a bad Power Supply
http://www.directron.com/atxswitch.html
Computer doesn't boot up;
1) You didn't follow Anti-Static Precautions
2) You didn't apply Thermal Paste to the top of the Processor, before you put the Heatsink on.
3) You didn't connect the 4-pin ATX +12 Volt power cable.
Power for the Processor. (No processor, no computer)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
4) You didn't use the Installation Disk (CD) that came with the motherboard. (Has the DRIVERS)
5) Is this a replacement motherboard for a bad one?
SAME motherboard, or a different one?
Why?
Because when Windows is installed on a computer, (Harddrive, actually), it assigns hash values to certain major hardware components.
Components such as;
1) Processor
2) Motherboard chipset
3) BIOS program, version, and date
4) Harddrive
5) Graphics chipset. (Whether Integrated Graphics, or a graphics card)
Change any two of these components, and Windows will think it is being stolen.
Microsoft User's License states, "ONE Genuine copy of Windows per ONE computer "
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
If you are lucky, the Windows activation screen may come up. Windows will want to be activated again. (Activated, not Registered)
Doesn't happen all the time, though.
Using a brand new genuine copy of Windows? Make sure you go into BIOS Setup, and in Boot Order, set the first boot device to CDROM.
The LED light on the motherboard indicates it HAS power.
Motherboard Manual for the Intel D945GCZ mobo. (MOtherBOard),
(GHz stands for GigaHertz.
Giga = approximately 1 Billion.
Hertz stands for Cycles per Second.
1GHz = approximately 1 Billion Cycles per Second.
It refers to Frequency Rate. For laymen frequency rate = 'Speed')
Plus, it isn't new. It is NOS. New Old Stock.
Means it could be a bad motherboard, even if it has never been used.
{Computer technology follows Moore's Law,
http://en.wikipedia.org/wiki/Moore%27s_law
What is new technology today may be old tomorrow }
http://www.intel.com/support/motherboards/desktop/d945gcz/sb/CS-020793.htm
Blue -> English Product Guide [PDF]
Let me know if you think there is a Chassis Intrusion Switch.
It will operate one of two ways;
1) When the cover is removed, the switch is open. No connection of the two wires is present. Remove the switch, put a piece of heat shrink tubing over one wire, and slide it back out of the way.
Twist the two wires together with an Electrician's knot, solder them, slide the heat shrink tubing over the connection, use heat to shrink the heat shrink tubing.
2) When the cover is removed, the switch is closed. The wires are grounded out. Remove the switch. Cut the exposed bare wire off, leaving just the insulation. Put a wire nut on it. Do the same for the other wire.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 24, 2012 | Intel Computers & Internet
No power from transformer
If the switch mode power supply does not power up then it maybe be faulty.
First check the power button wires from the front panel to the motherboard is seated correctly on the motherboard.
If it still does not boot up then replace the switch mode power supply, make sure the new switch mode power supply has the same or higher wattage rating.
Apr 05, 2012 | Computers & Internet
Hi, i currently have 2 faulty laptops with the same problem, when you try to switch them on theres no power, but if i leave the laptop for a few days it will come back on no problem last a few hrs or so...
Do the fans kick in when the machines are working? First thought is overheating problem, could be due to fans not working correctly or dust, and if it is maybe need to re-apply thermal compound to cpu (arctic silver).
hope this helps get back to me if i can help further
Oct 29, 2009 | ASUS Computers & Internet
Emachine t5230 cpu fan too fast
Hi orinzelenak,
This may seem like to simple, but try checking to see if the technician plugged the fan power supply into the correct pin for it. It sounds like the fan is plugged into a external plug directly from the power supply and not into the board, which would control the fan speed for you. Give a look, and maybe it's just that simple.
Good Luck
Mark
Jan 04, 2009 | E-Machines T2682 (000002965) PC Desktop
Hp color copier 190
Have you check the power cord and tried a different wall socket also change the power cord. After doing this the problem will either be four things.
  1. The fuser door not shut correctly
  2. The Front door not shut correctly
  3. The power supply switch faulty
  4. The power supply unit faulty.
Hope this helps
Thanks J
Jan 01, 2008 | Office Equipment & Supplies
E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
E-Machines eMachines Desktop PC Logo
215 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
