Question about RIM BlackBerry 8820 Smartphone
Power cycles but never starts
BB 8820 power cycles, by that I mean it starts the hourglass appears then goes off and the red indicator light comes on. This cycle continues indefinitely. Tried a reset, no effect Tried connecting via USB to the Desktop Manage - no use the manage only "sees" the pin for a second & then loses it
  • 407 Answers
You said you'd tried a reset - both types!?
Hold these keys down simultaenously - ALT+RIGHT SHIFT(CAP)+DELETE
Power back on.
If that doesn't work - try a double soft, where you follow the above, wait until you have a blank screen and then repeat - You should get another blank screen followed by the hourglass.
Posted on Jun 02, 2009
What is the red light next to the green power light? It appears to look like a temperature light. My unit won't run.
In most cases it means the shredder is full or something is jammed. Empty the shredding container. If the machine has a "reverse" position on its switch, try running it backwards to get whatever is jamming the teeth to come back out.
Nov 03, 2014 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Swimpure chlorine generator not working
Did you figure this out ? I have the same problem.
Sep 03, 2012 | Hayward Industrial Products SwimPure Salt...
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
BlackBerry® Curve™ 8330 Cellular Phone: hello! my bb curve 8330 won't power on, it is givi...
Might be that the battery is dead.
let it charge for hours without trying to power it.
after that, unplug and press the start button and let it works a few minute. it might take a while.
good luck
May 16, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8310
I had this issue and found that a system restore restored the BB back to the factory settings. I have seen an improvment but, we'll see.
Settings --> Options --> Security Options --> General Settings --> "from the Menu Button click on "wipe Handheld""
and wait!
Apr 29, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry 8820 Smartphone Logo
152 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
