Question about Car Audio & Video
Car amplified speakers...massive bang...
I currently changed my car radio, origionally had alpine head unit,worked fine with 800watt fly amp, supplying 2 vibe speakers!!now that i had changed radio, when i turn the radio on....i hear a scary loud bang from the speakers, after bang they work fine, and also when i turn off the radio, it makes a really loud bang or thud from the speakers!!what could be the cause and how do i fix this before my speakers blow man
Cheers Jay
  • Jay2412 Apr 20, 2009
    instead of making a delay circuit board....would it be possible to integrate a switch on the amps remote wire...an turn the switch off before the radio...if that would be possible it would be good,because then i would have the choice of turning on/off the speakers
  • 4 Answers
This kind of problem is often caused by transients in the signal
processor as it powers down finding their way into the signal path,
which the amplifier then transmits to the speakers.
Usually this can be solved by adding a little turn-off delay to the
processor. This allows the processor to stay powered on for a short
time after the amplifiers have powered down, thus preventing the pop.
Many components sold today (such as crossovers, equalizers, etc) have
delays built-in. Read your manual to see if it is possible to set this
delay on your piece of equipment or be sure to look for this feature
during your next car audio purchase.
If your processor does not have this feature, you can build your own
delay circuit with a diode and a capacitor. Add a 1N4004 diode in
series with the processor's turn-on lead, striped side towards the EQ.
Then add a capacitor in parallel, the (+) side of the cap connects to
the striped (processor) side of the diode, the (-) side of the cap goes
to ground (not the radio or EQ chassis - connect to the car chassis).
Experimenting with the cap value will give you the right amount of delay
before the EQ shuts off. You don't want it too long, just long enough to
make sure the amp is off before the EQ powers down. 220 - 1000 uF is
about right, and make sure the cap is a polarized electrolytic, 16V or
higher. Also keep in mind that the diode will introduce a 0.7V drop on
the remote wire, which can cause the processor to power down before the
rest of the system.
Posted on Apr 20, 2009
Need to wire alpine amp to factory ford radio
use one of these in parrallel on the speaker output, and connect the RCA-RCA on the amp, should work fine
http://cgi.ebay.co.uk/Speaker-to-RCA-Line-Level-Converter-Adaptor-Pre-outs_W0QQitemZ370214078716QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Amplifiers_PP?hash=item56327a88fc
Feb 14, 2010 | Alpine MRP-M350 Car Audio Amplifier
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Car Radio bench test procedure and special equipment???
Hi and welcome to FixYa,
Could you post back the exact model of the Alpine radio/head unit pls? It would also help if you know what was originally installed in your vehicle, if there is an external amp and how many speakers are currently installed. Some high end vehicles also uses the car radios/stereos for alphanumeric displays, might this also be in your car's model?
Would appreciate postback. Good luck and thank you for using FixYa.
Feb 13, 2009 | Alpine Car Audio & Video
I have an alpineIVA-D300 and I think the amplifier is bad. The screen works, radio goes to channels but I get no sounds.I have tested the speakers and they work
This may help. Alpine typically controls their internal amps one of two ways:
1) menu setting for external amp or defeat internal amp
or
2) top of the unit (with it removed) there maybe a series of switches by channel (front, back and sub) on the unit. My current alpine has the switches on top.
Jan 01, 2009 | Alpine IVA-D300 Car DVD Player
No radio sound from my IVA-D310E
neither of those units use fibre optic cables! but it sounds like you puled out the antenna wire behind the head unit. if you try and search radio stations without the manual tune on and it keeps changing frequency on it and never stops then its the antenna plug.
Nov 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Mar 08, 2008 | Alpine CDA-9885 CD Player
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
No sound from speakers after mra-f350 connected to alpine w205
Did you set the digital output to the on position on the bottom of the head unit?
You have to switch the head unit off then back on for it to recognize the position of the switch.
Oct 27, 2007 | Alpine MRA-F350 Car Audio Amplifier
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
