Question about Hyundai HPT-4250 Television
HPT-4250 My Hyundai HPT-4250 is 2 years old There was a pop and the screen went blank Everything else seems to be working ok There is a board on the right side of the TV looking from the rear with what looks like clear flat plastic connections which seem to connect to the screen, it also has a large aluminium heatsink in the middle and a lot of large capacitors and 2 fuses one of which is blown If you replace the blown fuse the replacement fuse does not blow but you loose the sound If you remove the fuse the sound comes back I assume the board is damaged and requires replacing however this is a guess and I am unsure whether this will cure the problem even if I am able to sourse a board
  • 1 more comment
  • johnayhome Sep 20, 2007
    Thanks for your help
    Not sure what you mean
    The power supply must be ok I assume if everything else works except the picture
    The blown fuse I am talking about is on the board which seem to be connected to the screen which I am assuming is the video board and not the main power supply ?
  • johnayhome Sep 21, 2007
    Thanks again for your comments
    However after reading your reply I had a chuckle to myself as it was way above my head
    Is the board that is connected to the plasma screen with the blown fuse and the big heatsink and the bank of capacitors the IHVT power supply board or am I looking for a different board on the other side of the TV where the power cable comes in
  • Stobbsy Dec 26, 2007
    I have similar problem to johnayhome's,our TV will only show the red standby light on,and I have been informed by a leading electrical outlet in the uk that our set needs a replacement 'power supply'module,but they are unable to locate Is there anyone out there that can help me find one ,or someone to help me,as our only 2 years old.
    Thanks Eva Stobbs
  • 1,139 Answers
I think what has happened is that your power supply malfunctioned and what has happened is that a capacitor has blown up. I would suggest that you do a complete search of the power supply to determine the location of the blown capacitor, I would advise getting a schematic to aid you in this. If you don't have experience in electronics I would also advise taking the set to the shop or calling a repairman to take care of this issue.
Posted on Sep 20, 2007
  • Henry McKelvey
    Henry McKelvey Sep 20, 2007
    Hello Johnayhome,
    The power supply of modern TVs is derived for the old Scan Rectification power supplies which are the predecessors of today's switching power supplies. They work the same way, the low voltage power supply turns on an oscillator which excites the HV transformer (IHVT) at a higher frequency then the 60 HZ which is common in the low voltage power supply. The HV power supply running at a higher frequency becomes easier to filter once converted into DC hence lower value capacitors (1000uf vs 50,000uf) are needed. Now here is the cool part about all of this; The voltage that powers the anode of the picture tube comes from where? The IHVT. The voltage that powers the video circuitry comes from where? The IHVT via voltage regulators, The voltage that is connected to the entire TV except for the Audio stages comes from where? That's right the IHVT. The reason that the audio is spared the task of being powered by the IHVT is because the frequency of the ripple of the power supply voltage of the IHVT is 15.750KHZ which is part of the audio frequency range, but so is the 60Hz of the low voltage supply, however 60HZ is not as drastic as 15.750KHZ. 60HZ hum happens and can be filtered out and still maintain good bass response, however you start removing 15KHZ and you start stepping on your High frequency response and that affects too much. hench the audio stage can deal with 60HZ hum but not 15KHZ whine.
    So what I am trying to say is that the screen voltage and the power supply are linked. Since the IHVT is common to both of them directly.
    I hope that this provides some helpful information.
    Respectfully Submitted,
Picture on Hyundai plasma TV but no sound
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 03, 2014 | Hyundai HPT-4250 Television
Trere are lines running up and down half way across the screne they are colorful.
Try to adjust the vertical hold trimer.In adjusting the trimer you look the screen while adjusting the trimer until the screen or picture back to normal.
Jul 04, 2011 | Hyundai HPT-4250 Television
When tv turned on screen stays blank?
Several causes can be attributed to this. If the contrast and brightness have been tampered with then the display remains black.
On the other hand if the picture IC is fried then this is possible. In this case you have to refer your unit to an expert.
Hope this solution has been helpful?
Sep 26, 2010 | Hyundai HPT-4250 Television
I need service manual for hyundi hpt-4250
dear sir good day you can send a req. email to the link below
New York - Tel : +1-201-816-4006 - Fax: +1-201-816-4036 - M/P: +1-201-370-7549 - E-mail : Los Angeles - Tel : +1-310-515-1101 - Fax: +1-310-532-2017 - M/P: +1-310-721-1161 - E-mail : Toronto - Tel : +1-416-229-6668 - Fax: +1-416-229-1224 - M/P: +1-416-779-6812 - E-mail :
Nov 28, 2009 | Hyundai HPT-4250 Television
HPT 4250
if you type in your model number on the internet there is a web site that comes up specifically for your model. they are not difficult to do, i hve done my one and I fed all the wires through the leg of the fire surrond.
If you do not have a fire surround the cables can be burried in the wall
Jul 03, 2008 | Hyundai HPT-4250 Television
Hyundai X and Y board
you can get the sound and vision card from currys masterpart for approx £170.00
£ 250 doesnt seem too bad as long as he guarentees his work for a period of time
Jan 03, 2008 | Hyundai HPT-4250 Television
Black lInes on screen
i have a white line vertical in the midle of tv
Nov 25, 2007 | Hyundai HPT-4250 Television
Hyundai 42" Plasma TV
Try That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
Nov 19, 2007 | Hyundai HPT-4250 Television
Hyundai HPT-4250 Television Logo
357 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
