Question about Samsung Digimax A7 Digital Camera
The flash has stopped working I think the bulb is blown??
I own a Samsung Digimax A7 Digital Camera and today the flash stopped working what can I do? How do I get this repaired and is it expensive to do this? Thanks for your help
  • siprendergas Apr 20, 2009
    I have tried this and am convinced that it is the bulb but do not know how to get it fixed. Thanks for your help it is greatly appriciated.
  • 34 Answers
On the left,right,up and down buttons on one it looks a bit like a lightning strike go to picture mode and press it.
Posted on Apr 19, 2009
Driver for samsung digimax A7 digital camera
Cameras don't usually require a driver for accessing the picture storage by USB cable. However other functions may require a driver. I expect Samsung provide this on their website in the downloads section.
Jun 07, 2014 | Samsung Digimax A7 Digital Camera
My Samsung Digimax A7 camera will not load memory cards. I insert a card and then turn on the device, which prompts a format for the card then I hit yes, the camera thinks for awhile then just turns off. ...
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
Mar 01, 2011 | Samsung Digimax A7 Digital Camera
The flash has stopped working. The red strobe light at the back flashes to tell you the flash is charging, but then does not stay red and when you take the picture the flash does not work, regardless of...
The flash capacitor could be bad, or the batteries could be weak- make sure they're charged, and clean the battery and camera contacts with a qtip and at least 90% isopropyl alcohol.
The flash consists of a small step-up transformer, a capacitor, small ic, and the xenon bulb. Some terminals on some cameras are coated with an insulating glue, but one some you can discharge the capacitor with a screwdriver- be ready for a fairly loud "Pop!". Do it a couple of times, or whatever it takes to fully discharge it. Look for broken, bad, or cold solder joints on the relavent devices. Take the old solder up, and resolder, if required. You can ohm out the transformer, and cursorily check the cap, but caps can break down while trying to charge, so that isn't always a conclusive check. The flash board is usually a separate board, and can be replaced as a unit. You might try to get an "as is" model off Ebay with a good flash circuit, and replace the board, bulb, and cap as a unit, but that's not an easy job. Other alternative is to get a new camera, since if you elect to have it serviced, it will justify buying a new one, in most cases. I found a working replacement on Ebay for $.99, but the shipping is $26.90 (you could try to talk them down). Here's the link:
http://cgi.ebay.com/Samsung-Digimax-A7-Digital-Camera-2-0-Monitor-Works-/220669630293?pt=Digital_Cameras&hash=item3360ef5755
Good luck, and hope this helps.
Sep 21, 2010 | Samsung Digimax A7 Digital Camera
Samsung flash doesn't work
Go to Menu -> Setup -> Lamp -> On
Aug 09, 2009 | Samsung Digimax S73 Digital Camera
Digimax a7 users guide
you can download usermanual for this model thru: www.samsungcamera.com on the search bar just type in the model which is a7 and you can see option for usermanual
Dec 28, 2008 | Samsung Digimax A7 Digital Camera
I Have no manual for my camera Samsung digimax A7..
Samsun website to download technical date from:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=+DIGIMAX+A7&dType=D&mType=&model_cd=&menu=guides&prd_i
Dec 10, 2008 | Samsung Digimax A7 Digital Camera
Digimax a7 battery problem
I had the same problem, apparently if you're using a external memory card that can cause this problem...
I didn't know that but I contacted Samsung and got mine repaired.
They put a note in saying the power board was faulty in the camera.
Much, much better now can take pictures like I used to be able to!
Jun 09, 2008 | Samsung Digimax A7 Digital Camera
Replacement part for Samsung Digimax A7 camera
Camera of this type are usually considered-'Consumable'
Like small radio DVD players toaster and kettles if it gets broken you buy the next one.
If it fail in service under warranty is it replaced complete - there will be no parts.
Duct Tape can come in very useful for this type of thing
Dec 24, 2007 | Samsung Digimax A7 Digital Camera
Samsung Digimax A7 Digital Camera Problem
My camera will not turn on , it froze last month whilst the lens was out so i pushed it back in and it started to work fine this time it has forze or broke with the lens inside and it will not turn on the batteries are fine but i cant turn the camera on?
Nov 05, 2007 | Samsung Digimax A7 Digital Camera
Samsung Digimax A7 Digital Camera Logo
143 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
