Question about AEG B4101-4 Electric Single Oven
Setting clock on my neighbour's AEG oven.
Built-in model, forget model no., something like 53580.
Instructions say hold down two centre (of four ) buttons, and use pop-out knob to set new time. I did this, and on letting go the two buttons it reverts to old time. Holding down RH of two centre buttons shows time that was trying to be entered. Extreme LH button had bell icon, ''auto'' shows beside time display, and can not be ''turned off''.
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Posted on Nov 17, 2008
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
How do you set the clock on an electrolux premier built in single oven after a power cut as time is flashing and auto is showing and only four buttons and no instruction manual.
hold down the first two buttons on the far left then turn the little diel button,this will set the time.also you can set the timer useing one button hope this helps roscargou.
Feb 15, 2010 | Electrolux Ovens
I need to reset the clock on my AEG cooker model No S75408 KG
I am assuming you have a touch pad for the clock. You can hold down the time button for a few seconds an it should start blinking. If it doesn't work, try pushing the "set" button for a few seconds. Usually, you can find it by trying all of the buttons til you get the right one. Then, you can adjust the time by moving the up and down arrows.
Jan 29, 2009 | Ovens
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG B4101-4 Electric Single Oven Logo
150 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
