Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice maker part WR60x0202
Hi, I have the fridge GE TFX26PPDAww seems like I'm rebuilding this fridge. I replaced the blue pump in the back of the fridge. This pump does have cold water coming out. BUT the ice maker does not work. Working by myself, I can't get electric to the blue pump to fill the ice cube tray. Any suggestions? Am I right about it being part WR60x0202? The blue pump was clogged from sand in the well. I now have a filter. Thanks, Joey
  • 100 Answers
Your part number is for and auger motor. I believe the "pump" you are talking about is the water valve part#-WR57X10023 if the icemaker doesn't send voltage to the valve then it would need to be replaced part#-WR30X0327
Posted on Oct 30, 2007
SOURCE:
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Have a tfx26ppdaww GE profile freezer/refrig. The freezer is not producing ice. I do get water from the front door though. Not sure if its the water inlet section, the ice maker, or the control board are...
sounds like a section of the dual water inlet valve relay is shorted not letting water thru you need to replace they are not too expensive also check to see if the lever on the ice tray is not in the off(up) positionand hear if water fills up the ice tray if not replace the valve.
Jun 16, 2011 | Refrigerators
GE side-by-side refrigerator tfx26ppdaww freezer cold, frost on back wall, fridge side warm, is it the damper? or something to do with the frost?
The Thermostat Defrost its not working anymore, it doesn't defrost anymore and it acumulate ice on the gap that flows the is in between the fridge and the freezer. so what you got to do is defrost your refrigerator and remove the back wall, and locate the defrost, cut it and take it to an appliance part store, and get a new one and just put it back and it should work like new!! :)
Jan 14, 2011 | GE Refrigerators
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Hi I have a GE Fridg. #GFSL6KEXALS Just has ice in bottom freezer, no water. Ice maker quit working, Does not seem to be filling with water.
Check the water line that goes from the house plumbing all the way to the inlet on the 'fridge. Are there any kinks? Dirt obstructing the line? You MUST BE VERY CAREFUL when pulling the 'fridge out to check. If you have a copper line, it takes NOTHING for one to kink. And as soon as it kinks...it's done.
Feb 23, 2010 | Refrigerators
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
Ge refrige freezer ,water to ice maker.
HI.YOU NEED TO CHECK THAT THE WATER VALVE IS WORKING OK THERE ARE TWO SEPARATE VALVES FOR THE FRIDGE
GOOD LUCK MOHAMED
PLEASE RATE THIS
Oct 19, 2008 | GE Monogram ZDI15C Automatic Icemaker
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
271 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
