Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Frother not working
Milk frother is only spitting out steam. the milk is not being drawn up the spout.
  • 1 more comment
  • 1955shadow May 11, 2010
    Remove the o rings where the milk frother connects to, there is a green, red and black rubber O ring. Remove them and get a toothpick and clean around where they sit. You will notice a hard milk build up like when you get on your teeth. This is what may be causing your problem the o-rings are not setting their properly. Also, the O Rings might be worn out, replace them.
  • Anonymous Mar 23, 2014
    No water comes out of the milk frother, machine makes no noise when you try to make a capacino. Capacino button just doesn't work. Have consulted manual and the manual doesn't offer any solution.
  • Anonymous Mar 29, 2014
    water flow from frother
    New Friend:
  • 4 Answers
Hey Everyone!
I think this might be the best and easiest solution!
This video on youtube explains it quite well:
Posted on Mar 11, 2017
  • 37 Answers
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Posted on Apr 19, 2009
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
Why does milk frother blow out steam instead of milk?
That is what it is supposed to do. Take cold milk in a cup, and put the frother wand in it... Kind of bob it up and down for a few seconds, and the milk will froth.
Mar 01, 2016 | Coffee Makers & Espresso Machines
Delonghi EN720 milk won't flow properly.
replace o ring ,,, descale ,,, disasemble ,, clean ..
Dec 14, 2013 | DeLonghi Coffee Makers & Espresso Machines
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
5,466 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
