Question about Compaq Evo N610C Notebook
Windows come on but no place to enter my log on name
Tip
How to Set Up Windows 7 Auto Login?
Windows 7 requires that you log on with your user account information each time you start your computer. If you wish to bypass this step, learn how to <a href="http://www.windowspasswordsrecovery.com/automatically-log-on-windows-7.htm">set up Windows 7 auto login</a>.<br /> I think maybe some people will impatient of logging in every single time when reboot their computers, expecially while they are just running home computers for gaming, listening to music, seeing a film or doing something unimportant. Today we will take a look at how to log on automatically in Windows 7.<br /> Another reason is that many people always <a href="http://www.windowspasswordsrecovery.com/forgot-windows-7-password.htm"><b>forget their Windows 7 User Password</b></a>. They need comuter automatically auto login while forgot password.<br /> Overview Whether your main computer is one that you use in the Office or one of your family shares in the cave, could the life you a little easier, if not to every time it booted log. You could press the power button, then go out and fill your cup coffee or dinner start and then come back to your beautiful thermal desktop. Instead you must either wait to boot type in your username and password one or you need to do this one again on your desktop.<br /> Fortunately, there is a way to <b>set up Windows 7 auto login</b>. That being said, consider whether it safe enough to do this. If even the slightest possibility that someone should could not have access to information on your computer it press the power button and wait your PC with fire, without you know then you will probably want to keep the user name and password in position. Are concerned not at all, read how to <b>enable Windows 7 auto login</b>.<br /> Manage User Accounts Before getting started with Windows 7 auto login, you may wish to find out how to create user accounts and change passwords as needed. To add a user account, change a password or enable Windows 7 auto login, you must be logged on as an administrator.<br /><img src="make-changes-to-windows-7-user-account.jpg" /> To create or manage user accounts, click Start and type user into the Instant Search box at the bottom of the Start menu. Select User Accounts from the results. Select the account you want to change and click the option for the changes you want to make. To create a new account, click Manage Another Account and then select Create New Account.<br /> Enable Windows 7 Auto Login Once you are logged in to the computer as an administrator, you can proceed with <b>Windows 7 auto login setup</b>. In order to set up Windows 7 auto login, the first thing you need to do is to get to the Advanced User Accounts Control Panel.<br /> <b>Step 1:</b> Open the Run dialog by clicking Start, typing run and pressing Enter. You can also use the keyboard shortcut Windows Key+R. Just type in "<b>netplwiz.exe</b>" into the start menu search box, click OK or press Enter., and you&iexcl;&macr;ll see this screen.<br /><img src="netplwiz.jpg" /><br /><b>Note:</b> If it doesn&iexcl;&macr;t work, you can type in "<b>control userpasswords2</b>" instead.<br /> <b>Step 2:</b> Uncheck the box which says "<b>Users must enter a user name and password to use this computer</b>". Click "Apply" or "OK" to apply this change.<br /><img src="users-must-enter-a-user-name-and-password-to-user-this-computer.jpg" /> <b>Step 3:</b> A new dialog box will open, aptly named <b>Automatically Log On</b>. You will need to enter the user name and password for the user account that you want to automatically log on each time the computer is started. Type the user name into the User Name field, type the password for this account into the Password field and then enter the password once more in the Confirm Password field. Hit &iexcl;&deg;OK&iexcl;&plusmn; to finish your configuration.<br /><img src="automatically-log-on-windows-7.jpg" /> <b>Note:</b> Of course, these steps can work perfectly on XP as well.<br /> Tips: Not a Windows 7 user? Still Using XP or Vista? Don't know how to automatically log on other Windows Versions without entering user name and password? See these articles below.<br /> <b>How to Autormatically log on Windows XP?</b><br /> <b>How to Autormatically log on Vista?</b><br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Windows 7 Password Reset Disk [Safe Download]</a><br />
on Mar 04, 2011 | Computers & Internet
Tip
Methods to reset your Windows XP password
There is nothing to worry if you forgot your Windows logon password or if your password expires. You can reset your Windows password by following instructions given below.<br /><br />You cannot reset password unless you have reset disk or can log on as an administrator. You may need to reinstall your operating system before using computer again. This is an essential safety measure setup by Microsoft Windows. Without this, anyone could change a password of anyone's computer. <br /><br />Reset Windows XP Home Edition Password<br /> <br />There are two methods to reset Windows XP Home Edition password<br /><br />First Method: <br /><br />To reset password you may need to log on as an administrator. Follow steps mentioned below to log on as an administrator <br /><br />a. Reboot the PC.<br />b. Press CTRL+ALT+DELETE couple of times, and then type the name of the administrator user name or just type 'Administrator'.<br /><br />c. Type your administrator password in the password field, and click OK. If you do not know the password, leave it blank, and click OK. <br />d. Press Start button on the taskbar, and click Run.<br />e. Enter control user passwords 2, and click OK button.<br />f. Open Users tab, select the user account form the list that you want to reset the password for, and press Reset Password.<br />g. Select a new password and Enter it in the new password field and then type that password again in the confirm password field, and then press OK.<br />h. Reboot the PC, and try logging in to the computer. <br /><br />If your computer is a member of a domain then follow these steps:<br /><br />To log on to the window as an administrator: <br /><br />a. Reboot the PC, and press the F8 key during the boot until the Windows Advanced Options menu appears.<br />b. Select the Safe Mode option, and press ENTER key.<br />c. Select Microsoft Windows XP edition, and press ENTER key. <br />d. Click your user name screen button, then click Administrator, and enter the administrator password in the password field.<br />e. Press ENTER key, and click Yes. <br /><br />To reset the Microsoft windows password:<br /><br />Click Start button on the taskbar below and then click Run.<br /><br />f. Enter control user passwords 2 in the text field, and click OK.<br />g. Pick the logon user name for which you want to alter the password.<br />h. Click on Change the Password, and enter a new log on password. <br />i. Press Change Password button.<br />j. Reboot the PC, and then log on to the windows. <br /><br />The Second Method: Using a password reset disk<br />To log on to the computer by using a password reset disk, follow the steps outlined below. <br /><br />Reset password for Windows XP Professional Edition<br /><br />1. Reboot your PC.<br />2. Click the user name, you'll see an error. <br />3. Click on the Use your password reset disk. The Password Reset Wizard window will open.<br />4. Click Next.<br />5. Insert the password reset disc into the CD/DVD drive, and click Next.<br />6. Type a new password and confirm the password in the required fields, then click on Next.<br />7. Click Finish, log on to the PC again. <br /><br />
on Jan 18, 2011 | Computers & Internet
I canno find my contacts on windows live hotmail
In the top left hand corner there should be drop down list Click on the people tab all contacts are there
or
Live email contacts
Windows Live Hotmail lists all contacts alphabetically, to a maximum of 25 on a page.
When all the contact fields are filled out, the contact is sorted alphabetically by first name.
If a first name is not entered for a contact, it is arranged alphabetically by last name.
If neither a first or last name is entered, then it is arranged alphabetically by email address.
To find Hotmail contacts on Windows Live Hotmail, use the search field.
Log into Windows Live Hotmail using your username and password.
Click "Contacts" on the left side of the page.
Type all or part of the first name, last name, or username of the person you are looking for in the text field marked "Search Your Contact List."
Press "Enter," or click the "Search" icon inside the text field.
A list of contacts matching the name you typed will be presented.
Place your mouse over avatar of the contact you are looking for.
A pop-up menu will open.
Click "Send Email" to send an email to that person.
Click "View Details" to see the contact's profile page.
Click "All Contacts" on the top left of the screen to clear the search results.
http://explore.live.com/windows-live-contacts-search-using
Sep 08, 2013 | hotmail.com
I seem to not be able to get logged in..
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
Nov 22, 2011 | Microsoft Windows XP Professional for PC
Tip
Forgot Windows 7 Password - What Should You Do to Log on Your Computer?
Just as Tom Hanks said in the famous movie Forrest Gump, "Life was like a box of chocolates, you never know what you gonna get." As a Microsoft Windows version launched for only 9 months, Windows 7 has overtaken Windows vista in global market share according to California-based Net Applications. It moves up to the second place in the Microsoft's OS, with 14.46 percent of the global market last month compared to Vista's 14.43 percent.
As a common PC user, I don't know whether Windows 7 will surpass Windows XP, which still has a lion's share of users worldwide after released for 9 years. I also don't know when Windows 7 will pass Windows XP if it is able to overtake. But as a common PC user often forgetting Windows password, I do know some ways to log on computer again if one forgot Windows 7 password.
The most well-known method is to create a password reset disk in advance. And when you forgot Windows 7 password, you can reset Windows 7 password with the disk and log on your computer again. The steps to create a password reset disk and how to use the disk to reset forgotten Windows password are available on Microsoft official website and various PC forums. Here I introduce you another effective way to regain access to computer if you forgot Windows 7 password. That is to reset lost password with Windows password recovery software, which can help you to reset Windows password with a bootable CD/DVD or USB flash drive. Following are steps to recover Windows 7 password by burning a USB flash drive.
Step 1: Download Windows Login Recovery and install in a computer.
Download Windows Login Recovery from official website, and then install it.
Step 2: Burn a USB drive to reset forgotten Windows password.
Follow the step-by-step guide to burn a USB drive to reset lost Windows 7 password after running Windows Login Recovery (the detailed user guide). After burning, insert the burned USB flash drive in the computer that you forgot Windows 7 password.
Step 3: Set BIOS to boot from USB.
1. Start computer and press F2 or Delete to enter BISO setup during the initial startup screen.
2. Use the arrow keys to select the Boot tab, and then select Hard Disk Drivers and press Enter.
3. Adjust USB to 1st Drive, and then press F10 to save.
The computer will restart automatically, and then you can start to remove the forgotten Windows 7 password under DOS.
Note: What key is pressed to enter BIOS depends on the manufacturers, but in most cases it is F2 or Delete.
Step 4: Remove the forgotten Windows password.
1. Choose the installation path of Windows, and enter the ID of the path. All user names will be displayed for you.
2. Select the user name you want to remove its password by entering the ID of the User Name. And then enter y to confirm and continue.
3. After removing the password for the selected user name, you can enter y to continue to reset passwords of other user names, or enter n to restart computer. And now you can log on computer without password.
Important: After selecting n to restart computer, please remember to press any press, and then take the burned USB flash drive out of computer.
After the above simple steps, your forgotten Windows password is removed so that you can log on your computer without password. This method can not only help you reset forgotten Windows 7 password, but also help you regain access to computer again when you forgot Windows password on Windows Vista, Windows XP and son. And there are 2 different editions of Windows Login Recovery for your choice according to your actual password.
on Aug 17, 2010 | Computers & Internet
Tip
Auto logon in Windows 7
You can use automatic logon to log on to your Windows 7
without having to type a user name or password.
(With automatic logon you will not see this anymore)
Configure Windows 7 to auto logon a specific user:
1. Open the Start Menu>All programs>Accessories>Run
(When you open this copy it) control userpasswords2
click the OK button.
2. Click on the user account name,
that you want to have automatically log on to highlight it.
Uncheck the Users must enter a user name and password
to use this computer box.
3. If the listed box blank - unchecked.
4. In the Password field, enter the selected user account's password.
If the user account does not have a password, then leave this field empty.
5. Restart your system, and you’re automatically logged in to Windows 7.
on Jan 26, 2010 | Computers & Internet
How to network connect and activate windows 2007 & MAC X
Set up user accounts
Users connecting to Windows Sharing must have user accounts on the Mac OS X computer that is sharing. There is no guest access. Any person who already has an account on the Mac OS X computer can use his existing account. You must log in to the Mac OS X computer with an administrator account to set this up. The steps differ for new and existing users.
For new users
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Accounts.
  3. Click New User (10.2) or the "+" button (10.3 or later).
  4. Enter the Name and Short Name for the user who will log in from Windows.
    The user's short name is exactly how the user will enter their name when they log in to Windows Sharing. The short name is always lowercase.
    For users of Windows 98: If you log in to Windows 98 with a username, make sure it matches your Mac OS X account's short name. If you do not log in to Windows 98 with a username, you will need to create a new Windows 98 username that matches the account short name in Mac OS X. For more information on using Windows operating systems, please see Microsoft documentation or contact Microsoft for further assistance.
  5. Enter the user's password.
  6. 10.2 only: Click the checkbox for "Allow user to log in from Windows".
  7. 10.2 only: Click OK.
  8. Quit System Preferences.
If your Windows PC has is equipped with an Ethernet port, you can connect your PC and Macintosh using an Ethernet cable. By doing this, you are creating a small local network, consisting of just the two computers. Set up your Windows PC by turning on File Sharing. Refer to the instructions that came with your Windows PC if you're not sure how to do this.
To locate and connect to the Windows computer, you can use the sidebar in a Finder window. You need to know the workgroup name for the computer and the network name (called the "computer name") for the computer. To connect to the computer, you also need a user name and password and the name of the shared folder you want to access. If you don't have this information, contact the person who owns the computer or your network administrator.
If you cannot locate the Windows computer in the Network browser, you may be able to connect to it using the Connect To Server dialog in the Finder.
Make sure the Internet Connection Firewall is turned off, or if it's on make sure TCP port 445 is open to allow sharing connections.
To connect you Mac and Windows computers: step_1.gif
In the Finder, choose Go > "Connect to Server."
Type the network address for the computer in the Server Address text box using one of these formats:
smb://DNSname/sharename smb://IPaddress/sharename
Follow the onscreen instructions to type the workgroup name and a user name and password, and choose the shared folder you want to access.
Feb 23, 2011 | Computers & Internet
Initialising Mailbox
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Apr 23, 2008 | NorStar M7310 Corded Phone
I wanna to change of the windows xp's strat name
Download a software named resource hacker from internet. Its of some kbs only. In that software you open your "explorer.exe" located at C:/windows/ In that go to String Table->37->1033->and change 'start' to 'yourname' Do not remove single quotes. Save it with other name as "newexplorer.exe" But before doing this make copy of your explorer.exe in other drive or place. Now change the registery by writting "regedit" in Start->Run Navigate to: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows NT\ CurrentVersion\ Winlogon In the right pane double click the Shell entry to open the Edit String dialog box as shown. In Value data: line, enter the name that was used to save the modified explorer.exe file. Click OK Close Registry Editor and either log off the system and log back in, or reboot the entire system if that?s your preference. If all went as planned you should see your new Start button with the revised text.
Sep 27, 2007 | Microsoft Windows XP Professional for PC
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
