Question about Rockford Fosgate Power 1050S Car Audio Amplifier
Noise in my car amp.
My amp used to be fine for a long time. Then one day it started making a humming noise, and the bass would start hitting like crazy with music on or off. I used to just unplug the rca cables. Then the next time id get in it, and plug the rca cables back up it would be fine, and a few days later do the samething. Now its doing this nonstop, if I turn my jeep on i have a low humming noise in the subs which are hooked to the amp. no noise at all in the normal speakers. If i take the rca cables out of the radio and just leave them in the amp, I can hear a low sound coming from the subs just from touching the other end of the rca cables, ive tried 3 different rca cables thinking that may be the problem, and its the same with all. Ive taken my ground from where its always been, cleaned it up and put it back since it worked forever in the same spot, and that didnt fix it. I followed my power wire to the battery looking for any cuts or anything and it was fine, even cleaned the end at the battery. took the dvd player out of the dash looking for problems and havent found any. for the time, i just have my amp on my backseat, rca cables running from the radio straight back to the amp on the seat. my power and remote amp wires ran on the right side (side of the battery) back to the amp, and my ground cable just a couple feet to the left of the jeep. Any answers to what may be causing this would be really helpfull. thanks in advance. I miss my bass :(
  • 3 more comments
  • militaryguy_ Apr 20, 2009
    I'll check this out tomorrow morning, but this amp doesnt have any fuses. (I would think so but) Should I unplug the power/ground too from the amp before doing this testing?
    Ok, this seems to be the problem, but I dont really know how to check/fix the connection between the shield and the board. Could you tell me how, or give me steps please? Sorry, I dont know much more then hooking them up lol.
    nevermind, turns out this isnt the problem. used another pair of testers and said 0.
  • Perry Babin May 11, 2010
    You should have a fuse in the wire from the battery. Remove it so the power source is disconnected from the amp.
    It sounds like you may have an open shield connection on the amplifier's RCA jacks. Remove the main power fuse before removing the cover from the amp.
    To check the shield ground on these amplifiers, touch one of the meter probes to the shield of each vertical set of connectors and push back. If there is ~0 ohms between the two shields when pushing back, the ground connection is OK. If there is more than 1 ohm of resistance, you need to check the connection between the shield and the board.
    http://www.bcae1.com/temp/checkingground...
    Problem Solver:
  • 11 Answers
Is it ok to ground my car amps directly to the ground post of my battery? Seems like it would be because the battery ground is about 10 in. away.
Posted on Aug 01, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Rockford Fos... Master
  • 2,226 Answers
Sounds like you have a bad ground going to your rca's. try running a wire from ground to the shield of your rcas and see if the noise goes away.
Posted on May 08, 2009
Ford expedition noise
humming could be the motor turning round but not engaging with the flywheel. you can check this by hitting the starter with a spanner a few times. if it starts up after you have a sticking solenoid. had to do this a few times my self to get engine started. replace starter as soon as possible if it works. usually happens if you not driven car for awhile.. or you do a lot of starting and small trips.
Jan 24, 2014 | Cars & Trucks
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
I have a set of subwoofers in my car powered by an amp with capacitor all 3 years old. A couple weeks ago I encountered a problem where my system will suddenly emit a weird loud humming noise (similar to...
try taking out the capacitor and wire the amp up with out it. it sounds like the cap is back feeding or discharging voltage when it should not be . if you reinstall the amp with out the cap and noise goes away buy a new cap or do away with it .
Oct 29, 2010 | Rockford Fosgate T600-2 Car Audio...
My dishwasher is an MDBH955AWW. It was perfect
If the water pump inside is stuck, this will happen. Do not run unless you are clear. The pump coil may get burnt if left to hum.
Humming noise will be some times due to the the relay coil also. If you can check your self it's fine. Otherwise take the help of a service provider.
May 24, 2010 | Dishwashers
Car subwoofer makes deep bass when i hit the gas.
there could be 2 reasons why, first make sure your power and remote wire is ran down one side of the car, second make sure the rca jacks is on the opposite side of your alternator, make sure they are that way, this will work, if noise is still there, then you may need and inline noise suppressor. but you shouldn't
Feb 20, 2010 | Kicker 05C104 Car Subwoofer
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
Rockford Fosgate Power 1050S Car Audio Amplifier Logo
497 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
