Question about Microsoft Xbox 360 Console
2 lights my 360 is is flashing with 2 lights and everytime i turn on the console it just flashes off and sometimes it will play for awhile then it will start flashing and also it won't read all my games
  • dennisbrack Nov 18, 2007
    consul lights up, centre of lights is on but only middle light is on in green, no sound, no vision, consul wurs and buzzes, all connections secure.
    disci in tray makes no difference. worked well for a year no problems,
    is it a bin job? regards DB
    have tried several games, have checked all connections,
    Scholar:
  • 57 Answers
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. 1. Let the Xbox 360 console cool. Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot. 2. Verify that the console has sufficient ventilation and that the fans are operating. 3. If the two lights continue to flash redafter you try steps 1 and 2, contact Xbox Customer Service To try to prevent this problem, use the following precautions:? Do not block any ventilation openings on the Xbox 360 console. ? Do not put the Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings. ? Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated. ? Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Posted on Sep 20, 2007
  • Anonymous Nov 27, 2007
    HOW IS THIS INNAPROPRIATE> CAME FROM MICROSOFT THEMSELFS>>>>>
    check yourself
SOURCE:
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
When playing Xbox 360 Games i get Flashing lights/Lines
sounds like the graphics chip is on its way out might just be a cold solder joint normaly turns to 3 red lights when ppl mention this to me
Jun 08, 2009 | Sony Playstation 3 (PS3) Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
2 red lights
This problem may occur when the Xbox console is too hot or is overheating. The flashing lights mean that the internal temperature of your Xbox 360 console has exceeded acceptable temperature limits. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot.Verify that your Xbox 360 console has enough ventilation and that the fans are operating. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Microsoft can be contacted by finding the number listed on the back of your video game booklets.
Good Luck to you and Happy Gaming.
Source:
http://support.microsoft.com/kb/907533
Oct 17, 2008 | Microsoft Xbox 360 Console
Xbox 360
4 RED lights are usually the AV cable is out. Borrow your friends cable then try it. If its the console send it to microsoft
Jul 24, 2008 | Microsoft Xbox 360 Console
Console flashes red instead of green
3 x flashing red lights,everytime i turn xbox on
Jul 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
