Question about Panasonic PT-52LCX65 44" HDTV
Large fish eyed picture
In the fish eyed area the the whites are yellowish and greenish. outside of the fisheye in the corners of the screen the colors are crisp and clear. why is this happening? can i fix it myself or do I need a repair man?
    Genius:
  • 1,148 Answers
TRY NEW CONNECTIONS AND JACKS ,,ALSO IN THE MENU GO TO COLOR CONVERSION AND USE IT
Posted on May 15, 2009
DLP D9 VIVITEK PROJECTOR
Sounds like the color wheel may be bad
Nov 18, 2013 | oneworld_china Active 3d Glasses For...
I have a Nikon D-40 I'm currently using a 55-200
Fisheye is the extreme of a wide angle lens. I think you are not using a fish eye lens, but a fish eye adopter. That is a lens that will "shorten" the focal length of a lens most of the time with 30 % sometimes with 50% when you put it in front of your lens. So you could make a 24 mm lens look or act like a 12 mm.
On your tele lens this only will slightly shorten the 55 mm, but even 50 % of 55 is 27 mm and can't be seen as a fish eye.
I think when you put this on a short lens, the picture you get will be round, like you were using a real fish eye.
Feb 28, 2012 | Nikon Cameras
My fisheye pictures don't come out perfectly circular anymore... on the bottom right corner of all the pictures is a black part that looks like a shadow. what is wrong with it?
Sounds like you have a light leak. At the film plane of your camera the image from the lens is upside down and laterally reversed, so the light leak is at the top left of the film when it's in the camera. If you're shooting for prints look at the strips of negatives. If the edges of the film are affected as well as the picture area then the light leak is at the back. If it's just the picture area then the light leak is through the film gate. If you hold a strip of negatives in the camera with the emulsion towards the lens and the picture upside down and then line up the picture with the film gate this should point to the problem area. All this assumes that your finger wasn't in front of the lens... :-)
Nov 29, 2009 | Lomo Fisheye 35mm Film Camera
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Screen discoloration
try going to this link - http://www.retrevo.com/support/Mitsubishi-WD-62531-TVs-manual/id/564ag724/t/2/ all tips and tricks in troubleshooting your HDTV you may find it here. Hope this Helps...
Nov 03, 2009 | Televison & Video
Discolored screen
If this is an older tube projection tv, it sounds like you have burnt phosphors on the crt. No solution except for replacement of the crt's and that is expensive.
Sep 01, 2009 | Hitachi Televison & Video
Screen of projection tv has a large yellowish greenish splotch in the center
iF IT IS ONE OF THOSE WITH THE THREE CRT'S THEN THE FLUID IN ONE ARE ALL THREE IS CONTAMINATED, IF IT IS ONE OF THE NEW ONES WITH THE LAMP, THEN THE LIGHT ENGINE IS BAD.
Sep 01, 2009 | Televison & Video
What causes fisheyes using an inexpensive HVLP system with Tremclad metal paint on aluminum?
Here is some information to solve the problem.
Fish Eyes: A surface depression or crater in the wet paint film. Fish eyes are caused by repulsion of the wet paint by a surface contaminant such as oil or silicone. The depression may or may not reveal the surface under the paint. Make sure the surface is clean.
Etching Primer
If you are going to be painting any aluminum, you are going to need an etching primer. This primer can also be used on steel. It is two-parts (not like epoxy, though) and tends to "bite aggressively" into the metal. It really stinks to have your paint stick well to your primer, but the primer releases from the metal. One of the major benefits is that you can paint over the primer in 1/2 hour, about the time it takes you to clean your gun and mix the paint.
OTHER PAINT RELATED STUFF
Additives: You can get anti fisheye additives, hardeners, flatteners, catalysts, metallics, metal flake, pearls, and reducers to mention a few. Get an anti fisheye thats compatible with the paint you use.
Masks Use a good quality dual cartridge mask for all work. Don't skimp, get the charcoal cartridges, they stop most aromatic vapors.
Jun 12, 2009 | HVLP 10 Piece Hvlp Paint Spray Gun Set
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Jun 13, 2008 | Philips 55PW9363 55" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
157 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
